Author Topic: EEVBlog 121GW Discussion thread  (Read 824710 times)
0 Members and 15 Guests are viewing this topic.
Offline rthorntn
Re: EEVBlog 121GW Discussion thread
« Reply #1975 on: September 12, 2023, 07:13:37 am »
Apologies for the thread necro, I forgot to fix up my DMM back in the day.
I have the "repair" kit, with the round PCB shim thing and dial but I can't find any instructions on the repair, do they exist?
Also my startup screen shows "U-1.01" should I be upgrading?
Thanks,
Richard
Online J-R
« Reply #1976 on: September 12, 2023, 07:58:19 am »
I have two 121GW DMMs that shipped with the shim, and I removed it on both and had no issues.   I did check the spring contacts to make sure they were making a good connection with the PCB.  So my opinion is that if you're not having an issue, then don't worry about it for now.  But here is one video showing where the shim goes:
The cutout portion faces the clip.  I also personally added a tiny amount of lubricant where the plastic parts rub, and also some precision lubricant to the contacts.  There is debate about this, but I think it's far easier to clean up some old lube than try to fix a worn component.
I do think you want to be on the latest firmware.  Maybe just double-check to make sure you can go directly to the latest release.  I don't recall off-hand.
Offline ploxiln
« Reply #1977 on: October 15, 2023, 07:14:59 am »
Google Play won't let me install the official 121GW app on my android phone ... I think because it's pretty new and I'm on the latest android version (13), and they have a scheme to try to force apps to target later "api level" if they want to submit updates, or want to support the latest Android, in order to get newer security/permissions rules rolled out over time ...
Anyway, I was able to find the APK on some mirror sites, a little bit sketchy, but I cross-checked a few to try to ensure I got the authentic thing:
bytes: 20624429
sha256: e9ecb6c86b1012b6829c813e0c6fb6929526d85218b50f3a3d2ac832ab32e1d5
I side-loaded it (possible on almost all android phones) and it worked just fine.
It would be nice to get an official download link on the product page for the APK, and for the "modern windows" app if that's even possible ... realistically I understand Dave is just not a software guy, but has provided the full source for these apps to enable others. So will I be the one who steps up to at least provide recent builds, to appease the fast decay of modern app platforms? hah I dunno ... I've never worked with these particular technologies (server/infra seems a lot more stable :P) but that's a lame excuse ...
Online J-R
« Reply #1978 on: October 15, 2023, 11:21:07 am »
The official app is linked from the 121GW store page: https://gitlab.com/eevblog/app-121gw
However, neither it nor the one currently on the Play store will work with Android 14.
I think most folks are using the Meteor app these days, which does work with Android 14, although I didn't fully test all the features.
The best solution in my opinion is to get an old phone and dedicate it for this specific purpose.  If you don't have one, check eBay, family members, friends.  Get a phone that is supported by LineageOS: https://wiki.lineageos.org/devices/
Offline ploxiln
« Reply #1979 on: October 16, 2023, 06:52:12 am »
Ah, I see the built android apk was recently-ish added to the gitlab repo, I didn't spot it there before - I was looking for "releases". It is a bit bigger than the copy I found on the mirror sites - maybe it's a debug build, or google re-compresses it? I'll have to extract and compare them ...
Google Play also says Meteor 121gw is not compatible with my phone, either - I guess I should mention it's a Sony Xperia 5 IV. Maybe it's a weird bluetooth version thing? I suspect it would work fine if side-loaded, like the original 121gw app does.
Online J-R
« Reply #1980 on: October 22, 2023, 03:16:24 am »
Did a couple posts get deleted?
Anyway, the app available for download on GitLab doesn't work, I've tried a few versions of android and the screen is just mostly blank after connecting.
So the app store app and Meteor app are the way to go for now.
Offline tszaboo
« Reply #1981 on: November 09, 2023, 01:50:06 pm »
Just got a 121GW at work. It's a cool little meter, I think it's full of nice have features, still haven't tried all the options.
One thing that I would like to submit as an error report:
When measuring power, negative current values and positive voltage results positive mVA (watt). So you get positive results when measuring on a battery if it's charging or discharging. I haven't verified this myself, just reported by my colleague.
Offline JDW
  • Country: jp
« Reply #1982 on: December 13, 2023, 04:33:50 am »
Dave,
I was contacted by a viewer of my 121GW review video who says he cannot order the meter from your product page.  I just checked.  Pretty crazy.  Says 2 in stock, but when you try to add to your Cart you can't.  Why?  Because it then says this:
You cannot add "121GW Multimeter" to the cart because the product is out of stock.
