I extracted strings from the E4407B and found some interesting ones
in particular is SCPI Debuger
Line 7267: 3679704:@(#)LDS Rev:3.10 - Module Incremental (Aug 4 2008) ; hpib (68xxx asm) Rev 1.20
Line 7360: 3769948:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Semeval Rev 3.10
Line 7438: 3859435:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); scpi_lp Rev 3.10
Line 7451: 3862796:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); shr Rev 3.10
Line 7509: 3894168:@(#)LDS Rev:3.10 - Module Incremental (Mar 26 2007); active function Rev 3.10
Line 7515: 3919656:@(#)LDS Rev:3.10 - Module Incremental (Mar 26 2007); fpanel control Rev 3.10
Line 7581: 3942204:@(#)LDS Rev:3.10 - Module Incremental (Mar 26 2007); menu system Rev 3.10
Line 7590: 3950528:@(#)LDS Rev:3.10 - Module Incremental (Jul 8 2003); ptp Rev 3.10
Line 7607: 3990652:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); scum Rev 3.10
Line 7613: 3997792:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Math64 Rev 3.10
Line 7614: 4008452:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); cvt (asm source) Rev 3.10
Line 7615: 4009139:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); mcat Rev 3.10
Line 7630: 4012400:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); rlock Rev 3.10
Line 7644: 4017028:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Save-Recall Rev 3.10
Line 7646: 4021306:@(#)LDS Rev:3.10 - Module Incremental (Sep 10 1999); OS wrapper for psos Rev 3.10
Line 7723: 4051040:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); HIHR Rev 3.10
Line 7737: 4059944:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Null Happening Reporter Rev 3.10
Line 7738: 4060052:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Tee Happening Reporter Rev 3.10
Line 7740: 4060976:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Stderr Happening Reporter Rev 3.10
Line 7741: 4061100:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Stdio Happening Reporter Rev 3.10
Line 7746: 4061988:@(#)LDS Rev:3.10 - Module Incremental (Oct 11 1999); Scpi Debugger Rev 3.10
Line 7765: 4072404:@(#)LDS Rev:3.10 - Module Incremental (Sep 10 1999); optimized memory manager Rev 3.10
I also extracted all the FlexLM items i could see
one of interest is
/usr/local/flexlm/licenses/license.dat
4072496:@(#) FLEXlm 6.0d (liblmgr.a), Copyright (C) 1988-1997 Globetrotter Software, Inc.
4072583:FLEXLM_COMM_TRANSPORT
4074343:FLEXLM_INTERVAL_OK
4074373:FLEXLM_USE_FINDER
4076772:FLEXLM_DIAGNOSTICS
4076795:LM_LICENSE_FILE
4076811:%s_LICENSE_FILE
4076830:%s%s%s%s%s
4078034:FLEXLM_DIAGNOSTICS
4078057:FLEXlm checkout error
4078079:license file(s):
4078103:lm_checkout("%s", %s, %d, 0x%x, ..., 0x%x)
4079117:x%s > %s
4079130:%d-%[^-]-%d
4080510:NOMORE
4080771:%d %d
4082547:,PORT_AT_HOST_PLUS
4083270:DUP_GROUP
4083280:SUITE_DUP_GROUP
4083296:W_LIC_LOSS
4083307:OVERDRAFT
4083322:USER_BASED
4083333:HOST_BASED
4083352:PLATFORMS
4083369:SUPERSEDE
4083410:DIST_CONSTRAINT
4086112:%s=%s
4086286:%s=%d
4086618:%ld-%[^-]-%ld
4093632:PORT_AT_HOST_PLUS
4094790:%s %s %s
4094811:INCREMENT
4094838:%s %s %s %s %s %s %s %s %[^
4094869:%s %s %s %s %s %s %s %[^
4094897:permanent
4094915:uncounted
4096630:PORT_AT_HOST_PLUS
4096796:%s %s
4096936:USE_SERVER
4097583:All licenses are reserved for others
4097621:Cannot remove a linger license
4097652:The decimal format license is typed incorrectly
4097700:This FEATURE line can't be converted to decimal format
4097755:The desired vendor daemon is down
4097789:Server node is down or not responding
4097827:Network connect to THIS_HOST failed
4097863:Attempt to generate license with incompatible attributes
4097920:This feature is available in a different license pool
4097974:feature removed during lmreread, or wrong SERVER line hostid
4098035:ENCRYPTION_SEEDs are non-unique
4098067:Future license file format or misspelling in license file
4098125:This platform not authorized by license
4098165:System clock has been set back
4098196:Checkout exceeds MAX specified in options file
4098243:License object already in use
4098273:License server doesn't support this request
4098317:USER_BASED license has no specified users -- see server log
4098377:FLEXlm version of client newer than server
4098420:Invalid PACKAGE line in license file
4098457:FLEXlm internal error -81
4098483:FLEXlm internal error -80
4098509:FLEXlm internal error -79
4098535:FLEXadmin API functions not available
4098573:Bad version number - must be floating point number, with no letters
4098641:Internal FLEXlm Error - Please report to Globetrotter Software
4098704:SYS$SETIMR call failed
4098727:Attempt to read beyond end of license file path
4098775:Local checkout filter rejected request
4098814:Old VENDORCODE (3-word) struct type passed to lm_init()
