Author Topic: EEVBlog 121GW Discussion thread  (Read 815092 times)
0 Members and 21 Guests are viewing this topic.
Offline J-R
Re: EEVBlog 121GW Discussion thread
« Reply #1775 on: April 28, 2020, 07:49:15 pm »
Regarding getting logged data off the internal MicroSD card... why not make it possible to do a File Transfer over BT? This should address users physical accessibility issues. Tried a BT file transfer from Windows 10 PC but the 121GW ignores the "Receive a File" request. Is it an issue the software stack to implement this feature is beyond the hardware's capability?
It was considered very early on back in the development but it was deemed to be too hard. IIRC it needed added support in the bootloader code, so I don't think it's even possible with just a firmware update.
What if you could "play back" the logged data on the display so the app could read it?
Offline moore
« Reply #1776 on: May 02, 2020, 05:33:21 pm »
Is this meter still available for sale in the US?  I only found a couple of used ebay listings.  Amazon says no stock.
Is there any issue with ordering directly from the site - customs holds etc.?
Offline EEVblog
« Reply #1777 on: May 03, 2020, 08:38:53 am »
No customs issues for the US. It ships via DHL express courier from my site.
I do not have enough stock at present to restock Amazon.
Offline cowasaki
« Reply #1778 on: May 30, 2020, 08:55:48 am »
About a month ago I bought three more multimeters, two £40  ones with bluetooth so I can monitor two voltages and display the values on the iPad and a 121GW as an accurate decent quality one on the bench.  I have a Keithley 2100 and two Philips bench meters but sometimes it's easier just use a hand held meter.  My first impressions are good and I like the probes.  The possible issue I have with the 121GW is reading small values of resistance.  I have built a bench adjustable load 2/4/8/16 ohms and the new meters and bench meters all work with it but the 121GW just reads that there is no connection.  I can read larger values and the accuracy matches up very well with the keighley but small values are not working.  I have ended up switching leads and using the cheap ones which seems silly
Any ideas?
Offline CDaniel
« Reply #1779 on: May 30, 2020, 08:58:49 am »
But what is showing when shorting leads ?
Offline cowasaki
« Reply #1780 on: May 30, 2020, 12:09:26 pm »
0.046 ohms
I've just checked it now and it read the resistance of a transformer correctly.
I'm going to have to work out the context of it doing this and repost
Offline cowasaki
« Reply #1781 on: June 04, 2020, 06:57:29 pm »
Ok it's not working again....
Unless I'm missing something obvious.
I have a 56K resistor with probes attached either side.  First I'm measuring with a brilliant cheap multimeter the Owen B35T+. It measures the resistor at 56K5 which is confirmed using using Keithley 2100.  Then I haven't changed anything at all but simply moved the probes from the Owen to the 121GW.  The 121GW measures the value as...... well it doesn't even recognise there is a value.  I then put the probes back into the Owen and it is measuring the same.  All I get out of the 121GW is OF.L. Not good for a meter costing 10-15 times the amount.
Offline cowasaki
« Reply #1782 on: June 04, 2020, 07:02:03 pm »
And I've just plugged it in again and it seems to be working.  I'm been having these issues from day 1 but as I have over ten meters I've not got round to doing anything with it.......
Offline dcac
« Reply #1783 on: June 04, 2020, 08:35:48 pm »
You seem to have the 121gw in Continuity mode and not in Ohms mode - Continuity can only measure up to 500.00 ohms.
Offline cowasaki
« Reply #1784 on: June 04, 2020, 09:23:05 pm »
? I switch to ohms and it was the only resistance mode that came up.  Do I have to change something else?  That doesn't seem very intuitive.  What tells you it's in continuity mode?
Offline darrellg
« Reply #1785 on: June 04, 2020, 09:40:00 pm »
Press the Mode button until is says AUTO in the top left and the Ohms symbol appears on the right.
The following users thanked this post: cowasaki
Offline cowasaki
« Reply #1786 on: June 04, 2020, 09:41:37 pm »
Does it remember it next time?
Offline dcac
« Reply #1787 on: June 04, 2020, 09:46:35 pm »
Yes last mode selected with red button is remembered - even after power of I think.
Continuity mode is shown by symbol in red circle.
Offline ve2mrx
« Reply #1788 on: June 23, 2020, 09:24:19 pm »
Hi everyone,
I got a 121GW last month from the EEVblog website, and I have one question:
What is the difference between the currently-sold 121GW "pre-Kickstarter" model sold by EEVblog's website and the "normal" production one?