Yet another problem you need to fix is the blue info bar at the bottom which says this...
Some EEVblog store products are also available from Simon's Electronics in the UK, Welectron in Germany, and Amazon in the US and Australia.
"Amazon in the US" is not accurate.  I just checked.  Says UNAVAILABLE.
Offline GraXXoR
  • Country: jp
« Reply #1983 on: December 13, 2023, 03:26:41 pm »
Hi. I am the person who intended to purchase 121GW accessing your store from Japan After watching a thoroughly comprehensive review by fellow Japan resident youTuber, JDW.
Unfortunately, While I was able to add the device to my cart and check in to PayPal to make the payment, when I confirm my address it says shipping to that address is not available.
Yet the confirm payment button is still clickable Despite the product supposedly being on shippable.
Not sure what the problem is. It’s the address that is already registered with PayPal so I know that it’s correct because it’s auto entered into the fields.
Hope this problem can be resolved so that I can get my 121GW ASAP.
Regards.
« Last Edit: December 13, 2023, 03:28:50 pm by GraXXoR »
Offline Veteran68
« Reply #1984 on: December 13, 2023, 04:12:30 pm »
Didn't Dave or someone mention recently that the 121GW was discontinued or soon to be?
That may explain the availability issues and lack of Amazon presence while the BM786 and BM235 are still available. Dave needs to update his site, if so. Then again he still advertises the uCurrent Gold too, even though he hasn't made/sold them in years now it seems.
Also interesting to note he's also selling the UT61E (but not the much improved E+) model. Did I just overlook that before? I didn't realize he resold Uni-T meters.
Offline JDW
  • Country: jp
« Reply #1985 on: December 13, 2023, 09:49:55 pm »
Curious you seem to be asking that question to either myself or GraXXoR, when it's rather clear that neither one of us are aware of any mention of product discontinuation.  You didn't even link to any post citing discontinuation.  And as you said, the website has not been updated, still showing inventory, which makes no sense if a product has been discontinued.
Dave?
Online thm_w
  • Non-expert
« Reply #1986 on: December 13, 2023, 11:27:49 pm »
Dave,
He was having issues with store and shipping prices, I don't know if its fully moved over to shopify or not. But can try ordering from here if you want to take the risk, OR wait for him to respond: https://eevblog.store/products/121gw-multimeter?variant=45270685581620 (thread here: https://www.eevblog.com/forum/chat/ot-shopify-kinda-sucks/msg5020315/#msg5020315)
If the stock was accurate (2 or 0) then you may have to wait until the meter is in stock again, so could be some months.
Just means out of stock, may or may not be restocked, depending on if dave decides to sell through amazon or find a US reshipper.
The following users thanked this post: JDW
Online J-R
« Reply #1987 on: December 13, 2023, 11:43:07 pm »
I have not heard anything about the 121GW being discontinued, and they are still selling out regularly.  But of course it is possible.
If you want one right now, Welectron has 9 in stock: https://www.welectron.com/EEVBlog-121GW-Data-Logging-Multimeter-with-Bluetooth
Is the UT61E listing maybe just be his way of doing an affiliate/click-through?  Seems like it will be drop shipped direct from China rather than through Dave in Australia.
Offline JDW
  • Country: jp
« Reply #1988 on: December 13, 2023, 11:50:22 pm »
I myself already have one. I am simply commenting here to help out someone who wants one for a reasonable price. And the best pricing seems to be available from Dave’s website. That €250 price is extremely expensive because it seems to include the VAT that only applies to Europe. So if someone wants to buy it outside Europe, it doesn’t make sense at that price.
Offline EEVblog
« Reply #1989 on: December 13, 2023, 11:57:12 pm »
Sorry about the problems, I've actually moved to a new store website, so try that.
It now has an exta cheaper shipping option with Sendle, in addition to DHL express.
The link on my website menu has changed to reflect that, but the old Woocommerce product pages and order system are still there and searchable by goolgle.
So I'm currently getting about 50/50 order split from the old and new website.
Had too many issues with Woocommerce, one of which is a buggy stock system, so I switched to shoppify and used the new domain name.
Will eventually shut down the old product pages so they are purged from Google search.
I do still have some stock left, and have ordered some more stock due late Jan. But Kane have advised that they are basically using up their remaining stock of parts, and I get the vibe that once that's done they might not want to make it any more.
The following users thanked this post: thm_w, JDW
Offline EEVblog
« Reply #1990 on: December 14, 2023, 12:01:13 am »
Correct. Shopify has a plugin that allows affiliate link integration via Aliexpress, and that product was just a test to see how it works. Ultimately I'd like to get around to adding a bunch of useful product suggestions there.
