Author Topic: East Tester ET4410&ET4510 Desktop LCR Meter  (Read 48181 times)
Offline w.v.s.
Re: East Tester ET4410 Desktop LCR Meter
« Reply #250 on: June 22, 2024, 03:52:59 pm »
Thank you for the update. I'm looking forward to your report.
Have a nice weekend, everyone!
The following users thanked this post: egonotto, Martin72
Offline james38
« Reply #251 on: June 22, 2024, 06:25:44 pm »
The audience is waiting, only the guest isn't there ;-)
I'm very excited about the 4510 model, especially
because we're now in the fortunate position of being able to make a direct comparison.
OK, the weather looks good for barbecuing right now ;-)
Have a nice weekend.
Online egonotto
« Reply #252 on: June 22, 2024, 07:45:24 pm »
Hello,
Amazon (https://www.amazon.de/Tisch-LCR-Messger%C3%A4t-Desktop-LCR-Bridge-Widerstandsmessger%C3%A4t-Impedanzanalysatoren-Kapazit%C3%A4tsmessger%C3%A4te/dp/B0D6GCTSKQ) says: "Package Dimensions 3 x 2 x 1 cm; 3.5 kg". There must be a component from a neutron star inside :)
Best regards
egonotto
« Last Edit: June 22, 2024, 07:47:13 pm by egonotto »
Online Martin72Topic starter
  • Testfield Technician
« Reply #253 on: June 22, 2024, 07:49:42 pm »
 :-DD
Not that I have to put on a radiation protection suit to pick it up....
(Kierkegaard)
Offline w.v.s.
« Reply #254 on: June 24, 2024, 04:30:58 pm »
Already put on your protection suit? Customs office might be closing soon :)
« Reply #255 on: June 24, 2024, 05:05:46 pm »
Here we go... ;)
Teardown will follow on the next weekend, maybe sooner.
(Kierkegaard)
The following users thanked this post: egonotto, thm_w, james38
Offline w.v.s.
Re: East Tester ET4410&ET4510 Desktop LCR Meter
« Reply #256 on: June 24, 2024, 05:55:51 pm »
Thank you! What is the firmware version of the new device and does it show the list bug?
« Reply #257 on: June 24, 2024, 06:16:13 pm »
I can do it right away.
However, I had no problem with the list function back then:
https://www.eevblog.com/forum/testgear/east-tester-et4410-desktop-lcr-meter/msg3989009/#msg3989009
(Kierkegaard)
« Reply #258 on: June 24, 2024, 06:43:39 pm »
Yepp, the bug exist on the ET4510... ;)
(Kierkegaard)
The following users thanked this post: egonotto, james38, w.v.s.
« Reply #259 on: June 24, 2024, 08:23:05 pm »
Correction, pictures will follow at the weekend, I did have a look inside earlier.
Well, what do you think? ;)
(Kierkegaard)
Offline w.v.s.
« Reply #260 on: June 24, 2024, 08:25:33 pm »
Thank you. I assume they share the same board and the same main-firmware and that the display-board(-firmware) and maybe something in the memory of the main-board memory, that is not covered by that update, differs. But we will know more, when you find the time to look inside.
You might ask aliexpress for a fix for the list bug for the 4510. I would bet that you get the same data, we've already seen.
« Last Edit: June 24, 2024, 08:28:41 pm by w.v.s. »
Offline w.v.s.
« Reply #261 on: June 24, 2024, 08:27:32 pm »
What's printed onto the board? ET44.M.V1.31?
« Reply #262 on: June 24, 2024, 08:29:15 pm »
Detailed pictures will follow, but what I could see just now was an absolute identity... 8)
Edit: It´s a ET44 V1.7 board from 2022, board version from my ET4410 is V1.6 from 2021.
I have already written to East Tester, if nothing comes back I can also try Aliexpress.
« Last Edit: June 24, 2024, 08:32:11 pm by Martin72 »
(Kierkegaard)
Offline w.v.s.
« Reply #263 on: June 24, 2024, 08:32:27 pm »
Nice, cross-changing the display unit is definitely  on my wish list for your weekend :)
« Reply #264 on: June 24, 2024, 08:35:59 pm »
Ah, that makes sense.
The difference will be there, while the signal board is the same.
Good idea, I'll try it out.
(Kierkegaard)
The following users thanked this post: thm_w, w.v.s.
« Reply #265 on: June 25, 2024, 01:05:03 pm »
They sent me something this morning (firmware), but I won't be able to see exactly what until this evening.
(Kierkegaard)
« Reply #266 on: June 25, 2024, 07:25:32 pm »
List function ? Fixed... 8)
« Last Edit: June 25, 2024, 07:27:05 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: egonotto, thm_w, w.v.s.
Offline w.v.s.
« Reply #267 on: June 25, 2024, 08:17:43 pm »
Oh, this firmware is newer than what we already know. Can you share the data? Would be interesting to see the differences.
« Reply #268 on: June 25, 2024, 08:26:25 pm »
Sure, why not...
(File is from 08.06.2024)
(Kierkegaard)
The following users thanked this post: w.v.s.
Offline pope
« Reply #269 on: June 25, 2024, 08:58:51 pm »
Sure, why not...
Thanks for sharing. How easy is it to update? Is it still in Chinese and all the procedure that was described here has to be followed or it's more straightforward?
« Reply #270 on: June 25, 2024, 09:20:32 pm »
Now that I know how to do it, it went quickly...
I received the update tool with the new firmware and copied the folder to the desktop.
Then I proceeded as follows:
-copied MSCOMM32.OCX and pasted it into the updatetool folder.
-Pressed the Windows key+X, then selected Powershell (Administrator).
-Changed to the updatetool folder and entered "regsvr32 MSCOMM.OCX".
-Powershell terminated.
-In the Device Manager, set the COM port settings to 19200 baud.
-Also set to 19200 baud on the ET4510 using the "Set" button.
-Start update tool, load hex file, set COM port.
-Set to ??? and then switched the ET4510 off and on again.
-The flash process starts, after 100% the ET4510 restarts itself.
Yes, there is no other version avaible, maybe in the future.
« Last Edit: June 25, 2024, 09:22:55 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: egonotto, pope
Offline pope
« Reply #271 on: June 25, 2024, 10:05:20 pm »
Thank you Martin, much appreciated!
BTW, can I use the USB port to do the update? I'm sure it has been discussed but unfortunately haven't got the time go through the whole thread yet.
« Reply #272 on: June 25, 2024, 10:10:34 pm »
Two more things....
Before using the LIST function, you should make sure that the measuring speed is set to SLOW.
If it is set to FAST, you have almost the same effect as with the bug before, quasi random values are listed.
There is no question that it was a bug that was fixed with the new firmware.
With the old firmware, the "Sequence" mode did not work properly (it always ran through instead of stopping after the 10th measuring point).
Second:
That was the answer from East Tester a few days ago when I asked them and only had the ET4410.
Yesterday I described the problem with the ET4510 and got an answer the morning after - that's very commendable.
This gives me hope for a possible support of my new toy from East Tester, which is already on its way and could replace the two ET44/4510. 8)
Edit:
This thread isn't that big that you can't have time for it...
But I just about remember, it must be the RS232 port.
« Last Edit: June 25, 2024, 10:13:58 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: egonotto, thm_w, pope
Offline w.v.s.
« Reply #273 on: June 25, 2024, 10:44:38 pm »
I've also observed doing sweeps with SCPI, that the first value received after switching parameters was pretty useless.
The update-software on the windows-side was identical to the one we already know?
« Reply #274 on: June 25, 2024, 11:10:58 pm »
Yes...
(Kierkegaard)
