there is also a series of F000000 to F000003 files that I wonder what they contain...i think they must be combined too.
also there is a bootloader file on the first floppy
have you been able to analyze the single firmware file with tools that are available in linux?
When I tried the linux tools they did not recognize the contents
PDISC is the physical Disc Number below whereas the DISC # is the as LABELED Disc for installation
BOOTROM: This looks for a DISK with ESALOADER on it and if so loads and runs it
DISC ESALOADER(PDISC1), This is what's run to install the FIRMWARE.
DISC1-5(PDISC2-6), this is the ESA Firmware Discs (this is the the ESAFW I uploaded)
DISC1-3(PDISC7-9), These contain the ESA Power Suite Software) (the F000000 to F000003 are the Powersuite Image files)
I'll combine and upload the Powersute after work today