My PCB looks like it's 2019-09 dated...
NOTE: The current stock meter from this website is the latest pre-Kickstarter build that has the new PCB (doesn’t require the shim) and larger protection transistors fitted. It also comes with the UEi test leads instead of the Brymen test leads. These leads do not have banana tip adapters like the Brymen leads
I'm OK with the different leads or cosmetics. I'm really wondering about performance/quality differences.
Hi Dave,
Thanks everyone!
73's de Martin VE2MRX
Offline EEVblog
« Reply #1789 on: June 23, 2020, 11:14:43 pm »
Hi everyone,
Oops, that should read "post-Kickstarter"!
My store has had the latest hardware build for many months now.
Offline ve2mrx
« Reply #1790 on: June 24, 2020, 02:07:32 am »
Hi Dave!
Thanks for the explanation!
Indeed, I found it odd that the PCB was 2019-09 and it was supposed to be "pre-Kickstarter"... I figured all that was "Pre-Kickstarter" was the meter's shell and boot, meticulously upgraded with the new guts :P
Well, your comment explains everything!
Thanks!
Martin
near Montreal, Quebec, Canada
Offline cowasaki
« Reply #1791 on: June 25, 2020, 12:01:47 pm »
To be honest I am less than impressed with the 121gw. An experienced engineer should not not to resort to the manual every time he wants to do something that is basically simple. I’m just trying to work out the wiring in a speaker cab. The difference between the resistances is small but the leads I’m using are showing as 1.5 ohms. Now that probably because I’m going through several adapters but I don’t have five arms so it’s the only way I can manage with what I have with me. Simple just zero the probes and it’s not a problem!!!!
Err no. How do I zero the probes? On my Keighley there is a nice zero button. On the 121gw? No I can’t work it out. This is the second time I’ve had issues with this DMM and it’s the second time I’ve used it. The first first it wouldn’t read certain resistances at all because it was in some mode.
Any clues?  If it had been a £10 DDM I would have chucked it out of the window by now
Offline newbrain
« Reply #1792 on: June 25, 2020, 12:15:13 pm »
The's a nice REL-Δ button.
Exactly the same as on my Fluke 87V, and FWIW, the UNI-T 61-D I previously had...
Or did I misunderstand something? :-//
« Reply #1793 on: June 25, 2020, 12:20:10 pm »
To be honest I am less than impressed with the 121gw. An experienced engineer should not not to resort to the manual every time he wants to do something that is basically simple. I .... Snip
 :o Rel, Zero, Null ........ all in common use so  :-//
Offline cowasaki
« Reply #1794 on: June 25, 2020, 12:26:12 pm »
That was the first thing I tried REL doesn’t do anything at all.
Offline cowasaki
« Reply #1795 on: June 25, 2020, 12:29:10 pm »
Ok I’ve pressed it and wobbled it and pressed it harder then suddenly it zeros. I think I might have a slightly dodgy button. That would explain things....  will have a proper mess later I need to get this cab back together.
Offline firewalker
  • Country: gr
« Reply #1796 on: June 25, 2020, 12:44:15 pm »
I have a similar issue on Ohms range. In my case is the rotary switch. If it is not centered exactly, it doesn't behave correctly.
Alexander.
Offline cowasaki
« Reply #1797 on: June 25, 2020, 12:45:06 pm »
Yes after it worked that first time it now works every time (I will have to start using it more to make sure it doesn’t happen again before the warranty is up) I bought this 2-3 months ago but as I have a couple of Philips/fluke and a Keighley bench meter on my bench it doesn’t get used much (twice). I’m currently scrabbling around on the floor trying to rewire a cab with speakers that don’t belong in it! I was getting more and more annoyed :-) it’s working now and I can get back to my nice soothing valve amplifiers.......
Offline cowasaki
« Reply #1798 on: June 25, 2020, 12:50:00 pm »
Fire walker,
I think it was just that the button was stiff from new or not seated right. It’s working fine now and all the other buttons SEEM to be fine. I’ve only used it once before. I can’t use it as my main DDM as I build valve amplifiers and I’m messing with voltages higher than 500v which it didn’t want to measure (no doubt there will be a way to measure them and I’ll have to check the destruction book to see). I’ve not spent any real time with it. I bought it on a whim when I got a refund for a camera for my bench scope.
Offline ornea
« Reply #1799 on: June 25, 2020, 08:50:18 pm »
Not my go to meter as it makes me work hard to get results but I can report it spent a night in torrential rain and after a drying session appears to be fine.
