Author Topic: Need help ,Lecroy WaveRunner 625ZI fail to boot!  (Read 977 times)
Offline YikeTopic starter
  • Country: tw
« on: January 04, 2022, 03:17:52 am »
Hi everyone, New owner of this unit.  Sorry to repeat the post. I want to ask experienced people for advice in solving my problem. I have a LeCroy 625zi. I plan to reinstall the system and find that there is a password. Therefore, I remove the BIOS battery. After installing it back, I can't start it again. The DOS interface is not displayed, and only the fan is working. I can confirm that the power supply is OK!And all output voltages are qualified! How can I repair it?
Thank you in advance for your suggestions.
« Last Edit: January 04, 2022, 03:35:52 am by Yike »
Offline Martin Miranda
  • Country: ph
  • ~~Work: Electronics~~, ~~Hobby: Electronics~~
Re: Need help ,Lecroy WaveRunner 625ZI fail to boot!
« Reply #1 on: January 04, 2022, 03:51:27 am »
tried installing a 2nd external monitor?
beach, sun and the island i call home.
https://www.youtube.com/channel/UCOspWWciGGyF5NwmeVT_mWA
  • Country: tw
« Reply #2 on: January 04, 2022, 04:03:37 am »
OK,I will do it this night! Thank you for your advice!
  • Country: tw
« Reply #3 on: January 05, 2022, 12:33:46 am »
I saved my machine, There is still one fault left,who knows which component is damaged?
Offline darkstar49
« Reply #4 on: January 06, 2022, 08:37:24 am »
doesn't help much... what menu are you in ?? Would be useful to see the left part of the screen...
Some service menu's are not applicable to all scopes, so maybe that's the case here ?? Therefor, need to see the left pane as well...
