Author Topic: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B  (Read 109740 times)
Offline abyrvalg
Re: Enabling options on Agilent ESA series E4402B E4404B E4405B E4407B
« Reply #175 on: September 18, 2020, 11:45:22 am »
I've studied the PSOS debug handler: nothing like "^C" handling there, but there is one undocumented cmd with unclear functionality: lowercase "r".
Offline abyrvalg
« Reply #176 on: September 18, 2020, 11:48:07 am »
Ok, so we need patching. Could someone try figuring out the DIP switch responsible for Flash/DRAM boot as described here: https://www.eevblog.com/forum/testgear/enabling-options-on-agilent-esa-series-e4402b-e4404b-e4405b-e4407b/msg3238002/#msg3238002 ?
Offline suj
« Reply #177 on: September 18, 2020, 11:48:56 am »
I conducted an experiment. In the monitor:
->slong 04600020 04028318
->dlong 04600020
04600020  04028318 00000000 00000000 00000000   ................
Then reset and:
->dlong 04600020
04600020  00000000 00000000 00000000 00000000   ................
Clearly the contents of the DRAM cannot survive the hardware reset.
Offline suj
« Reply #178 on: September 18, 2020, 11:50:01 am »
I need some time. MB need to be removed to change dip-switch settings
Offline abyrvalg
« Reply #179 on: September 18, 2020, 12:03:38 pm »
Could you try the "r" cmd (in normal mode) also?
Offline suj
« Reply #180 on: September 18, 2020, 12:06:10 pm »
Of course. I have SA opened and its possible to change dip-switch without removing MB.
Offline suj
« Reply #181 on: September 18, 2020, 12:23:58 pm »
"r" like RESET. But:
->dlong 04600020
Online tv84
  • Country: pt
« Reply #182 on: September 18, 2020, 12:38:30 pm »
->dlong 04600020
Then reset and:
->dlong 04600020
I missed something...  |O
@abyrvalg, when is that location filled with the 04028318 ?
Offline suj
« Reply #183 on: September 18, 2020, 12:47:22 pm »
I can't get consistent readings from address 0x0200200c when changing dip-switches. It looks different after the reset. Sometimes, with the same settings, the readings are different depending on the time in which the reading is made.
Offline abyrvalg
« Reply #184 on: September 18, 2020, 01:09:53 pm »
DRAM not surviving: found the reason - BootROM clears entire DRAM at each start, so reset is not our friend :(
Inconsistent switch reg reading: there can be some other bits not related to switches, ignore them. We are interested in bit 8 (hex mask 0100), normally it should be 0 (for "Download to Flash Selected") and we need to switch it to 1 (for "Download to DRAM Selected").
Offline abyrvalg
« Reply #185 on: September 18, 2020, 01:16:07 pm »
@tv84, a function at 04011078 in ESAFW initializes data section (04600000-0476DD88) by copying from 04435E14 and clears bss section (0476DD88-048BCCE8)
Offline suj
« Reply #186 on: September 18, 2020, 01:29:45 pm »
DIP switch #4, ON position (default)
->dword 0x0200200c
0200200c  0400   ..
DIP switch #4, OFF position
->dword 0x0200200c
0200200c  0500   ..
Offline suj
« Reply #187 on: September 18, 2020, 01:43:20 pm »
After booting with DIP switch #4 in OFF position:
***** Mosquito Bootrom *****
Copyright 1988-1997,
Hewlett-Packard Company, all rights reserved.
@(#)HEWLETT-PACKARD, E4401 Bootrom, 5.00
@(#)LDS Rev: 3.02 - Module Incremental (Sep  9 2003)
@(#)Linked: Sep  9 2003 14:46:44
Bootrom Checksum ...
Bootrom DRAM:     Testing 69632 bytes at 0x04000000
Non Destructive SRAM Test ...
Main Firmware DRAM:     Testing 33484800 bytes at 0x04011000
Main FW Checksum ...
Self-tests complete.SRAM selftest results:
        Start  = 0xa000000
        End    = 0xa007fa3
        Errors = 0x0
DRAM selftest results:
        Start  = 0x4011000
        End    = 0x6000000
        Errors = 0x0
hpibPort = 0x8005000
hpibPort = 0x8005000, bus Address = 19
Cache Enabled
16MBytes of FLASH
ROM Monitor
Enter ? for help.
Offline abyrvalg
« Reply #188 on: September 18, 2020, 01:49:30 pm »
Great! That's it!
So, what we can do now:
- set DIP4 to ON (to enable ESAFW loading from flash)
- start the ESA with boot interruption
--- now we have stock ESAFW loaded from flash into DRAM, but we are in ROM Monitor
- patch ESAFW in RAM (with smem/sbyte/sword/slong)
- set DIP4 to OFF (to disable ESAFW reload in "gu" command)
- send gu command to start the patched image from DRAM
@tv84, any ideas what to patch?
