Author Topic: EEVBlog 121GW Discussion thread  (Read 815352 times)
Offline skyjumper
400mA fuse replacement
« Reply #1850 on: March 22, 2021, 03:26:56 pm »
Hi All, this weekend I blew the 400mA 600V fuse. I'm in the US, and Dave's fuse pack would take some time to get here. I see lots of 600V 500mA fuses available, not so much with the 400mA. Could I safely use a 500mA fuse instead?
Offline Wytnucls
Re: EEVBlog 121GW Discussion thread
« Reply #1851 on: March 22, 2021, 05:41:26 pm »
The range is 500mA, so the 500mA 600V fuse is fine, if it has a FF rating (Fast) and a high breaking capacity (10kA).
6x32mm, rated for AC/DC (UL248-1)
« Last Edit: March 22, 2021, 05:50:18 pm by Wytnucls »
The following users thanked this post: skyjumper
Offline skyjumper
« Reply #1852 on: March 22, 2021, 08:28:31 pm »
Thanks very much, I thought as much but this makes me wonder why there is a 400mA fuse to begin with? Although I did end up finding some 400mA @ 600V, are these acceptable:
https://www.amazon.com/gp/product/B0891P5XMM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
« Last Edit: March 22, 2021, 08:42:28 pm by skyjumper »
Offline Wytnucls
« Reply #1853 on: March 22, 2021, 09:15:23 pm »
Stick to good brands, like Littelfuse, Cooper Bussmann or Siba if you can, otherwise examine the datasheet carefully for compliance.
The manual recommends  cryptically ASTM HV610.0.4 400 mA (600V) or HV620.0.4(1000V) A/500 mA current input fuse (sic)
Offline skyjumper
« Reply #1854 on: March 22, 2021, 09:18:00 pm »
Ah okay, well if 1000V fuse is acceptable then there are many 500mA to choose from. Thanks.
Offline Brumby
« Reply #1855 on: March 22, 2021, 11:53:00 pm »
« Reply #1856 on: March 23, 2021, 09:49:29 am »
This:
And make sure the spelling is correct! Poor spelling invariably indicates counterfeits that have no sand inside to quench the fault arc, something I'm seeing more of in the UK with BS1362 fuses.
They can and do explode under fault loading.
Offline skyjumper
« Reply #1857 on: March 23, 2021, 04:24:38 pm »
I have Dave's fuse pack on order, but that will take 15 days and I can't wait that long to get this back into service. I should have stocked up on fuses for it, but it never occurred to me they would be hard to find on short notice. In the meantime I'll use the one I ordered and be super careful not to screw up again. Maybe the international postal Gods will smile on me :-)
Online EEVblog
« Reply #1858 on: March 24, 2021, 07:40:13 am »
Beware of fakes on ebay and other places. Because of the very high potential margins on these, the market is awash with fakes.
The following users thanked this post: Marco1971
Offline tmcks
« Reply #1859 on: April 21, 2021, 02:04:39 am »
Hi all,
I received my 121GW today. I went to check the firmware and I see v2.04 is the highest listed on the 121GW firmware page, but the start screen on the DMM shows v2.05. Is this an error and I should flash 2.04, or is 2.05 real and just not listed yet?
Thanks.
Offline firewalker
  • Country: gr
« Reply #1860 on: April 21, 2021, 09:43:31 am »
Hi all,
Thanks.
Probably not listed yet. Check the contents of the microSD card. If you see a file named EEVBlog.bin, share it with us.  :D :D :D
Alexander.
Offline tmcks
« Reply #1861 on: April 21, 2021, 01:59:17 pm »
Alexander.
Sorry, but the SD card seems to be empty.
Online EEVblog
« Reply #1862 on: April 22, 2021, 01:35:01 am »
Hi all,
Thanks.
I don't have have 2.05, have asked Kane what the deal is.
I have new stock on the way soon, don't know what version they will have. I can only presume that you bought it from Welectron and they somehow have a newer version firmware.
Offline tmcks
« Reply #1863 on: April 22, 2021, 02:31:41 am »
Hi all,
Thanks.
Yes, it is from Welectron.
Thank you.
Online EEVblog
« Reply #1864 on: April 22, 2021, 02:56:09 am »
I now have v2.05
They changed the low pass filter curve to better match the performance of the Fluke 289, which I guess they are using as a sort of reference.
And yes, this version was shipped to Welectron.
The following users thanked this post: dcac, J-R, tmcks
Offline J-R
« Reply #1865 on: April 22, 2021, 05:03:59 am »
Flashed without incident.
The following users thanked this post: EEVblog, jancumps
Offline e0ne199
  • Country: id
« Reply #1866 on: April 27, 2021, 06:09:50 pm »
I now have v2.05
is that the only update??
Online EEVblog
« Reply #1867 on: April 28, 2021, 12:55:40 am »
I now have v2.05
Yes. That is the only change they said was made.
Offline commandlinehool
« Reply #1868 on: May 28, 2021, 01:21:31 pm »
Also got mine from electron today with 2.05. Also the yellow shim have been removed?
Does it always comes without probes? I thought it’s either Brymen or UEI probes.
Cheers
« Last Edit: May 28, 2021, 03:26:16 pm by commandlinehool »
Online EEVblog
« Reply #1869 on: May 29, 2021, 10:26:12 am »
Yes, the shim was only for the first several thousand PCB's that had the wrong thickness.
I don't have control over what Welectron sell, but Kane's standard FOB quote is without probes. If the distributor wants probes then they have to order them as a separate line item.
Offline J-R
« Reply #1870 on: May 30, 2021, 01:13:04 am »
By default Welectron checks the box to include the probes when you hit the 121GW page, but you can uncheck it.
I have two 121GW units that came with shims.  I removed it from both and have had zero issues.  Perhaps after things wear it might be needed.
« Reply #1871 on: June 01, 2021, 11:50:17 am »
Thx for the reply. I didn't know they aren't stock included. :)
Yeah, I thought there were some included, so I unchecked it  ;D.  Got myself some Fluke Probes now, maybe have to shorten the banana plugs a bit but otherwise they work fine.
Yeah, I wanted to remove them to avoid issues and found out they aren't there anymore. :)
Offline Timz
« Reply #1872 on: June 03, 2021, 09:01:54 pm »
Yeah, just received 121GW 2 days ago, and the firmware reads 2.05,  no idea if that's actually from Welectron, but I ordered it directly from EEVBlog shop online.  Delivered to UK by DHL courier and it originated from Australia.
Happy with this product so far.  Thank you so much.
Offline dzenbo
  • Country: ua
« Reply #1873 on: June 04, 2021, 02:25:41 pm »
Hi, I have not read all thread trough so maybe this note will be not a new. But in my opinion AutoHold mod is slightly raw, especially in resistance measurement - it takes all my time to get value of a single res. In the same time in a basic mode I see that the value jumps in a least significant digit only. And it is very disapoint that I cant check 5% resistors over the board as fast as I have expected  :P
I understand that design and consumer satisfaction it is all about trade-offs. But my vision of this process is to give user freedom to select between A) more digits, sometimes more noise and more time to get a value, and B) less digits - faster response.
We have a "1 kHz" mode which enables filter. So maybe it is reasonable to make it available for other modes?
One more. Looks that the AutoHold mode does not depends of Auto range or particular range is selected. I thought the overall time to get hold the value is a sum of the time required to find the range and the time required to ensure that the value is stable. But looks that it is not. Very strange
If required I will make a video report later.
Online EEVblog
« Reply #1874 on: June 07, 2021, 05:38:05 am »
Correct, all my units in stock are the latest 2.05. Welectron were just the first to get it.
