Author Topic: EEVBlog 121GW Discussion thread  (Read 805198 times)
0 Members and 32 Guests are viewing this topic.
Offline Iagash
Re: EEVBlog 121GW Discussion thread
« Reply #475 on: March 28, 2018, 09:55:59 am »
With V1.10 I still see wrong voltage and current displays in certain parts of the measuring range, I see a spurious wrong decimal point in current display and I see wrong range display (A instead of mA) in the current display. All of this in DC VA-mode.
Apart from that the displayed values are consistently wrong.
On the meter display or the app display? (or both)
Only in the app, the meter is correct.
Does the SD card logged data show correct or incorrect readings?
I didn't try the SD-card since the log is of no use to me without timestamps.
I guess the invalid checksums must then be some electrical problem in my meter if no one else can see them.
Again, how are you validating your checksums? with your own software?
Yes with my own software, you have the raw readings in the post above, you could verify yourself.
Offline plexusTopic starter
« Reply #476 on: March 28, 2018, 07:01:20 pm »
I updated the meter to 1.10 and now the iphone app doesn't work. it connects (apparently) but there is no meter display in the app.
Any ideas? Fixes? Any idea when a real eevblog iOS app will be released?
Offline HKJ
    • Tests
« Reply #477 on: March 28, 2018, 07:28:36 pm »
The Bluetooth protocol changed, you have to use the correct application version (I do not know that yet, I am still waiting on my meter).
« Reply #478 on: March 28, 2018, 07:31:18 pm »
EEVBlog: any ETA on an iOS app?
Should I downgrade the firmware? Will that work? Any idea to what version? I use that app!
Offline Iagash
« Reply #479 on: March 28, 2018, 08:30:57 pm »
Anything < 1.10 should work, so I'd say use 1.07.
Offline EEVblog
« Reply #480 on: March 29, 2018, 02:54:11 am »
The Bluetooth packet changed as has been discussed on here.
We (EEVblog "we", not UEi) do not endorse nor have control over the UEi application that is currently on the iPhone store. We are not aware of if or when they are updating that.
David is starting working on the iPhone version shortly, we now have a mac setup to enable the compiler to do this.
The following users thanked this post: benst
« Reply #481 on: March 29, 2018, 03:15:27 am »
Thanks Dave that's good news. Looking forward to a spiffy iOS app.
Offline EEVblog
« Reply #482 on: March 29, 2018, 04:56:22 am »
In theory it's as easy as pressing Compile for iOS, but we have not done this before, so  :-//
« Reply #483 on: March 29, 2018, 05:01:26 am »
It's probably a good time to get into iOS if not just for the experience of it. Like it or not it is a significant market and it's likely a good iOS app will inspire meter sales. But remember, iOS users are used to a particular look and feel. Don't go all Android-y/Windoze on us.  :scared: :scared: :scared:
The following users thanked this post: benst, Ardutronic
Offline Brumby
« Reply #484 on: March 29, 2018, 06:24:57 am »
Sleek, stylish, streamlined - and it sets the parameters and tells the user what to do, because it knows best.
The following users thanked this post: bitwelder, The Soulman
« Reply #485 on: March 29, 2018, 06:35:44 am »
That's pretty much true of Apple.
But I think there is enough flexibility with the iOS UX framework that a flexible app could be designed.
Offline kory
« Reply #486 on: March 29, 2018, 09:20:15 am »
Dave thanks for the last update on these meters.  Since some people have cancelled and the meters have already been ordered, would it be possible to order more meters?
Also, it is well worth the wait for the bugs to be worked out, especially any hardware bugs.
Take care everyone!
Offline firstcolle
« Reply #487 on: March 29, 2018, 09:25:29 am »
Really really looking forward to get mine :)
thanks for all your work (Dave and all the forum users that helped to find, solve and test bugs!)
The following users thanked this post: 1anX
Offline VinzC
  • See you later, oscillator.
About changing the shipping address
« Reply #488 on: March 29, 2018, 09:56:47 am »
Hi Dave.