Offline Veteran68
« Reply #1991 on: December 14, 2023, 01:01:39 am »
It wasn't directed at anyone in particular. It was just me rhetorically commenting that I *thought* I'd heard something about availability being in question. I didn't link anything because I wasn't even sure I'd heard that, just that I seemed to recall it. Obviously if I were sure and had a link, I wouldn't have expressed it as a question.
Many store listings, including Dave's, often keep products that are permanently or at least indefinitely out of stock. That's not unusual, whether it makes sense or not. If something never comes into stock, then one can argue it's discontinued (if they're the manufacturer, anyway). Again, uCurrent Gold is a good example. It's been OOS for years and Dave has suggested he may not make/sell any more.
This is probably what I'd heard/read somewhere and was remembering.
Offline JDW
  • Country: jp
« Reply #1992 on: December 14, 2023, 01:06:19 am »
I am updating the purchase links in the text description under my 121GW Review video now, Dave.  But even though I see the FUSE PACK on your new shop site, it has been out of stock for at least a year and as long as I can remember.  And news about availability?
https://eevblog.store/products/multimeter-fuse-pack
Same issue with the Soft Case for 121GW too:
https://eevblog.store/products/bm235-121gw-case
Thanks.
« Last Edit: December 14, 2023, 01:09:07 am by JDW »
Offline EEVblog
« Reply #1993 on: December 14, 2023, 01:11:42 am »
Cases are at the local port, so will have them next week.
Fuses I need to order again, no ETA on that.
Online J-R
« Reply #1994 on: December 14, 2023, 06:05:34 am »
Welectron has the including/excluding VAT pricing clearly listed.  So 121GW + Brymen silicon test leads (the default if you simply add it to your cart) is $239.74USD delivered to USA via DHL Express Worldwide (less than a week).
121GW from Dave direct is $223.68USD delivered to USA via Sendle International (Estimated delivery Tuesday, Jan 2–Monday, Jan 29) or DHL Expresss Zone 4 for a couple dollars more (sssent by sssnake? no ETA listed).
So pricing is not too drastically different.  It also fluctuates with the exchange rates, which you can gamble with if you like.  I personally like Welectron because I can add fuses, test leads, carrying cases, etc. to my order and save on shipping.
Offline GraXXoR
  • Country: jp
« Reply #1995 on: December 16, 2023, 03:58:05 pm »
Hi there there seems to be some confusion about what issue I’m having here.
The thing is I go through the entire shopping process added to my cart, it does actually seem to be in stock…. And once I’ve added it to my cart I go to the PayPal checkout and then I enter my business address or use the one register with my PayPal (home address) and then it says that it cannot be shipped to my country.
However there is still a pay button underneath it which seems a bit odd considering it can’t be shipped and I don’t want to press it.
I have attached the error message which I am receiving.
My address is central Tokyo.
« Last Edit: December 16, 2023, 03:59:49 pm by GraXXoR »
Offline EEVblog
« Reply #1996 on: December 16, 2023, 10:50:58 pm »
Email me your address.
Offline GraXXoR
  • Country: jp
« Reply #1997 on: December 17, 2023, 05:59:49 pm »
Message sent. Let me know if the system is having a problem handling my address...
Tho I suspect I'm not far from JDW who successfully received one.
If it doesn't work, I'll order one with a set of brymen probes from that German site.
Seriously, thanks a for the rapid feedback.... Shows the calibre of the man when he can handle individual posts so quickly on an enterprise as big as EEVBLOG.
Cheers,
  Grx
« Last Edit: December 17, 2023, 07:08:25 pm by GraXXoR »
Offline EEVblog
« Reply #1998 on: December 18, 2023, 04:03:28 am »
Sorry, Japan wasn't set correctly in Shopify. Should work now.
Offline GraXXoR
  • Country: jp
« Reply #1999 on: December 18, 2023, 01:54:53 pm »
damn. the price went up O_O
It was $204 now I have to pay in yen (29,000) not dollars and when paypal converts that back into dollars it's $214... and I'll likely have to pay 10% local tax on that bringing it to ¥31,900.
I can currently get the Sanwa PC7000 locally with a 3 year guarantee for ¥24,800 (~ $180) including tax and postage, so I will have a bit more of a think on it. ¥26,000 ($190) with gold plated test leads.
... thanks for fixing it in any case. I might pick something up from you if the Yen recovers a bit against the dollar. My limit for a tester is 30,000 and this just unfortunately tipped over to the other side.
« Last Edit: December 18, 2023, 07:03:28 pm by GraXXoR »