I'm going to prepare some patch to jump from ESAFW back to ROM Monitor (i.e. with some of the psos debug commands) without reset to dump the data section content finally.
The following users thanked this post: smgvbest
Offline abyrvalg
« Reply #189 on: September 18, 2020, 01:59:54 pm »
sword 04139614 4ef9
sword 04139618 d8a4
gu
- ESAFW should start normally after this. Then, when it is running already, press "r" and you should get back to ROM Monitor with DRAM keeping the content (try dlong 04600020 there to see).
Offline suj
« Reply #190 on: September 18, 2020, 02:37:32 pm »
->dlong 04600020
04600020  04028318 04028324 0402832a 04028331   .......$...*...1
Offline suj
« Reply #191 on: September 18, 2020, 02:45:58 pm »
My steps:
0. Set the serial terminal to 19200,8n1
1. DIP sw #4 set to ON
2. break the boot process with 0x06
3. sword 04139614 4ef9
4. sword 04139618 d8a4
5. DIP sw #4 set to OFF
6. gu
7. SA restart in normal mode
8. Press "r" and we are in the monitor now  8)
9. Change the serial port speed.
>slong 815F4 1001A
10. Change speed of the serial terminal to 115200, 8n1
Respect for you  :-+ :-+ :-+
« Last Edit: September 18, 2020, 04:34:35 pm by suj »
The following users thanked this post: smgvbest, analogRF
Offline smgvbest
    • Kilbourne Astronomics
« Reply #192 on: September 18, 2020, 02:54:58 pm »
My steps:
6. gu
Cool,  I wake up and you all have done allot.
@suj how are you flipping the DIP SW without removing the Processor Card?
a long stick???  LOL
Sandra
(Yes, I am a Woman :p )
Offline suj
« Reply #193 on: September 18, 2020, 02:59:17 pm »
a long stick???  LOL
Offline smgvbest
« Reply #194 on: September 18, 2020, 03:01:51 pm »
a long stick???  LOL
Ah,  right angle tweezers and coming in from that angle,   thanks.  :-+
Sandra
Offline abyrvalg
« Reply #195 on: September 18, 2020, 03:05:10 pm »
Great!
@tv84, your turn! :)
Btw, does anyone know what UART IC is used in ESA? Perhaps it is possible to raise the baudrate by writing to some regs manually from the Monitor.
Offline suj
« Reply #196 on: September 18, 2020, 03:09:42 pm »
It's part of the 68EN360 QICC. Its working in "companion" mode with 68LC040
Offline smgvbest
« Reply #197 on: September 18, 2020, 03:24:26 pm »
Great!
Given where we are I don't know if this is worth pursuing or not but there appears to be some kind of undocumented SCPI debug interface and FLASH from SCPI is a supported option as well
found it by mistake ,
hmon    [device] - download into memory
defaults to loading from SCPI
I've not been able to find what [device] is supported
SCPI does not work but hmon on own loads from it
tried FLOPPY, FLASH, 0-1, A-Z, A:-C: and a few more
even things like /dev/fd0
if we want to avoid that, that's fine I defer to the Guru's here.
Sandra
Offline smgvbest
« Reply #198 on: September 18, 2020, 03:46:38 pm »
I think I can patch the license validation ATM. Although, having some idea of how flexlm tests licenses, I don't know what are the consequences of activating all licenses.
I would prefer 1st to have the dump, so that I can search for the seeds. If I can find the seeds in the dump, the keygen will be instantaneous.
Do you want the same dump we've had before or a different one?
Sandra
Offline suj
« Reply #199 on: September 18, 2020, 03:52:42 pm »
I would not like to look too far into the future, but maybe it would also be worth reflecting on one of the problems. Probably most owners of the E4401 series hope to unlock the 219 option. Due to the measurement method (Y-factor), cooperation with the equipment is required. And here comes the problem under the name E4401-60123. It is not described in CLIP and there is no schematic diagram. I only found one low resolution photo on the internet. The card works with two types of noise sources: traditional sources of the 346 series and newer SNS series (N4000A, N4001A, N4002A). Cooperation with newer ones is more demanding. The noise source has a memory (probably EEPROM) with a stored ENR table and measures its temperature. Working out this can be very difficult. The type 346 sources, on the other hand, only require +28 V voltage switch. A DC/DC converter is placed on the card. One bit is required for ON/OFF keying only. The card itself should work without option 219, there is an option "Press Service, More, Noise Source (On)" in the service menu. And that could be a hook for finding the address of that bit that needs to be switched. Another thing is the card identification. FW should think the card is inserted. This is a way to create hardware that emulates part of the E4401-60123 card to work with 346 series sources. Connectors such as on the E4401 series expansion cards are available from Mouser. The E4401-60123 card itself is available in Keysight as far as I remember. Over $2800...
