Author Topic: East Tester ET4410&ET4510 Desktop LCR Meter  (Read 49179 times)
thephil and 1 Guest are viewing this topic.
Offline w.v.s.
Re: East Tester ET4410&ET4510 Desktop LCR Meter
« Reply #325 on: June 29, 2024, 12:54:03 pm »
I have just connected the front panel of the ET4410 to the rest of the ET4510....
It's still an ET4410, as we suspected it's up to the front panel whether you have an ET45 or ET44.
And the serial number is also stored in the front-panel, right?
Offline Martin72Topic starter
  • Testfield Technician
« Reply #326 on: June 29, 2024, 12:54:50 pm »
Pics...
ET4410 Front with ET4510 Signalboard and vice versa.
The readings are slightly different when you change the boards, which makes sense in terms of calibration, that's what I noticed, but I hadn't photographed it now.
(Kierkegaard)
The following users thanked this post: w.v.s.
« Reply #327 on: June 29, 2024, 12:58:19 pm »
Yes.
(Kierkegaard)
Offline w.v.s.
« Reply #328 on: June 29, 2024, 01:43:03 pm »
I can confirm:
DISPLAY:PAGE?
MEASurement
DISPLAY:PAGE?
.STSTem
DISPLAY:PAGE STSTem
exec success
DISPLAY:PAGE SYSTem
exec err
But I also get errors when I try to combine that with 4410 or 4510.
« Last Edit: June 29, 2024, 01:47:24 pm by w.v.s. »
Offline pope
« Reply #329 on: June 29, 2024, 02:25:56 pm »
Pics...
The very first thing I did on mine, when I received it, was to take the lid off and snap this zip-tie that holds the mains cable and the data wires together.
After that, I turned it on for the first time  ;D
Offline w.v.s.
« Reply #330 on: June 29, 2024, 03:55:42 pm »
And I discovered something else, but first take pictures.
Ready, when you are! :)
« Reply #331 on: June 29, 2024, 04:00:06 pm »
I had already mentioned this in the picture post:
There is a small deviation from the displayed measured value when you swap the signal boards with each other, which probably has something to do with the (internal) calibration.
If you pair the same to the same again, the measured values are the same as before.
I will probably take detailed pictures of the circuit boards today, then reassemble the two so that they are ready for the "shoot out", because:
My next LCR device arrived today, but I wasn't at home, so I got it Monday. 8)
« Last Edit: June 29, 2024, 04:02:23 pm by Martin72 »
(Kierkegaard)
Offline w.v.s.
« Reply #332 on: June 29, 2024, 05:18:45 pm »
Did you calibrate before doing the measurements? I think the tolerances are on the main board, while calibration data is probably stored on the display board.
« Reply #333 on: June 29, 2024, 05:47:29 pm »
No, that should show the difference when you swap the boards.
(Kierkegaard)
« Reply #334 on: June 29, 2024, 06:50:43 pm »
Here are 2 reduced images, a folder with zoomable images can be found here:
https://drive.google.com/drive/folders/1hC-yNHRm7UwpRnx4ql7qrWrp0SjIWgxk?usp=sharing
(Will be deleted in 2 days)
(Kierkegaard)
The following users thanked this post: james38
Offline w.v.s.
« Reply #335 on: June 29, 2024, 07:24:19 pm »
Thank you! The neighborhood of JP600 looks a little dirty.
« Reply #336 on: June 29, 2024, 09:20:24 pm »
Pinouts of the 4-pin ports of the two controllers, according to the datasheet.
(Kierkegaard)
Offline w.v.s.
« Reply #337 on: June 29, 2024, 09:28:41 pm »
I don't have JTAG experience or equipment, but if somebody has, the memory in the 0x20000xxx area seems to contain interesting information, including the model. Would be interesting to dump that. But it is RAM and I don't know when it's written there and when it is evaluated.
« Reply #338 on: June 29, 2024, 09:45:40 pm »
I have a J-Link mini EDU and no experiences, time to learn more.
SW-DIO and SW-CLK are the "native" assignments, but they can also be UART RX/TX by the program.
(Kierkegaard)
Offline james38
« Reply #339 on: June 30, 2024, 12:18:51 am »
I took a look at the diodes D600/D601 on the mainboard on the N32G455 chip.
I don't know if this has been discussed before, but mine is missing, while Martin's is there.
D600 is understandable and goes to pin 26 (BP0)
D601 has a line that goes under the chip, no idea where and also to pin 53 (PB14).
Perhaps an approach.
EDIT:
I just got the information from my colleague that his ET4410 has the diodes in it.
The only difference is that he has a Musttool and not an Easttester.
So the diodes here have another unknown function.
« Last Edit: June 30, 2024, 07:24:54 pm by james38 »
« Reply #340 on: June 30, 2024, 07:59:50 pm »
At first I would say that these are clamp diodes, i.e. some kind of protective function.
