Author Topic: Enabling options for R&S test equipment  (Read 143801 times)
Offline sezhReppo
  • Country: ug
Re: Enabling options for R&S test equipment
« Reply #325 on: March 15, 2024, 07:35:39 am »
Hi!
I turned off the batteries on my FSH3 for almost a day, the options remained unchanged.
I need help. We need FSH View software for FSH3. Can anyone help?
Offline eb4fbz
« Reply #326 on: March 25, 2024, 06:51:02 pm »
https://we.tl/t-2bL96LII03
The following users thanked this post: sezhReppo
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #327 on: March 25, 2024, 09:11:55 pm »
Here's the installer I got from one of my coworkers
https://tinyurl.com/db5w4enz
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline goaty
« Reply #328 on: March 26, 2024, 06:32:27 am »
Lates FSHView I´ve got here is 14.20.
Offline MeasureMan
  • Country: ru
« Reply #329 on: March 26, 2024, 05:06:07 pm »
Hello!
I have base model of R&S RTH1004. Can anybody help me to activate more wide bandwith?
Thanks!
Offline imaurente
  • Country: br
« Reply #330 on: April 17, 2024, 10:13:56 am »
Hello, I have the same problem, I need to enable the IQ, DAB and ISDB-T features on my SFE100, has anyone discovered anything???
Offline Ennio
« Reply #331 on: April 24, 2024, 08:20:24 pm »
Hi, I have an R&S ETC and I would like to know how to find out the key to unlock the K240 option for DVBT-2 with the hardware already installed, how can I do it since it can no longer be purchased? Thank you.
« Last Edit: April 28, 2024, 12:01:46 pm by Ennio »
Offline Ennio
« Reply #332 on: April 28, 2024, 01:09:10 pm »
Hello everyone, can anyone help me solve the problem?
Offline Ennio
« Reply #333 on: May 01, 2024, 01:53:35 pm »
An original key for the ETC in my possession is: 066379365018881348971792051684 relating to the K140 option. In the results of main.c this type of key does not appear but only 10 numbers. How to solve the problem for the K240 always with 30 numbers?
« Last Edit: May 01, 2024, 01:56:05 pm by Ennio »
Offline hihiwifi
« Reply #334 on: May 03, 2024, 07:15:01 am »
I have a PR200 with the Panorama Scan and Time Domain options installed, I can provide firmware, software, documentation(Full manual, pretty sure its 600 pages or something), etc. to anyone who would like to give cracking the option encryption a shot. I would imagine this encryption is still being used on the latest devices, so it may be worthwhile to look into.
The firmware is just an .itb file that can be extracted in HexWalk leaving you with a .squashfs archive which I assume is what has the good stuff in it, a 10MB "C0" file, and an 83.8MB C0.gz file.
Poked around in the .squashfs file for a bit, to say it's intimidating is an understatement. Ended up finding the lines of code where it calls openssl/crypto when you go to type in the option key, but I have no idea where to go from there.
As the PR200 is Rohde's latest portable receiver, I cannot provide option keys for security reasons.
Offline mr ed
« Reply #335 on: May 14, 2024, 01:45:51 am »
...SMIQ   what would be the simple hash???
Offline luc-on7kz
« Reply #336 on: May 27, 2024, 07:59:18 am »
Hello
I try to access these link
https://bitschubbser.org/nextcloud/index.php/s/6TCghFbYMsbkfph (PW: eevblog)
but it give me a error "Page not found"
who can help me and give me a link where I can download the AMPS firmware (and more)
thanks
Luc
Offline ve7xen
    • VE7XEN Blog
« Reply #337 on: May 27, 2024, 05:22:28 pm »
https://gotroot.ca/cmu200
The AMPS firmware is part of the IS136 package IIRC.
73 de VE7XEN
He/Him
Offline leakyDiode
  • Country: aq
« Reply #338 on: May 29, 2024, 08:28:30 pm »
I want to share with you my key generator for SMx (SME, SMT, SMP) and SMIQ signal generators. It can generate keys for software options and factory installation keys (aka signal generator personality). The output is a  6 digit number. Please don't laugh at the used encryption method  :-DD
How to use it:
Edit the c-file and add your serial number, SMIQ flag. See comment "UPDATE below variables"
Compile with: gcc -o SMx SMx.c
Run with: ./SMx
Profit
This key generator has been tested with SME and SMIQ generators.
