SIMM Repaired
the simm that caused the processor board to blow has been repaired. it apparently was upgraded from 4M to 12M of flash and the soldering was , um poor
I removed all flash and caps. tested all of the them. flash was read, erased, programmed, read, erased and read for each of the 3 flash memories.
checked caps and replaced all.
also started work on the processor board. FWIW,
On J3 you can supply 5v @ 1.3A to 3rd (of the longer) pin from right side and on P7 for GND and youv'e got power.
it does need more voltages but Boots with just 5V
