Glad to see Joe also was able to capture this
, now with multiple confirms of the issue my guess is the manufacture will look into the issue and hopefully resolve it. Like Joe said, that’s why we test.
The weird thing is trying to make it repeatable. I did capture another 44K logs and it didn’t show up this time. So I ran a faster more aggressive fall curve with only 1000 points and 5 seconds between each point change from 20VDC to 5VDC over a few hours capturing a little over 2000 logs. And again I didn’t see it.
I could run another 19 hour test with 50K logs captured, but this is such a long test to do and not fun to watch
It must be a very specific chain of events that happens to cause this loop.
I think having three different meters see the issue is enough for me. My power supply is needed for some other projects.
I hope all goes well and you have a fast recovery.
Scott
