Hi All,
Purchased a HP 6642a looks from date code on some chips that it was built around 1994, so 26 years old...Works fine from preliminary tests but I would prefer swapping out RIFA Film caps and Electrolytic. RIFA where not an issue. But the Electrolytic are another story... they are 3 pin, so if I change them for 2 pin they no longer fit as they will not line up correctly.
What have some of you done to change out 3pin to 2 pin as they are really hard to source. Just get some with long pins and make it work? Insulate whatever sticks out? Tried Digikey and Mouser
Tks
Luca
