Author Topic: Python script to measure DC-DC converters  (Read 165 times)
Offline tszabooTopic starter
« on: July 20, 2024, 11:35:47 am »
I've made a python script to measure DC-DC converters.
It measures the efficiency across input voltage and load current
And shows the load dependency of the output voltage.
I've included an example output of a very simple 7812 based power supply.
Code is below. Uses python, finds the VISA connected instruments.
Uses a Rigol DP832 Power supply and a Siglent SDL1020 in my case.
Warning: The code will totally blow up your DUT if you don't configure it correctly.
I suggest manually setting up the Overvoltage and Overcurrent conditions on both your instruments before starting.
Re: Python script to measure DC-DC converters
« Reply #1 on: July 20, 2024, 11:38:56 am »
It was running using jupyter notebook, but there is no reason why it wouldn't work from regular python console.
import pyvisa
import numpy as np
import itertools
import time
import csv
import pandas as pd
import matplotlib.pyplot as plt
import datetime
rm = pyvisa.ResourceManager()
[print(x) for x in rm.list_resources()];
#use instrument names OR serial numbers
#Power supply settings
PSU_NAME = "DP832"
VIN_NUMBER_OF_SAMPLES = 20
VIN_MIN = 15
VIN_MAX = 22
IIN_MAX = 1
#DC load settings
DC_LOAD_NAME = "SDL1020"
IOUT_NUMBER_OF_SAMPLES = 20
IOUT_MIN = 0.01
IOUT_MAX = 0.3
DELAY = 0.5
CSV_FILE = 'measurements.csv'
EFFICIENCY_IMAGE = 'Efficiency.png'
VOLTAGE_IMAGE = 'Output.png'
#Creating measurement parameters
VIN = np.linspace (VIN_MIN,VIN_MAX,VIN_NUMBER_OF_SAMPLES)
IOUT = np.linspace (IOUT_MIN,IOUT_MAX,IOUT_NUMBER_OF_SAMPLES)
N= len(list(itertools.product(VIN,IOUT)))
print (f"Taking {N} measurements")
print (f"Expected time: {N*(DELAY+2)} seconds")
#Connecting to instruments
# Example usage:
#instrument_identifier = "DP832"  # Or any other identifier
def find_instrument(instrument_identifier,rm):
  instruments = rm.list_resources()
  for instrument_name in instruments:
    try:
      instrument = rm.open_resource(instrument_name)
      idn = instrument.query("*IDN?")
      if instrument_identifier in idn:
        print("Instrument found:")
        print(idn)
        return instrument
      else:
        instrument.close()
    except:
      pass
  return None
PSU = find_instrument(PSU_NAME,rm)
DCL = find_instrument(DC_LOAD_NAME,rm)
def measure_point(vin, iin, iout):
    PSU.write(f"APPL CH1,{vin},{iin}")
    #if PSU.query(":OUTPut:STATe? CH1").find("ON") == -1:
    #    PSU.write(":OUTPut:STATe CH1,ON")
    DCL.write(f":SOURce:CURRent:LEVel:IMMediate {iout}")
    #if DCL.query(":SOURce:INPut?").find("ON") == -1:
    #   DCL.write(":SOURce:INPut ON")
    time.sleep(DELAY)
    a= PSU.query(":MEASure:CURRent:DC? CH1", 0.1)
    b= PSU.query(":MEASure:VOLTage:DC? CH1", 0.1)
    c= DCL.query(":MEASure:CURRent:DC?", 0.1)
    d= DCL.query(":MEASure:VOLTage:DC?", 0.1)
    a = float(a.strip())
    b = float(b.strip())
    c = float(c.strip())
    d = float(d.strip())
    #print ((a,b,c,d))
    print(".", end="")
    try:
        eff = (c*d)/(a*b)*100
    except ZeroDivisionError:
        eff = 0
    return vin,iout,eff,a,b,c,d
vin,iout = next(itertools.product(VIN, IOUT))
measure_point(vin,IIN_MAX,iout)
with open(CSV_FILE,'w', newline='') as csvfile:
    print (datetime.datetime.now())
    headerList = ['VIN','IOUT','EFF', 'CIN', 'VIN_A', 'IOUT_A','VOUT']
    writer = csv.writer(csvfile, delimiter=',')
    writer.writerow(headerList)
    for vin,iout in itertools.product(VIN,IOUT):
        #print (vin,iout)
        m = measure_point(vin,IIN_MAX,iout)
        writer.writerow(m)
#Turn off output
PSU.write("OUTP CH1,OFF")
DCL.write(":SOURce:INPut OFF")
#Beep
PSU.write(":SYSTem:BEEPer:IMMediate")
time.sleep(0.5)
time.sleep(0.5)
print ("Measurements done")
df = pd.read_csv(CSV_FILE)
df
plt.tricontourf(df['VIN'], df['IOUT'], df['EFF'], cmap='seismic',levels=30)
plt.xlabel('Input voltage')
plt.ylabel('Output current')
plt.colorbar(label='Efficiency')
plt.savefig(EFFICIENCY_IMAGE)  # Save the plot
plt.show()
plt.tricontourf(df['VIN'], df['IOUT'], df['VOUT'], cmap='viridis',levels=30)
plt.colorbar(label='Output voltage')
plt.savefig(VOLTAGE_IMAGE)  # Save the plot
plt.show()
