I've got both the ITech 8511+ and the Siglent SDL1020X-E. If you don't need the bells and whistles, the Itech loads work well and the 150W 8511+ can be had for less than $350 (from China). The Siglent SDL-1020X-E 200W does add a lot of features and with a discount can probably be had for $450.
The better display and network connectivity are worth the extra $100 to me, but if you aren't going to perform programming or remote automation with the load then the Itech is fine, too. (The ITech is SCPI programmable, but uses a serial interface)
