How easy is it to update?
Now that I know how to do it, it went quickly...
I received the update tool with the new firmware and copied the folder to the desktop.
Then I proceeded as follows:
-copied MSCOMM32.OCX and pasted it into the updatetool folder.
-Pressed the Windows key+X, then selected Powershell (Administrator).
-Changed to the updatetool folder and entered "regsvr32 MSCOMM.OCX".
-Powershell terminated.
-In the Device Manager, set the COM port settings to 19200 baud.
-Also set to 19200 baud on the ET4510 using the "Set" button.
-Start update tool, load hex file, set COM port.
-Set to
and then switched the ET4510 off and on again.
-The flash process starts, after 100% the ET4510 restarts itself.
Is it still in Chinese
Yes, there is no other version avaible, maybe in the future.
