I can derive a rough memory map from QUICC's BRx/ORx regs initialization:
0: 00000000 [20000] SRAM-like, slow timing - this is BootROM as we already know
1: 04000000 [400000] DRAM-like, fast timing - this is DRAM bank 0
2: 04400000 [400000] DRAM-like, fast timing - this is DRAM bank 1
3: 02000000 [20000] SRAM-like, external timing - FPGA ? DIP switches regs are here, flash size reg, DRAM size reg
4: 08000000 [100000] SRAM-like, external timing - ??
5: 0A000000 [80000] SRAM-like, external timing - this is SRAM
6: 0C000000 [400000] SRAM-like, external timing - this is firmware flash
7: 0E000000 [20000] SRAM-like, external timing - ??
Try dumping a small piece from each of the two unknown regions (08000000, 0E000000), maybe the content will provide some ideas.