4098870:Invalid TZ environment variable
4098902:Attempt to borrow the same (destination) license twice
4098957:License borrowing database corrupted
4098994:License borrowing not enabled
4099024:No licenses available to borrow
4099056:FLEXlm include file/library version mismatch
4099101:Unknown VENDORCODE struct type passed to lm_init()
4099152:lmremove request before the minimum lmremove interval
4099206:You are not a license administrator
4099242:Network software (tcp/ip) not available
4099282:Cannot read license file data from server
4099324:Server message checksum failure
4099356:Message checksum failure
4099381:setsockopt() call failed
4099406:socket() call failed
4099427:Cannot compute FEATURESET data from license file
4099476:Incorrect FEATURESET line in license file
4099518:No FEATURESET line in license file
4099553:Checkout request rejected by vendor-defined checkout filter
4099613:FLEXlm vendor daemon did not respond within timeout interval
4099674:FLEXlm not initialized
4099697:FLEXlm key data has expired
4099725:Date invalid for binary format
4099756:FLEXlm platform not enabled
4099784:Clock setting check not available in daemon
4099828:FLEXlm software is demonstration version
4099869:FLEXlm function not available in this version
4099915:Invalid FLEXlm key data supplied
4099948:No FLEXlm key data supplied in lm_init() call
4099994:Invalid parameter
4100012:Feature was never checked out
4100042:Cannot allocate dynamic memory
4100073:User/host not on INCLUDE list for feature
4100115:User/host on EXCLUDE list for feature
4100153:Duplicate selection mismatch for this feature
4100199:Feature database corrupted in daemon
4100236:In the queue for this feature
4100266:Clock difference too large between client and server
4100319:Bad encryption handshake with daemon
4100356:No such attribute
4100374:Feature start date is in the future
4100410:Cannot read license file
4100435:Cannot find ethernet device
4100463:Cannot read /vmunix
4100483:Cannot read /dev/kmem
4100505:Request for more licenses than this feature supports
4100558:License server does not support this version of this feature
4100619:Users are queued for this feature
4100653:License server temporarily busy (new server connecting)
4100709:Feature checkin failure detected at license server
4100760:License file does not support this version
4100803:License server busy (no majority)
4100837:Error in select system call
4100865:License server does not support this feature
4100910:Cannot write data to license server
4100946:Cannot read data from license server
4100983:Cannot connect to license server
4101016:Cannot find SERVER hostname in network database
4101064:No SERVER lines in license file
4101096:Invalid returned data from license server
4101138:Invalid date format in license file
4101174:Feature has expired
4101194:Invalid host
4101207:Invalid (inconsistent) license key
4101242:No socket connection to license manager server
4101289:No port number in license file and "FLEXlm" service does not exist
4101356:No such feature exists
4101379:Licensed number of users already reached
4101420:No server for this feature
4101447:Invalid license file syntax
4101475:Cannot find license file
4101910:The system administrator has reserved all the licenses for others.
4101978:Reservations are made in the options file. The server must be restarted
4102051:for options file changes to take effect.
4102093:1) Check the lmgrd log file, or 2) Try lmreread.
4102143:See the system adminstrator about starting the server, or
4102202:make sure the you're referring to the right host (see LM_LICENSE_FILE).
4102275:The license file indicates THIS_HOST, and the server is not
4102336:running on this host. If it's running on a different host,
4102398:THIS_HOST should be changed to the correct host.
4102448:This is a warning condition. The server has pooled one or more
4102513:INCREMENT lines into a single pool, and the request was made on
4102578:an INCREMENT line that has been pooled. If this is reported as an
4102646:error, it's an internal error in FLEXlm
4102687:The file was issued for a later version of FLEXlm than this
4102748:program understands.
4102770:The server (lmgrd) has not been started yet, or
4102819:the wrong port@host or license file is being used, or the
4102878:port or hostname in the license file has been changed.
4102934:The lookup for the hostname on the SERVER line in the
4102989:license file failed. This often happens when NIS or DNS
4103047:or the hosts file is incorrect. Workaround:Use IP-Address
4103108:(e.g., 123.456.789.123) instead of hostname
4103153:The hostid of this system does not match the hostid
4103206:specified in the license file
4103237:The license-key and data for the feature do no match.
