Hi@all,
I recently rebuild a Agilent MSO8104A. I swapped the dying hard drive for a new SSD, increased the RAM from 1GB to 4G (only 3.25 are detected) and reinstalled the software with new versions.
The scope was already preinstalled with 89600 VSA, however apparently it never worked. The VSA does not detect the local instrument, instead some simulated instrument is used. I checked the manual for the installing the VSA software on a Infiniium Osciloscope, however it was not really helpful. I run on Scope v05.71 and VSA v11.21. Anyone had similar experience and knows a solution?
Just a stupid upgrade idea: The current hardware uses a Intel Celeron D 352. Can it be swapped for a Core2Duo?
