Author Topic: EEVBlog Members Discount at Tequipment?  (Read 464092 times)
Offline Hamster
Re: EEVBlog Members Discount at Tequipment?
« Reply #1375 on: February 05, 2018, 05:24:25 pm »
does the discount code work for Fluke Gear? If so, can someone pm the updated code.. Thanks.
Arcade Board Repair Guru.  [ twitch: HammysHangout , youTube: Hammy Builds ]
Offline nanofrog
« Reply #1376 on: February 06, 2018, 03:22:33 pm »
PM sent to maginnovision, zorkmids, jjoonathan, and Hamster.
Offline nanofrog
« Reply #1377 on: February 06, 2018, 03:31:06 pm »
I also just retired, & am repopulating my test bench that I used back when I worked at a TV-repair shop (remember those ??). Might I please get access to the discount code for TEquipment ?
Many thanks,
gfkdrobi
Please read the first post in the thread.
Offline alank2
« Reply #1378 on: February 06, 2018, 08:45:21 pm »
Could someone PM me the code if they have it!
Offline nanofrog
« Reply #1379 on: February 07, 2018, 04:23:49 pm »
PM sent.
Offline dlo
« Reply #1380 on: February 08, 2018, 06:26:46 am »
Long time lurker and would like to purchase a rigol. Please pm code if still available. Thank you!
Offline nanofrog
« Reply #1381 on: February 08, 2018, 11:34:41 am »
Read the first post.  ::)
Offline hiperco
« Reply #1382 on: February 09, 2018, 03:07:43 pm »
Code please :)
Sent from my SAMSUNG-SM-G891A using Tapatalk
Offline nanofrog
« Reply #1383 on: February 09, 2018, 04:04:41 pm »
Offline keox
  • Country: il
« Reply #1384 on: February 10, 2018, 08:12:46 pm »
Also a code for me, please.
Offline nanofrog
« Reply #1385 on: February 10, 2018, 08:16:03 pm »
Pls read the first post.  Something should click. ;)
Offline haudio
« Reply #1386 on: February 11, 2018, 02:00:53 am »
Long time lurker looking to purchase a Rigol DP832.
Read the first post  :) - could you send the TEquipment discount code when you have a minute?
Thank you!
p
Offline nanofrog
« Reply #1387 on: February 11, 2018, 01:17:57 pm »
Thank you!
p
PM sent.
Offline PoDuck
« Reply #1388 on: February 14, 2018, 06:42:41 pm »
I'm not sure I qualify, but if I do, could I get the discount code please?   :)
Offline nanofrog
« Reply #1389 on: February 14, 2018, 07:27:38 pm »
PM sent.
Offline TurboSam
« Reply #1390 on: February 15, 2018, 12:15:01 am »
As detailed in another post, I'm ready to pull the trigger and the target is a DS1054Z Kit at TEquipment. :-+
Could someone please pass along the code?
thanks!
Paralysis by analysis.
Offline nanofrog
« Reply #1391 on: February 15, 2018, 01:06:52 am »
thanks!
Please read the first post.
Offline TurboSam
« Reply #1392 on: February 15, 2018, 03:00:19 am »
I did read the first post... :)  I've also spent all my waking hours for the last three days reading virtually every post/thread I could find on the scopes I was interested in before deciding on my buy...
Hope that helps.
thanks.
Offline Rofflesaur
« Reply #1393 on: February 15, 2018, 05:39:42 am »
Has the discount code changed?
Also, where do you even enter it in at anymore?
It's time to buy a pre-heater and Omni-Vises!
Offline nanofrog
« Reply #1394 on: February 15, 2018, 05:09:37 pm »
Hope that helps.
thanks.
Sadly, it doesn't. And as you've read the first post, you should understand why.
The good news is it doesn't take much to qualify. In fact it's quite possible to achieve it in a single post and has been done in a number of cases (the New Member Please Introduce Yourself thread is a good starting point for this).
Yes it has.
PM sent.
Offline mesodumb
« Reply #1395 on: February 16, 2018, 03:19:15 pm »
got an order pending. can you pm me the code please. thanks.
Offline kamran
« Reply #1396 on: February 16, 2018, 05:13:46 pm »
May I have the discount code please?
Offline nanofrog
« Reply #1397 on: February 16, 2018, 05:28:09 pm »
PM sent.
Offline TurboSam
« Reply #1398 on: February 16, 2018, 06:33:03 pm »
Age must have dimmed my analytic abilities since I must be missing something....  :-//
Offline nanofrog
« Reply #1399 on: February 16, 2018, 06:42:58 pm »
PM sent. Please read its entirety.
