Author Topic: EEVBlog 121GW Multimeter Firmware Details  (Read 347902 times)
Offline firewalker
  • Country: gr
Re: EEVBlog 121GW Multimeter Firmware Details
« Reply #75 on: August 12, 2018, 09:03:12 am »
v1.26 is now on the website for download. We have not tried it yet, but UEi have said that it now logs the displayed data instead of the bargraph data. There should now be no noise on the logged data as per previous versions. Please try it and report.
Offline firewalker
  • Country: gr
« Reply #76 on: August 14, 2018, 08:01:28 pm »
Have anyone decoded the binary file with the calibration data?
Alexander.
Offline tpw_rules
« Reply #77 on: August 14, 2018, 08:04:29 pm »
Alexander.
Sure have. If you've got python 3 or above, run this script with the first argument pointing to the file.
Offline firewalker
  • Country: gr
« Reply #78 on: August 14, 2018, 08:19:20 pm »
Thank you!!! <3 <3 <3
Alexander.
Offline firewalker
  • Country: gr
« Reply #79 on: August 14, 2018, 08:26:43 pm »
The offset number is directly added to the adc result? Is the function that involves the values read form the adc, the calibration data and the displayed number known?
Alexander.
Offline tpw_rules
« Reply #80 on: August 14, 2018, 09:04:24 pm »
Yeah, it's all detailed in the reverse engineering. I suggest you consult that if you are curious because I'm too lazy to explain everything. But to put it in a sentence, bargraph = (ADC - offset) * gain, and screen = smooth(average(bargraph) - nonlinearity_corr), where average is the average of 8 or 16 bargraph samples, nonlinearity_corr is some nonlinearity offset calculated using some data tables and the listed coefficients in a manner that I don't entirely understand, and smooth is a rolling average that resets if the difference between samples is too large.
May I ask why you are interested in knowing all this?
The following users thanked this post: firewalker
Offline firewalker
  • Country: gr
« Reply #81 on: August 14, 2018, 09:12:55 pm »
I was wondering if it is possible to recalibrate offset by hand editing the calibration data. Because someone (Dr. Frank) mentioned that someone might have to complete and the full scale gain calibration in order the meter to save and accept the zero offset data. But this mean specialized equipment.
Alexander.
Offline tpw_rules
« Reply #82 on: August 14, 2018, 09:18:59 pm »
It would be possible. However, according to my knowledge of the firmware, the corresponding factor is saved before the G-END or OFF-E message is displayed. So you can just turn off the meter after offset calibration to skip gain calibration. But of course, the offset factor is used when calibrating the gain factor, so one would be advised to do gain as well. Maybe someone can work out the math to adjust the gain factor, and hand edit that in.
Offline Lion_Tamer
« Reply #83 on: September 02, 2018, 07:54:57 pm »
Hi all
I have finally had time to sit down and start playing with the meter properly, although I would love to have completely open source firmware I also know that I don't have the skill or knowledge to write it, I also don't have the time or equipment to do the extensive testing required but thought that I could contribute by at least dumping out the firmware from the BLE112 blue tooth module (I know that at least Joe has a meter with an un-programmed module and though it would be useful in case anyone bricks one).
I did this using the "Texas Instruments Smart RF Flash Programmer" software with a "CC Debugger" connected to the CN2 port in the 121GW - connections as below:
121GW <=> CC Debugger
Pin 1 <=> Pin 7
Pin 2 <=> Pin 2 + 9
Pin 3 <=> Pin 1
Pin 4 <=> Pin 3
Pin 5 <=> Pin 4
In time I may try to reverse engineer it a bit more but I suspect that my lack of expertise will hinder me there.
Jem
P.S. this was dumped from meter no 180701854 running firmware version 1.26
The following users thanked this post: Kean
Offline Lion_Tamer
« Reply #84 on: September 27, 2018, 09:14:56 pm »
I found that I was struggling to understand the official Packet protocol document so as I don't currently have a blue tooth interface for the PC I have been looking at the UART streams between the STM32 processor and the BLE112 blue tooth interface on the meter and am slowly creating a more detailed document about the 19 byte packet.
I have attached what I have got so far below along with a screen shot of a packet as captured from my meter.
Note: Meter Firmware Version 1.51
Jem
Offline Lion_Tamer
« Reply #85 on: September 27, 2018, 10:12:07 pm »
Its a 19 byte packet from the STM32 to the BLE112 inside the meter, I don't know if the BLE112 adds any packets before it transmits it to the receiving device, I intend to try and look at the transmitted data as well at some point to see if it does add stuff but don't have a compatible blue tooth receiver for the PC.
