I'm Backer To The Future #649.
How Time McFly's, so today I finally received my Dave-O-Meter, from Welectron.
The DHLorean just stopped by in front of Doc Franks house.
Was expected to appear much earlier in the past, but anyhow, now it's present, to often use it in the future.
It came flashing @ 1.21 GW, with unzippered EEVBLog1_22, so this Mc Fly is closed:
![](https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/?action=dlattach;attach=478823;image)
Then I hooked it up on High Voltage, to check its Lightning Rod capabilities, the DC and AC values turned out to be ok.
![](https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/?action=dlattach;attach=478829;image)
![](https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/?action=dlattach;attach=478835;image)
Biff Tanner (BT) is also polishing the data fine onto my mobile, and the 8 GB micro SD can biffer a lot of data.
The 1 MOhm range is quite noisy, and 10 MOhm is way off:
![](https://www.eevblog.com/forum/testgear/eevblog-121gw-discussion-thread/?action=dlattach;attach=478841;image)
let's wait until it cools down after the timely journey, maybe a little bit of calibration is required.
Greetings from Doc Frank
