Author Topic: EEVblog BM235 Not Beeping Anymore  (Read 6762 times)
Offline vitormhenriqueTopic starter
« on: August 05, 2016, 03:41:44 am »
What's up guys,
I have a question, my EEVblog BM235 stopped beeping all of a sudden, since yesterday it does not make any sound, neither on continuity test, or putting the probes incorrectly (like inserting it on current and putting the meeter on volts).
Is there something really silly that I'm missing  |O ? like a mute function that I activated? I looked on the manual and did not find any thing related with a mute function. Note that everything else looks fine, measuring voltage, current, even continuity is fine, the screen still flash.
Or is something wrong with my BM235?
Thank you all!
Vitor Henrique
Offline retiredcaps
Re: EEVblog BM235 Not Beeping Anymore
« Reply #1 on: August 05, 2016, 04:11:54 am »
Possibly.  Can you take a clear focused photo of the beeper and its surrounding area?  Something like Dave's picture at
https://www.flickr.com/photos/eevblog/24689654432
but, obviously, we want to see yours for possible damage.
You may have a weak solder joint, dislodged component, bad component and/or bad beeper.
Offline Owen
« Reply #2 on: August 05, 2016, 05:45:47 am »
The BM235 slowly becomes a show stopper. How many had issues? 5 or so? Brymen definitely needs a better quality control on that one. First Backlight noise, second lcd contrast issue, than broken Ls, solder joints... If I would buy one at least now I would think when my first issues appears.
No i'm not a Brymen hater or something, i have 3 Brymens... So i feel a bit worried abour their reputation for now on 😖.
Online Whales
    • Halestrom
« Reply #3 on: August 05, 2016, 07:07:30 am »
Tried changing the batteries?
Offline Hydrawerk
« Reply #4 on: August 05, 2016, 05:12:59 pm »
Check the black buzzer. There should be a 50 Ohm resistance.
Offline Kilrah
« Reply #5 on: August 05, 2016, 06:25:55 pm »
5 out of how many hundreds? Come on...
« Reply #6 on: August 05, 2016, 07:59:46 pm »
I'll measure the resistance and take some pictures tonight!
And yes, I changed the battery :)
Thanks for the help guys!
« Reply #7 on: August 06, 2016, 01:21:52 am »
So I just took apart my multimeter, tested resistance of the Piezo and it did not show anything.
Removed the piezo from the PCB and tested the diode continuity, nothing. As you can see from the pictures, it does not look like anything went wrong with my BM235.
I had a Piezo lying around and replaced the original, and voalá, started beeping again. Probably the replaced Piezo does not have the same rating form the original, so I'm not sure that it is a smart decision to keep it there, it definitely does not sound like the original.
I'm attaching a image of the original piezzo, do you guys know where can I find a similar one?
« Last Edit: August 06, 2016, 01:23:37 am by vitormhenrique »
Offline Hydrawerk
« Reply #8 on: August 06, 2016, 02:59:03 am »
Is it really a piezo? Isn't it a little dynamic speaker with a coil inside?
« Reply #9 on: August 06, 2016, 06:55:07 am »
Not sure, I'll open the component tomorrow and analyze what is inside.
Online Whales
    • Halestrom
« Reply #10 on: August 06, 2016, 11:34:46 am »
Indeed both come in an identical looking package.
Offline Hydrawerk
« Reply #11 on: August 06, 2016, 04:23:28 pm »
My $15k MSRP scope fried itself after sitting on the bench unused for 6 weeks.
Sorry, what is a MSRP scope??
I could only find that MSRP means manufacturer's suggested retail price.
Offline Kilrah
« Reply #12 on: August 06, 2016, 04:31:40 pm »
You got it then. The whole point is that an expensive scope failed.
Online zapta
« Reply #13 on: August 06, 2016, 05:35:42 pm »
I also have a MSRP scope. Different model number though. It's from the $4xx series.
« Reply #14 on: August 08, 2016, 02:34:25 pm »
Definitely a piezo on my opinion.
Offline Fungus
« Reply #15 on: August 08, 2016, 03:34:43 pm »
You understood it perfectly.
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #16 on: August 08, 2016, 08:26:40 pm »
Read it as ($15k MSRP) Scope, not $15K (MSRP Scope).
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline Gyro
« Reply #17 on: August 08, 2016, 09:08:58 pm »
I wonder what the failure mode was, there isn't exactly much to go wrong with a piezo. Contamination of the spring contact points (flux or wash)? Overheating during assembly causing loss of spring pressure (melted plastic)? Corrosion in storage or use?
I bet it would work again if you cleaned and reassembled it.
Best Regards, Chris
Offline Muxr
« Reply #18 on: August 08, 2016, 09:32:27 pm »
bad contact perhaps..
