May I introduce myself with a micro-review (please keep in mind, I am only a little hobbyist)?
For playing around with multimeters I wanted to have an adjustable voltage source with acceptable stability and a voltage range up to approx. 100 V. Although I found nearly nothing in the internet about the performance and although the noise-specs seemed not very impresssive to me I tried a Keithley model 230 programmable voltage source.
In principle this instrument seems to be a microprocessor which controls an A/D-converter (DAC80) with an internal reference which feeds an amplifier. That's all.
The voltage source has four ranges (+/- 199,9 mV, +/- 1,9995V, +/- 19,995V, +/- 101,0V) and can deliver and sink up to 100 mA. The output voltage can be dialed in with a resolution of 12 bit using the buttons on the front panel. The complete documentation with schematics can be found in the internet.
Most of the functions of the instrument can be programmed using the front panel...
(K230_front.jpg)
but unfortunately all the connectors are on the back...
(K230_back.jpg)
When powered on the voltage source needs approx. one hour to reach constant output voltage:
(K230_10V_warm_up.jpg)
For increased resolution I measured the output of the K230 as the difference to my cheap 10 V-voltage standard (Ref-102) with an old Rohde & Schwarz UDL45 Multimeter (uncalibrated, 5,5 dig, = Analogics DP-100). Currently the UDL45 ist the only multimeter which I can connect to a computer.
When warmed up the voltage stability is satisfactory:
(K230_100mV.jpg)
(K230_1V.jpg)
(K230_10V.jpg)
(K230_100V.jpg)
For higher resolution in the 10 V-range I measured the stability as the difference to the 10V-Standard:
(K230_10V_vs_Ref102.jpg)
This noise of approx. 5 ppm (peak to peak, sum of K230 + UDL45 + Ref-102) corresponds to measurements using a HP3456A (uncalibrated) and its statistic program:
(K230_noise_3456A.jpg)
And for special applications it might be interesting to use the program mode. Up to 99 steps can easily be programmed using the front panel and the program can be executed stepwise or once or continously.
(K230_program.jpg)
I am happy with this instrument
