Author Topic: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B  (Read 104645 times)
0 Members and 13 Guests are viewing this topic.
Offline mankan
Re: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B
« Reply #300 on: November 21, 2020, 04:12:07 pm »
Thanks again PA0PBZ  :)
Now I have the options that is useful for my HW.
As a way of paying it forward, I've attached zipped disk folders so no need for real floppy drives. I also managed to run the disk image SW in my XP Virtual Box, it was the fastest floppy drive I have ever used  :)
Offline smgvbest
    • Kilbourne Astronomics
« Reply #301 on: November 22, 2020, 04:33:33 am »
Hi
I have an e4403B, I would like to start activating the option 049 color display ...
I tried to follow these steps but I believe I am doing something ...
can someone detail the steps more?
I'm using Putty as a serial monitor ...
I can make the morning calls until 9 ...
doing this procedure I need to do what else?
My steps:
0. Set the serial terminal to 19200,8n1
1. DIP sw # 4 set to ON
2. break the boot process with 0x06
3. sword 04139614 4ef9
4. sword 04139618 d8a4
5. DIP sw # 4 set to OFF
6. gu
7. SA restart in normal mode
8. Press "r" and we are in the monitor now 8)
9. Change the serial port speed.
> slong 815F4 1001A
10. Change speed of the serial terminal to 115200, 8n1
does you SA actually have a Color Display?
depending on the Unit some where not shipped with a Color Display and hence the need for Opt 049 when installing a color display
if you have a color display and its not showing color then you need to create a license for 049,   information of which is in this thread on how to do
Sandra
(Yes, I am a Woman :p )
Offline suj
« Reply #302 on: November 22, 2020, 02:26:56 pm »
I don't know if I'm doing it wrong or skipping some process to activate the licenses ...
after this procedure what do i need to do more?
0. Set the serial terminal to 19200.8n1
2. interrupt the boot process with 0x06
6 .gu
7. Restart SA in normal mode
8. Press "r" and we are on the monitor now 8)
9. Change the speed of the serial port.
> slong 815F4 1001A
10. Change the speed of the serial terminal to 115200, 8n1
That was a procedure to get a dump for debugging, not useful to you. The solution is in post #244.
Offline mankan
« Reply #303 on: November 29, 2020, 10:21:00 am »
Weirdly enough I have the same download issue again, this time its the latest ESG fw that fails the same way. Can I bother some of the master downloaders in this thread for assistance? https://www.keysight.com/main/software.jspx?cc=US&lc=eng&nid=-32463.536880925&id=1000001137:epsg:sud&pageMode=CV
Offline PA0PBZ
« Reply #304 on: November 29, 2020, 11:08:01 am »
No problem for me with this one.
The following users thanked this post: mankan, roxbox
Offline Electrole
« Reply #305 on: February 08, 2021, 08:42:51 pm »
Dear all,
I have read this thread with interest and utter admiration! I have recently acquired an almost working E4411B which I'm trying to fix. Eventually, and if the repair session goes well, the E4411B will deserve to have option 1DR (narrow BW) enabled. However, I fail to see exactly which steps to carry out in order to enable this option. Could some of you perhaps be persuaded to write up a small tutorial that takes the reader through the concrete steps? My E4411B has FW version A.14.03 and was born with B72 Expansion Memory, so I guess an update should be doable.
Best regards
Offline PA0PBZ
« Reply #306 on: February 08, 2021, 09:17:00 pm »
Send me a PM with your hostid and the required option and I think we can work it out  ;)
The following users thanked this post: VRCW
Offline n8ur
« Reply #307 on: February 21, 2021, 08:54:15 pm »
I've been trying to do my homework, but a day of searching the interwebs for lmcryptgui has only turned up references in message boards 10 years ago with links to locations that are long gone.
If anyone here has, or can help me find, the file, I'd really appreciate it.
Thanks!
John
Offline roxbox
    • RoxBox Karaoke
« Reply #308 on: April 22, 2021, 05:32:43 pm »
This would be nice, I have TME!
added: I looked at the E4406A bin and the E4440A and found the flexlm structure,
the data is the same for both so I would think that the keys and seeds for the E4406A would work with the E444xA  specans.
has anyone tried this?
I can not seem to get the keys and or seeds correct to reproduce any of the lic codes I have. can anyone point me in the correct direction?
frank
« Last Edit: May 13, 2021, 07:35:59 pm by roxbox »
Offline ps
« Reply #309 on: May 07, 2021, 09:11:51 pm »
For early units, option 1D5 is added by installing a Corning / VECTRON MC867X4-002W OCXO (10MHz  +12V sinewave EFC) to the reference/third converter board.
Is this OCXO controlled by the same DACs as the regular timebase, i.e. using the System - Alignments - Timebase menu?
