Today the digikey order arrived, except the MAX6350 and AD5791 "of course".
But they will be delivered later, if in stock - So I can not forget about them.
I don't have to worry about the two AD8676 anymore, thanks to a very nice user.
So today the missing resistors and capacitors arrived.
C33 is now a foil with 1µF.
The resistors look quite unspectacular, for that they were so expensive.
The 100 Ohm (R10)with 0.02% tolerance and 0.2PPM Tempco has very narrow solder joints, the 1K (R16) in 0805 case and with 0.01% tolerance looks like any other.
And I'll take the board to work again tomorrow, there is one more component after the L1/L2 and USB port that I can't solder at home:
U3...
(because of the exposed metal back)
Hopefully it will work tomorrow, I wanted to solder at home this weekend what I already have.
