Author Topic: Lecroy options -=recovery=-  (Read 100756 times)
Offline figgie
Re: Lecroy options -=recovery=-
« Reply #275 on: April 08, 2024, 10:05:09 pm »
Anyone have 8.1.0.2 and/or any of the flavors between 8.0.1.2 and 8.8.0.5 in 64bit? Pm me!
8.1.0.1.
much obliged sir!
Offline figgie
« Reply #276 on: April 08, 2024, 10:07:42 pm »
already tried... all 64 bit software is showing the latest MAUI 10.X
Interesting, they have removed them since I looked last year. Possibly to prevent unlocking licenses by downgrading?
Have you tried if upgrading to versions 10.X works? For the older 32-bit scopes installing an older version officially supporting that scope first (for the drivers) and then upgrading to a later 32-bit function worked as far as I know.
I tried going to MAUI 10.6.x.. that version sees the 16 character keys but does not apply them. :(
Offline figgie
« Reply #277 on: April 08, 2024, 10:56:37 pm »
ok minor update...
8.1.0.1 - shows ONLY the 16 character options and the options work. Unfortunately, it does not show the 26 character options (either normally or in the svc menu). I am thinking from the documentation. 8.1.2.0 was a major release...
8.7.0.5 - shows both 16 character (legacy key) and 26 character. 16 character legacy keys though showing are not being applied unlike 8.1.0.1 (highest version tested at this point) with operational options on W7.
« Last Edit: April 08, 2024, 11:11:35 pm by figgie »
