Author Topic: East Tester ET5410 ET5420 ET5411 ET54 series - Software  (Read 27590 times)
Online ptluis
  • Country: pt
Re: East Tester ET5410 ET5420 ET5411 ET54 series - Software
« Reply #51 on: June 17, 2024, 12:59:17 pm »
hello  guys!
I buy  the last model dual load  ET5420A+   and detect  a fex of bugs  in the firmware and contact  the support of ET .
this send me  a hex file and  a application to update the firmware but all in chinese.
Have any of you ever updated the firmware?
the software  show all buttons in chinese or  unreadable characters and  i can't  upgrade.
this is the links  sed  by  the suport of ET
ET54A+_Boot升级流程English.pdf (452.96KB)查看/下载https://drive.263.net/link/fqukk0zII0snDzr/?link=fqukk0zII0snDzr
ET54A+.2334.020(150V).hex (870.06KB)查看/下载https://drive.263.net/link/JYOohoRH93OYiX6/?link=JYOohoRH93OYiX6
ET54A+电子负载升级V1.05.rar (1.37MB)查看/下载https://drive.263.net/link/4XXX6M2F5pAvaie/?link=4XXX6M2F5pAvaie
links expired, did you download the files? if yes can you post them here?
Btw, can you connect both channels in parallel without any problems?
Hello, we are currently trying to learn about the update process of the ET44XX and ET45XX lcr-meters.
https://www.eevblog.com/forum/testgear/east-tester-et4410-desktop-lcr-meter/msg5542409/#msg5542409
I would like to do some comparisons with the ET54XX electronic load. Did anyone download that update files and could share them?
The user never posted or sent the files to me, so can't help you. One thing I advise all owners of these units is to check connection on the binding posts. Most of them come loose and if that's the case you will get voltage drop readings deceiving you on the real results. I own both ET5410A and ET5420A and they act defective because of that. After tight good all binding posts this units are working fine.
Offline Tiedix
« Reply #52 on: July 16, 2024, 09:55:15 am »
Hi there,
I own the EastTester ET5411 and have the same problem when trying to connect the ET4511 via USB/ com3 to a PC: "ET5410" do not match answer: "ET5411,V1.02.2034.029,09432030024,V1.11.2034.002" (there is no ET5411 in the search socket of the TestController SW).
On April 30iest, 2023 you posted, that you succeeded in editing the IDstring.
How did you do that?
Your help would be greatly appreciated
Offline HKJ
    • Tests
« Reply #53 on: July 17, 2024, 01:14:50 pm »
Hi there,
You find a definition file for simllar ET devices and this.
#metadef
#idString ET5411,
#name  East Tester ET5411
#handle ET5411
#port     com
This will only work if the file already contains #metadef statements and the defined profile basically match the device (This will often be the case with similar devices from the same manufacturer). There is ways to modify the actual definition conditionally based on the #metadef used as can be seen in a lot of the definition files.
If a file do not have a #metadef, it is easy to add.
Before the first line starting with # add #meta and somewhere before that add a #metadef, then other #metadef can be added before that.
