Author Topic: HP-8591E video issue  (Read 581 times)
Offline lu8egbTopic starter
  • Country: ar
« on: December 06, 2018, 08:06:51 pm »
Hi everybody,
I wanted to ask about the HP-8591E analyzer to the HP experts.
Someone offered me this analyzer -mint condition indeed- that apparently has a video problem (I think).
I have had the opportunity to see the rig only a few minutes. I´ll try to describe the issue.
The equipment turn-on ok and accepts all the parameters of amplitude, span or frequency that are entered. However, at 3 or 4 seconds after switching on, the entire grassline "goes up" and it endeed compressed as a single line you can see at the top of the display, so that it is not possible to run any diagnostic routine.
After that, I was reading the service guide at assembly level repair to arrive at an indicative conclusion. There is some examples of common troubleshooting video problems, but not this case. I can see the video is processed at A16 module.
Any guideline or comments will be appreciated.
Thanks for watching.