The survey link you posted in the Kickstarter comments section (Johnny B. Goode @ https://www.kickstarter.com/projects/eevblog/eevblog-121gw-multimeter/rewards/6297526/survey) to change the shipping address indeed doesn't work for me; it drives me back to kickstarter home page.
@all,
EDIT: No taking the audience for dummies, this is only for the sake of completeness.
I had to use the button «Show my contribution» (translated from French: «Afficher mon engagement»). That button stands to the right of «You are a contributor» and is visible once logged in and you're viewing the multimeter project. Then select the Survey tab. From there you can change your shipping address :-+ .
Otherwise use the kickstarter menu under your login icon on the top right corner of the page, click the EEVBlog multimeter and from there «Show my contribution».
Thanks for the update. I'm still looking forward to the postman knocking at my door ;-) .
 \$\Omega\$ sweet  \$\Omega\$ 8)
« Last Edit: March 30, 2018, 02:06:33 pm by VinzC »
Offline Cliff Matthews
    • General Repair and Support
« Reply #489 on: March 29, 2018, 11:43:19 am »
..a good iOS app will inspire meter sales.
Today's headlines: "Thousands of seniors and trendy spoon-fed millennials suddenly adopt electronics as a hobby"  :-DD
Offline Iagash
« Reply #490 on: March 29, 2018, 03:37:44 pm »
At the moment raw packet logging is not a feature of the app, I use debug outputs (in visual studio, with debug mode) to get the data.
I would still suggest you include the feature in your app.
It might be the linux bluetooth stack that is the reason for the errors, but it might also be some electrical problem with pullup/diode level shifter (R76/D4 in the schematic) in my (or others) meter. Maybe the resulting voltages are too narrowly specified.
With that feature more people could check easily if that's the case on more meters.
Offline Elasia
« Reply #491 on: March 29, 2018, 03:52:27 pm »
+1 for raw packet logging / debugging, it really comes in handy to eliminate possible failure modes when making protocols
Offline Candid
« Reply #492 on: March 29, 2018, 08:45:05 pm »
I re-checked with 1.10 and get the same results. Can someone confirm my measurements?
Why is the 121GW reading wrong in auto range/manual 5V range in this situation?
Can you reproduce the following measurements?
2.0V peak to peak sine wave 4kHz, No DC offset, duty cycle 50%. Both meters in AC mode. Firmware 1.07 on my 121GW with serial number EEVblog 000084
Auto mode on both meters, Fluke in highres mode:
121GW selects 5V range, reads 1.1133Vac
Fluke 28II selects 6V range, reads 0.7031Vac
manual mode on both meters:
121GW 5V range, reads 1.1133Vac
Fluke 28II 6V range, 0.7032Vac
121GW 50V range, reads 0.659Vac (and it looses the frequency measurement and displays 0.00kHz)
Fluke 28II 60V range, reads 0.663Vac
See the attached pictures.
Online Messtechniker
« Reply #493 on: March 30, 2018, 11:10:44 am »
Since the 121GW seems to have an UART, I'd like to know precisely
where to get at the UART signals.
Are these at Pin 122 on U4 for Rx and Pin 119 for Tx?
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
Offline darrellg
« Reply #494 on: March 30, 2018, 05:48:54 pm »
There is a schematic on the product page at https://www.eevblog.com/product/121gw/.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #495 on: April 02, 2018, 01:16:14 pm »
Finally conduct updating the firmware of my 121GW multimeter.
I am happy with the autorange speed.
https://youtu.be/6Y1KzSA-BUE
The following users thanked this post: dcac, 1anX, Dampmaskin
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #496 on: April 02, 2018, 04:05:37 pm »
I think I need to get better of improving video quality.
Offline coromonadalix
« Reply #497 on: April 02, 2018, 09:41:52 pm »
nice to see improvements like this :)
now Dave  design an bench meter version loll
Offline EEVblog
« Reply #498 on: April 02, 2018, 11:48:27 pm »
Sorry, but no, not at this stage.
Offline JustMeHere
« Reply #499 on: April 03, 2018, 12:19:22 am »
Oh can't wait. Need a new DMM.
