Author Topic: EEVBlog 121GW Bench Stand (3D Printed)  (Read 1129 times)
Offline snoozerTopic starter
  • Country: ie
« on: September 15, 2019, 01:40:12 pm »
thought I share my 121GW bench stand design in case others might find it useful. I wanted the angle a little lower then the original build in stand and since I am almost exclusively use it on the bench I also wanted it a bit wider to prevent accidental fall over. Have to add some rubber pads to the bottom to prevent it from slipping around but should be fine then.
Thingiverse link:
https://www.thingiverse.com/thing:3862923
Fusion 360 link:
https://a360.co/31q8WmW
Have FuN!
Jan P.
The following users thanked this post: Kean
Offline coromonadalix
Re: EEVBlog 121GW Bench Stand (3D Printed)
« Reply #1 on: September 15, 2019, 01:42:53 pm »
Nicely done  :-+