Once a key has been entered I haven't found a way on how to remove it, but based on the firmware it's possible to remove installed keys and options. If somebody knows how, please share the procedure.
It might be possible that this generator could generate as well keys for other instruments from the same era, but this has not been further explored yet.
« Last Edit: May 30, 2024, 07:47:13 am by leakyDiode »
The following users thanked this post: eliocor, ve7xen, KeBeNe, egonotto, ps, analogRF, OH2LIY, ktgun
Offline tv84
  • Country: pt
« Reply #339 on: May 29, 2024, 09:59:26 pm »
Well done. I hadn't noticed that the lookup table was a CRC16..  :palm:
From my notes:
SMIQB51 - 1105.1831.02 - GPS
The following users thanked this post: KeBeNe, egonotto, leakyDiode
Offline Gian2975
« Reply #340 on: May 30, 2024, 07:32:40 pm »
HI,
I have an FSH3.23 I would like to calibrate the reference at 10MHz.
It seems to be possible only with specific software.
I see that among the options that can be enabled there is also this:
Cal. Allowed (k15)
Would it be possible to proceed with the calibration manually with this option?
If you have already installed it, can you check?
Or do you have any idea what software you can use to perform the calibration
Thank you
Offline Gian2975
« Reply #341 on: June 02, 2024, 05:52:17 pm »
I managed to enable all available options, but unfortunately this problem happened.
The span steps are incorrect, and the up and down keys are reversed.
It already had firmware version 14.0, I tried to update again, but unfortunately it didn't solve the problem.
Some parameters seem to have been compromised.
I attach a short video to help me understand the problem.
I have already tried all the resets possible but I haven't solved the problem.
Now I would like to try removing the options but it doesn't seem feasible.
Do you have any ideas?
Thank you
Link video:
https://www.youtube.com/shorts/YofmDIOqMxk
Offline drhex
« Reply #342 on: June 11, 2024, 09:07:19 am »
And another request for option codes for SMU200A - does anybody have a keygen? Also looking for the calibration software, if anybody has a link I'd be grateful!
Offline KeBeNe
« Reply #343 on: June 20, 2024, 03:43:01 am »
How to use it:
Run with: ./SMx
Profit
Just as a hint,
The options for the SME, SME32;33;36 , as well as SME42;43;46 are not software options, but change the device type!
(e.g. an SME-02 becomes an SME-32, an SME-03 -> SME-33 etc.)
So please do not use them, you will make your device almost unusable!
in case someone was so hasty, the keys are entered in Prot-Level3, uninstalling the keys worked for me by entering them again in Prot-Level2.
The SME-B41 to B43 options require the SME-B12 option in addition to the SME-B11 option.
« Last Edit: June 20, 2024, 04:02:52 am by KeBeNe »
Offline aXerman
« Reply #344 on: June 26, 2024, 04:22:37 pm »
If you have an updated link for the FSHView software I would be forever grateful!
Offline goaty
« Reply #345 on: June 26, 2024, 07:34:26 pm »
There is no public link for FSHView, one has to ask RnS.
I can send 14.20 via eMail if necessary.
Offline carver
  • Country: nr
« Reply #346 on: June 26, 2024, 07:49:05 pm »
FSHView_V1420_setup.exe
https://mega.nz/file/zhY0gbJC#Bu-i3R71GKtG8LbKq4M-O9g96m1KuGGTUUSMFhrzffo
this is for the old FSH. for the new FSH - all versions at first google links.
« Last Edit: June 26, 2024, 07:53:38 pm by carver »
/carv
The following users thanked this post: R-S-chx
Offline pdenisowski
« Reply #347 on: June 26, 2024, 11:06:13 pm »
There are basically three software packages for FSH (all free of charge)
- FSH3/6 uses the FSHView Software
- FSH4/8/up can use either the FSH4View Software or the newer InstrumentView software
So unless you're running an FSH3/6, you can download the software directly from the R&S website
https://www.rohde-schwarz.com/software/fsh/
I have FSHView V13.12 from a colleague of mine if anyone needs it.
Offline aXerman
« Reply #348 on: June 28, 2024, 02:15:35 pm »
This is the one I'm looking for, thanks! I have an old FSH3 that I have been playing around with, and another in pieces with damaged RF input melf resistors and non-functioning display I have yet to track down replacements for.
Offline Chefbastler
« Reply #349 on: July 19, 2024, 01:59:00 pm »
Hello, I have an R&S FSL3 Spectrum Analyzer.
Has anyone found a keygen generator for the box?