4103292:This usually happens when a license file has been altered
4103351:The license files (or server network addresses) attempted are
4103415:listed below. Use LM_LICENSE_FILE to use a different license file,
4103484:or contact your software provider for a license file.
4103539:Usually this error message should be ignored.
4103586:It occurs when the FLEXlm error message function was called
4103647:though no error was detected
4104086:Vendor:Host
4104098:Platforms
4104108:PACKAGE text
4104121:Version text
4104134:Start date
4104145:Application version > License version
4104183:Server name
4104195:Date text
4104205:Expire date
4104224:Hostname
4104233:License text
4104246:Filename
4104257:INVALID FLEXlm error code
4104283:Feature:
4104314:%-15s %s
4104323:License path:
4104363:For further information, refer to the FLEXlm End User Manual,
4104425:available at "[url=http://www.globetrotter.com]www.globetrotter.com[/url]".
4104462:FLEXlm error:
4104477:%-15s%d,%d. System Error:%d "%s"%s
4104514:%d,%d:%d (%s)
4104530:%-15s%d,%d
4104541:(%d,%d)
4105410:%s:%s
4105530:no error
4105977:%d-%[^-]-%d
4106804:0123456789ABCDEF
4107098:1-jan-1990
4107113:1-jan-2025
4107127:%d-%s-%d
4108724:hp700_u9
4108978:LM_DEBUG_HOSTID
4109996:/etc/resolv.conf
4110826:DEMO
4110851:INTERNET=
4110876:HOSTNAME=
4110886:DISPLAY=
4110900:ID_STRING=
4110923:SENTINEL_KEY=
4110937:FLEXID=7-
4110952:FLEXID=8-
4110962:FLEXID=9-
4110972:FLEXID=A-
4110987:DISK_SERIAL_NUM=
4111013:VENDORDEF=
4112732:DUP_GROUP not valid with uncounted license
4112775:Hostid required for uncounted feature
4112813:HOST or USER BASED licenses must be counted
4112857:Illegal char in feature name:only alpha-num and '_' allowed
4112918:SUITE only applies to PACKAGE lines
4112954:Can't combine USER_BASED and HOST_BASED
4112994:PACKAGE and COMPONENT name can't be identical
4113040:%d-%[^-]-%d
4113052:ISSUED Invalid date format
4113079:ISSUED Can't have year 0
4113656:03.0
4114484:USE_SERVER
4115223:%s_LICENSE_FILE
4115239:LM_LICENSE_FILE
4115263:FLEXLM_USE_FINDER
4115281:/usr/local/flexlm/licenses/license.dat
4116485:START_LICENSE
4116504:END_LICENSE
4116896:%d%s
4117267:%c%c%c%c%c%c%c%c%s
4119122:%d-%s-%d
4120010:%c%s
4121072:DEMO
4121104:DISPLAY=
4121113:ID_STRING=
4121133:HOSTNAME=
4121155:FLEXID=7-
4121174:SENTINEL_KEY=
4121188:FLEXID=8-
4121201:FLEXID=9-
4121211:FLEXID=A-
4121221:DISK_SERIAL_NUM=
4121243:INTERNET=
4123359:SUPERSEDE
4123377:HOST_BASED
4123388:PLATFORMS
4123398:USER_BASED
4123409:CAPACITY
4123437:SUITE_DUP_GROUP
4123456:COMPONENTS
4123467:dist_info
4123494:asset_info
4123505:user_info
4123515:vendor_info
4123527:OVERDRAFT
4123537:DUP_GROUP
4123554:VENDOR_STRING
4123568:W_LIC_LOSS
4123579:w_term_signal
4123608:w_binary
4124356:SITE
4126380:/dev/tty
4126688:START_LICENSE
4128178:%s %s %s %s %s
4128204:this_host
Also of interest is
0:----- System/pSOS Debug commands:-----
1176785:'?' - this help message.
1176815:'j' - drop into breakpoint.
1176848:'^C' - Abort to monitor.
1176877:'^P' - Process status info, and LOTS of it.
1176925:'[dD]' - Print DLP debug information.
1176965:'[bB]' - Big memory hog report.
1176999:'[pP]' - Process ONLY status info.
1177038:'[eE]' - Exchange info.
1177064:'[gG]' - toggle breakpoint exception handlers on/off
1177119:'[tT]' - Time log.
1177140:'[hH]' - History log.
1177164:'[oO]' - Memory segment ownership.
1177201:'[mM]' - Memory segment summary.
1177236:'[sS]' - Semaphore ownership, etc.
1177273:'[uU]' - maximum process stack Usage.
1177313:'[vV]' - memory Validity check.
1177347:'[iI]' - Show psosSystemData.
1177379:'[1]' - Show NVRAM contents.
1177411:'[9]' - Show Exception Report.
1177445:'[wW] <process name>' - Show process stack trace.
1177497:Unknown debug char:'%c' (0x%02X). Press '?' for help.