Jem
Offline Dampmaskin
  • Country: no
    • Steam Engine
« Reply #86 on: October 30, 2018, 11:59:37 am »
Now version 1.51 is gone from the product page, and 1.26 is the newest. What happened?
Offline Candid
« Reply #87 on: October 30, 2018, 04:48:10 pm »
So as a 121GW user I would like to hear about the reason or at least if I should downgrade to 1.26.
Offline GeoffreyF
« Reply #88 on: November 01, 2018, 02:06:56 pm »
I figured it was just an oversight with managing the web page. Possibly still there may be problems with attending to this due to the move.  I wish someone would comment on this matter.  I did install 1.51 in my meter.  I see no problems but I'm wondering what's what.
US Amateur Extra W1GCF.
Offline MrPeak
« Reply #89 on: November 03, 2018, 06:06:36 pm »
I've installed the 1.51 FW, a month ago, without any issues. I want to know why the FW
was removed. There is another thread, where a user complains that the calibration data is
partly wrong after upgrade to 1.51.
Maybe someone can bring a little bit clarity about the background. I'm afraid that my calibration
data is also corrupt.
« Last Edit: November 03, 2018, 09:07:45 pm by MrPeak »
Offline cmumford
« Reply #90 on: November 05, 2018, 01:00:23 am »
I also upgraded to 1.51, but didn't use the meter post upgrade. I'd love to know if I should downgrade.
Offline gdewitte
« Reply #91 on: November 05, 2018, 09:16:17 pm »
And now 1.52 is out there. Could someone please give us an update?
Offline GeoffreyF
« Reply #92 on: November 05, 2018, 10:48:41 pm »
Being of an empirical and somewhat adventurous nature, I decided to install the firmware labeled 1_52.  The meter started back up just fine but comedy ensued, the firmware revision is reported as 1_53.  I checked this several times lest my eyes deceived me.  1_53. I suppose I can state the result is better than expected, at least numerically.
Cursory examination, the meter seems OK.  I'm still wondering if, after 1_51, it's still calibrated. but I think it is.  I'd like a way to verify that - what a "bricked calibration" looks like is not what mine looks like.  I'm thinking that the incident that initiated pulling 1_51 was fairly anomalous but can we get confirmation?
Offline CDaniel
« Reply #93 on: November 05, 2018, 11:35:14 pm »
I installed v1.52 , so far I see a big improvement in reducing the 50Hz noise in resistance mode , now when measuring Mohm resistors you can touch the probes and cables .
The beep sound in diode mode is still laggy ...
Offline GeoffreyF
« Reply #94 on: November 06, 2018, 02:14:31 am »
Did it report 1.53 when  when you first started it?  I think resistance resolution seems faster.  I don't think that beep is supposed to happen with all diodes.  Beep happens only when resistance is very low. It's responding to apparent continuity.
Offline CDaniel
« Reply #95 on: November 06, 2018, 07:13:32 am »
Yes of course it display 1.53 ...
The beep when you are shorting the probes is laggy , so when measuring a shorted transistor or diode you have to wait a moment ... not good at all . Every other multimeter is much responsive .
In continuity mode the beep is very fast responding , so I don't see any reason why in diode mode is laggy .
« Last Edit: November 06, 2018, 07:25:33 am by CDaniel »
Offline GeoffreyF
« Reply #96 on: November 06, 2018, 02:56:01 pm »
I am using Probemaster probes but even with the ones which came with (that I believe are UEI Test) - I have found no lag at all on beep, simply striking the probe tips against one another or bring the tips together, is an immediate beep.   Something may be off with your unit.  When you short the probes, what is the resistance reading?
Offline CDaniel
« Reply #97 on: November 06, 2018, 04:03:53 pm »
The beep lag is only in diode mode ( maybe 0.5sec ) , in continuity mode is very fast .
Resistance is zero when shorting the probes
Offline GeoffreyF
« Reply #98 on: November 06, 2018, 04:44:34 pm »
There is no mention of diode beep in the manual.  According to the manual there is a 2.2k resistor and a PTC in series with the DUT.   Literally the diode test is not supposed to Beep except that is a side effect of the continuity function for diodes with low enough forward current to trigger it.  It's hardly surprising that when the beep happens - it is "laggy".  it's not a simple continuity test.
You are wanting something to work that is not part of the published feature set.
Offline CDaniel
« Reply #99 on: November 06, 2018, 05:03:01 pm »
Every decent multimeter has the beep in diode mode ... and is fast , feature or not  :D
If you really work with the multimeter repairing something you will know why .
« Last Edit: November 06, 2018, 05:04:57 pm by CDaniel »
