0 Members and 13 Guests are viewing this topic.
I have an E4401B 1.5GHz analyzer that has all of the options I need (including the tracking generator) but was wondering if it is the same as the 3GHz version just limited in someway by software key or other method.SamW3OHM
1.5 GHz model cannot be upgraded because the base RF deck is different to the 3 GHz model3.0 GHz model cannot be upgraded either, because it lacks the IF/LO Amplifier and Yig Filter/Mixer assembly, and frequency extension card which controls them6.7 GHz model apparently can be software upgraded to 12 GHz
I have more to offer
I don't have an ESA myself but I think you have to run the exe on a PC with a floppy drive to extract the contents to the floppy, then use the floppy in the ESA. You probably also need a license code to activate it, I can generate that for you if you give me your HOSTID.
Hello all, many thanks for the effort!Been reading through. How the heck are you extracting the personality files?I need 226, but as I don't have the extended memory - I'm limited to version A.01.15 (as per instructions).I am completely unable to extract the .exe file in any compatibility mode.Tnx
The attached PDFs should answer some of your questions. The extended memory is required to go beyond A.08.02Notes:Instruments must have Option B72 (expanded memory) to install version A.08.02 or newer firmware. Option B72 has been standard in all new ESA analyzers since the end of 2001, and has always been standard in the EMC analyzers.Also look here for documents etc:https://xdevs.com/doc/HP_Agilent_Keysight/HP%20ESA%20E4400%20Series%20Spectrum%20Analyzer%20Documentation%20Firmware%20Tools/
Sorry, total noob to this. Do I just then use the licence no generated an enter it in using the panel, or do I need to copy this file to the ESG? - If I need to copy it, can you point me in the right direction. There is no floppy drive or LAN connection I can see on my E4432B.
In a previous post I asked for help acquiring flexlm software and or keys for some options.
