I'd like to know what information people hope to gain by poking at mains with an oscilloscope as opposed to, eg., plugging in a lamp.
For Pete's sake, everybody, buy a bloody differential probe, & those of us with enough knowledge to do it safely in other ways can just quietly die out, without running into hundreds of iterations of this thread everytime we log on throughout our declining years!
You don't even need that for a quick test. Just pop the ground clips off your probes and set the 'scope to "AC" mode.
(Use two probes and "difference" as necessary).
Indeed, but you probably just generated another twenty or so postings about how inadequate this method is, & how you can only do any testing with a differential probe ---- yada, yada, yada.
Back in the day, when differential probes cost as much as a small car, if I asked the Boss for such a device, he would have reacted in the mode so succinctly described in the modern abbreviation "ROFLMAO", & I would have been sent off "with a flea in my ear" to find a workaround.
Now that they have become relatively cheap, differential probes have been elevated to something of a cult status,
