Please help with DM501 repair. It worked normally about 2 years ago. It will now display a random number and a decimal point when turned on. The display does not respond, only the decimal point switches when changing ranges.The display shows, for example, -1.0480 when -1 is constantly lit and the decimal point with the rest flashes. I don't have pulses on transformer T300, anode CR310. Pin 9 U310B has a correct 5Hz rectangle, but it no longer passes through the C310. The transformer, diode and capacitor are OK.I would insert the diagram, but I don't know how. Thank you very much in advance for any help!
