Author Topic: Electrical Metrology- "Converting a Leeds&Northrup Ayrton Shunt Box to a 0.03% R  (Read 1467 times)
Offline GEOelectronicsTopic starter
link to:  "Converting a Leeds&Northrup Ayrton Shunt Box to a 0.03% Resistance Standard"
 http://www.qsl.net/k/k0ff/VOLT_NUTS/Ayrton_Shunt_Conversion/Leeds-Ayrton_Pub_25.May.2018.pdf
Geo>K0FF
Offline Gyro
Nice easy conversion and writeup.  :-+
A couple of suggestions:
- With minimal wiring mods (cutting the link between the wipers on the two wafers and moving one wire), you could convert it into a 4 wire kelvin sensed resistance standard with sense on the other terminals. It would eliminate variations due to switch contact resistance. Probably most useful on the three lowest values.
- The Metal disc on the knob is almost certainly attached with screws. You could turn it upside down and add more permanent markings.
Both mods would be easily reversible.
Best Regards, Chris
The following users thanked this post: GEOelectronics
Good points, thanks Gyro. Yes the dial is held in place by screws. There are two different versions of the dial, both are easily hackable. Soon I'll post my 4 wire resistor standards build, made with 5 and 10 Dollar eBay finds. (mil spec Vishay metal foil resistors).
Not volt-Nuts standard but way better than anything I had before.
Geo>K0FF
Offline Vgkid
Look into my 4385 teardown to see how they implemented a 4-wire setup.
https://www.eevblog.com/forum/metrology/ln-4385-teardown/
Thanks for the link and teardown L&N. Yours looks like mine. There are a number of "Boxes" from (evidently) different vintages that use same circuitry and box, but much different style knobs. The newer (I assume) ones are black and have a shroud over them.
Personally I like the metal disc look.
The attached picture I caption" You might be a Volt-Nut if this is your idea of an adjustable resistor!"
Notice the file marks on the flattened section of one wire?
We used to "trim" carbon resistors with a file. I write that up sometime.
Geo>K0FF
Offline Vgkid
You wouldn't happen to have a 7593 would you. That was the most expensive L&N "box".
Had to go write down a short inventory. Here's what I'm working with at the moment:
VOLT BOXes:
1 X 7592 with Black Plastic (Bakelite?) Knob shroud and black dial skirt
1X 7592 with silver knob skirt.
2 X 7593 with all clear terminal insulators and silver color metal knob skirt
1 X 7593  with clear and colored (red+black) and silver knob skirt
SHUNT BOXes:
1X 2664 Ayrton variant High Resistance Silver knob skirt
1X 4385 Low Resistance Black knob shroud and skirt
0X 4385S can't find this one, maybe didn't win it?
Are you a collector? Have data posted on any Volt Box?
May I use your schematic drawing of the 4385 (with credit given) in my eHam article? If granted ow shall I credit?
I like this sub board much better.
Geo>K0FF
Offline Vgkid
You can  post my stuff.
 This was originally posted to the volt nuts list a few years ago , then TiN hosted it on his site.
https://doc.xdevs.com/doc/L%26N/LN1972.pdf
