1) Purchased.
2) Plugged in leads that came with the meter.
3) Ran through basic measurements to make sure it worked.
4) Removed leads - everything OK.
5) Plugged in leads, coiled around meter, probes pressed into holster.
6) Put on shelf.
7) A few weeks later,decide to store leads by hanging them.
8 ) Remove leads, shroud sticking out of lead banana plug.
![Angry >:(](https://www.eevblog.com/forum/Smileys/default/angry.gif)
I haven't even opened up the meter to update the firmware yet.
I've snapped a few close ups of the broken shroud. It is seriously stress cracked beyond what I would think the mere insertion and removal of test leads should cause.
So, how can I fix this? Superglue?
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