Or does it require the N7811A software package to set the control voltage? If so, does anybody know the required GPIB commands? Otherwise it could be easier to use some precision resistors and a pot to provide the tune voltage in hardware.
Generally, have any of the N7811A alignment procedures been reverse engineered, so that they could be done with a simple GPIB interface and some own code?
Offline msraya
  • EA7EE
« Reply #310 on: May 08, 2021, 10:40:49 am »
I managed to unlock my ESA-L E4411, but the question I have is if it is possible to convert an ESA-L SA to ESA-E through service manual?
I will screw up the set?
Unhappily I don't have boards to use extended functions either  :-// ...
Regards
Manuel
Offline smgvbest
« Reply #311 on: May 09, 2021, 07:54:39 pm »
Regards
Manuel
you  can change the model in the service manual but your SA has to have all the hardware needed to do it successfully.
you can not convert up either you can only convert down from what I see.
I also do not know of any ramification of doing so.
Sandra
Offline msraya
  • EA7EE
« Reply #312 on: May 12, 2021, 06:13:36 am »
Thank You Sandra!
I don't have hardware options, so I cannot upgrade the instruments and I think It would be complicated.
The ESA-E E4411B was bottom line feature-wise SA from HP. No hardware options. So little more can I do.
I was looking for the option table and I manage to find it.
But the only option I can really use was the pre-amplifier. All other options were crippled or not applicable.
I suppose it is lacking some hardware as there are no way to select low BW filter although I enabled 1D5 option.
So, now only pre-amplifier and 200Hz EMI filter is working.  :-//
Regards
Manuel
Offline KD4PBS
« Reply #313 on: October 05, 2021, 07:23:17 pm »
I, too, am looking for the magic program which is required to add options to the E4400 series, and no matter my google duck duck fu, I also only find dead links to sites which no longer exist.  And this isn't my first rodeo.
Anyone have any ideas?
Regards-
Edit: Ask and you shall receive!  Thanks, y'all!
« Last Edit: October 28, 2021, 06:52:02 pm by KD4PBS »
Offline harha
« Reply #314 on: December 25, 2021, 02:22:42 am »
Hi
I have followed this thread with great interest,as i am the lucky owner of an very clean Agilent E4402B.
Have a option 219 Noise Figure card on its way and have downloaded the option 219 personality from keysight---but its an exe file greater than a 3.5 floppy.Found that its a special selfextractor working with windows xp--have tried with no luck!
Could somone possibly help with this peronality????
Regards
Hardy
Offline PA0PBZ
« Reply #315 on: December 25, 2021, 09:24:51 am »
Offline harha
« Reply #316 on: December 25, 2021, 05:12:45 pm »
Hi
The only option 219 personality file from keysight are an exe bigger than one floppy--its an selfextraxtor from North Beach Labs DiskDuplicator,supposed to run with win xp---but it doesnt work for me in an old xp pc
Regards
Hardy.
Offline harha
« Reply #317 on: December 25, 2021, 05:24:13 pm »
Here are the install instructions for the option 219
Hardy
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #318 on: December 25, 2021, 06:30:46 pm »
Hi
Regards
Hardy.
I downloaded the file but it won't extract as you say, in any compatibility mode, or running as administrator.
Offline tv84
  • Country: pt
« Reply #319 on: December 25, 2021, 06:42:50 pm »
2021 Xmas gift.
The following users thanked this post: harha, volvo_nut_v70
Offline PA0PBZ
« Reply #320 on: December 25, 2021, 10:38:32 pm »
Hi
Regards
Hardy.
It looks like the instructions are wrong, it wants to extract a disk image. I'm going to try to get it working on a W7 VM and an USB floppy tomorrow, stay tuned.
Offline PA0PBZ
« Reply #321 on: December 26, 2021, 12:48:17 pm »
Here are the 2 disks, just copy the content to the root of the drive (and report back  ;) )
(For reference: This is to install option 219 on the ESA series)
The following users thanked this post: jwrodgers, harha
Offline harha
« Reply #322 on: December 26, 2021, 07:29:37 pm »
Thanks!!!
I can confirm its working.
Happy New Year
Hardy
Offline mankan
« Reply #323 on: February 15, 2022, 10:09:30 pm »
@suj Any progress to report in reverse engineering board addressing for building an option 219 board?
Maybe @harha can provide help with measurements on his.
Offline suj
« Reply #324 on: February 15, 2022, 10:21:50 pm »
I lost my motivation ;). I bought an N8973A, and at higher frequencies I use frequency conversion before the N8973A. Maybe I will come back to it someday, especially since I have the hardware in place.
I was also thinking about using the E4407B as a frequency converter for the N8973A and feed the signal from the 321.4 MHz IF to the NFA. Since the external heterodyne control commands on the N8973A are configurable, it might be possible to configure both so that the NFA controls the SA.