(Kierkegaard)
Offline james38
« Reply #341 on: June 30, 2024, 08:44:14 pm »
Yes, it certainly looks like that.
I just looked at the differences between the N32G455 and the N32G457 in the data sheet.
They are essentially the same.
Only the N32G457 has the following functions, which are not used in the LCR:
- 1x 10/100M Ethernet interface
- digital video (DVP) interface
I think depending on chip availability they used the 457 when the 455 was not available.
Here is a list of the components on the mainboard that I could identify as a reference.
U100 16 Pin HJ4053    High-Speed CMOS Logic Analog Multiplexer and Demultiplexer
U102 16 Pin HJ4053    High-Speed CMOS Logic Analog Multiplexer and Demultiplexer
U201  8 Pin TL072C    (DIP TL07xx Low-Noise FET-Input Operational Amplifiers)
U200  8 Pin MS8052M   250MHz Rail-to-Rail Output CMOS Operational Amplifiers
U300  8 Pin SGM3003   Ultra Low ON-Resistance, Low Voltage, SPDT Analog Switch
U301  8 Pin SGM8052XS 250MHz, Rail-to-Rail Output, CMOS Operational Amplifiers
U302 10 Pin SGM3002   Low On-Resistance, Low Voltage, SPDT Analog Switch
U303 16 Pin HJ4051    High-Speed CMOS Logic Analog Multiplexer and Demultiplexer
U304 16 Pin HJ4051    High-Speed CMOS Logic Analog Multiplexer and Demultiplexer
U305 16 Pin HJ4051    High-Speed CMOS Logic Analog Multiplexer and Demultiplexer
U403  8 Pin MS8052M   250MHz, Rail-to-Rail Output, CMOS Operational Amplifiers
U404  8 Pin MS8052M   250MHz, Rail-to-Rail Output, CMOS Operational Amplifiers
U408  8 Pin MS8052M   250MHz, Rail-to-Rail Output, CMOS Operational Amplifiers
U409 16 Pin HJ4051    (8-CHANNEL ANALOG MULTIPLEXERS/DEMULTIPLEXERS)
U410 16 Pin HJ4051    (8-CHANNEL ANALOG MULTIPLEXERS/DEMULTIPLEXERS)
U1   LQFP 64 Nation N32G457/N32G455 Front
U600 LQFP 64 Nation N32G455 Mainboard
N32G455 series based on 32-bit ARM Cortex-M4F kernel, run up to 144MHz, support floating-point unit and
DSP instructions, up to 512KB embedded flash, 144KB SRAM, 4x12bit 4.7Msps ADC, 4xOPAMP, 7xCOMP,
2x1Msps 12bit DAC. Integrates multi-channel U(S)ART, I2C, SPI, QSPI, USB and CAN communication
interfaces, 1x SDIO interface and built-in cryptographic algorithm hardware acceleration engi
N32G457 series based on 32-bit ARM Cortex-M4F kernel, run up to 144MHz, support floating-point unit and
interfaces, 1x SDIO interface, and built-in cryptographic algorithm hardware acceleration engi
Differenz zum 455:
1x 10/100M Ethernet interface, digital video (DVP) interface
« Last Edit: June 30, 2024, 09:04:30 pm by james38 »
The following users thanked this post: Martin72, w.v.s.
Offline w.v.s.
« Reply #342 on: June 30, 2024, 10:31:24 pm »
Just ordered a ST-Link V2 (the slow way) to be ready, if something interesting happens on these jumpers close to the MCUs.
These tools might help with doing the talking.
https://github.com/etet100/stlink-n32g455
Have a nice week!
« Reply #343 on: June 30, 2024, 10:57:36 pm »
I have now ordered this:
JST Micro 4pin
(Kierkegaard)
« Reply #344 on: July 01, 2024, 09:44:57 am »
Big Boy arrived.... 8)
(Kierkegaard)
The following users thanked this post: egonotto, thm_w, coromonadalix
Offline w.v.s.
« Reply #345 on: July 01, 2024, 10:36:22 am »
 8) Looking forward to your report!
« Reply #346 on: July 01, 2024, 01:46:32 pm »
Less than 24 hours later they were already there.
And......Fits. 8)
(Kierkegaard)
Offline w.v.s.
« Reply #347 on: July 01, 2024, 04:31:02 pm »
Nice so see that the 4X10 stuff has still some attention after the arrival of the "big boy" :)
« Reply #348 on: July 01, 2024, 04:37:16 pm »
Of course, I'm still interested in whether we can make progress or not. :D
(Kierkegaard)
Online coromonadalix
« Reply #349 on: July 01, 2024, 07:35:39 pm »
why not  loll    to see almost identical HW, and finding  the itsy tiny bit who could help / change ........
yep big boy it is  :-+  form 100 khz 200 300 500  1MHz  ....
« Last Edit: July 01, 2024, 07:37:22 pm by coromonadalix »
