Hi tv84,
I attached a API.DLL form a ZVR. could you decode the option from it?
I don't think so. Do you have examples of options for that equipment?
I double checked with ZVR manual, the only K option for ZVR is K9 only, there is nothing to do with this unit.
So I am looking in another one, FSEA30. the datasheet say the K option for FSEA is:
FSE-K4 Phase Noise Measurement Software,
FSE-K3 Noise Measurement Software
FSE-K10 GSM Test Software, Mobile
FSE-K11 GSM Test Software, Base Station
FSE-K20 GSM Test Software, Edge Mobile
FSE-K21 GSM Test Software, EDGE Base Station
FSE-K30 GSM Test Software, 850 GHz band Mobile
FSE-K31 GSM Test Software, 850 GHz band Base Station
Just decoded the SN using "Rohde & Schwarz FSP option generator".
Notice: that I decode all seeds, the comment "Kx xxxx Application Firmware" is not correct, it's for FSP
3780795724 - K5 - GSM/EDGE Application Firmware
0284552823 - K7 - AM/FM/PM Measurement Demodulator
4196994763 - B17 - IQ Online
0684125256 - None
1514211661 - K84 - 1xEV-DO BTS Application Firmware
0579586646 - K84 - 1xEV-DO MS Application Firmware
3285910640 - None
1332515167 - FSP-B15 FSP-B70 FS-K7
1746004935 - K72 prior K74
0425836556 - None
3914572062 - K9 - Power Meter
0367944746 - FSP-B15 FS-K7
0178533596 - None
0084427020 - None
0973137605 - K76 - 3GPP TD-SCDMA BTS Application Firmware
4058089560 - K77 - 3GPP TD-SCDMA MS Application Firmware
2816669065 - K30 - Noise Figure Measurament
0774785927 - K82 - CDMA2000 BTS Application Firmware
1251526595 - K83 - CDMA2000 MS Application Firmware
0364322959 - K8 - Bluetooth Application Firmware
3912188941 - K40 - Phase Noise Measurament
2043795852 - None
2216559242 - None
3509799288 - None
0667766505 - None
2179962388 - 31 days trial period
4232888520 - 78 days trial period
1998016984 - None
1665344687 - None
0081926458 - Frequency Extension
1876889287 - None
2554963261 - Trasducer Set
0989643314 - None
1367083121 - None
2589261327 - None
3754352886 - None
2349723378 - None
2713318677 - None
0242151735 - None
3807482493 - None
2651669256 - None
0586577237 - None
3525044770 - None
0034228987 - None
1143727560 - None
2616543767 - None
1636617207 - None
0959025083 - None
1318982380 - None
2600577035 - None
compare with the options.ini in my FSEA. the fisrt line is the "FSE-K10 GSM Test Software, Mobile".
Options file in my FSEA:
3780795724; GSM MTS ANALYZER
My question is which line of the SN is for other option?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
FSE-K10 GSM Test Software, Mobile 3780795724
another thing I found is that there is no API.dll in my FSEA30. I search all *.ll in hard disk, it seems that "FSEFPNL.DLL" is the suspect one.
