Author Topic: East Tester ET4410&ET4510 Desktop LCR Meter  (Read 46321 times)
Online Martin72Topic starter
  • Testfield Technician
Re: East Tester ET4410 Desktop LCR Meter
« Reply #225 on: June 13, 2024, 08:16:39 pm »
It stays that way, even if you let the program run for minutes - I still can't see what it says.
The fact is, the program only continues to run when you switch the ET4410 off and on again.
Then a few lines appear, the status bar remains at 0% and perhaps it also says why this is the case.
But I just can't read it.
EDIT:
Aha!!!
The status bar is filling up, I'll write why in a moment.
« Last Edit: June 13, 2024, 08:20:41 pm by Martin72 »
(Kierkegaard)
« Reply #226 on: June 13, 2024, 08:35:48 pm »
Something is still missing...
The status bar has filled up, then something will be written.
But it doesn't seem to be switching off and on again, because I still have a black screen.
Anyway, you can apparently start this routine again and again.
Why did it continue?
You have to click on the field under the ???? field, then something happens.
(Kierkegaard)
« Reply #227 on: June 13, 2024, 08:46:03 pm »
Something has to be done afterwards, see 2nd picture.
Because when I switch off/on now, it stays dark.
EDIT:
In james38's post it says that the device reboots by itself after a few minutes.
I have waited 10 minutes and nothing happens...
Crap. :(
« Last Edit: June 13, 2024, 09:06:59 pm by Martin72 »
(Kierkegaard)
Offline w.v.s.
« Reply #228 on: June 13, 2024, 09:24:54 pm »
You have to click on the field under the ? ? ? ? field, then something happens.
As far as I understand, that is for pausing the upgrade. I'm not sure why one would like to do that.
« Reply #229 on: June 13, 2024, 09:30:16 pm »
But otherwise nothing happens, you have to press the button twice, otherwise the state bar won't start.
I now also believe that my disconnection from the mains has nothing to do with the current status because the system was put into a "waiting state" beforehand.
i also don't understand why nothing is displayed in chinese, even though i have downloaded and installed the language pack for windows 10.
(Kierkegaard)
Offline KungFuJosh
  • TEAS is real.
« Reply #230 on: June 13, 2024, 09:33:16 pm »
Make sure the fonts are active.
Offline w.v.s.
« Reply #231 on: June 13, 2024, 09:39:52 pm »
I think you'll see the Chinese, when you have traditional Chinese as your language settings. I would only try this with an extra user, because I cannot use windows blindly enough to perform all operations in Chinese and then switch back to English. I don't find other [2] in the setup strings than that mentioned earlier. So I guess the strings may be stored in some unicode and I would have to find into that in order to extract the right strings and display them.
« Last Edit: June 13, 2024, 09:43:06 pm by w.v.s. »
Offline w.v.s.
« Reply #232 on: June 13, 2024, 09:57:01 pm »
The following users thanked this post: coromonadalix, Martin72
Offline james38
« Reply #233 on: June 14, 2024, 03:02:30 am »
In order to display the program correctly under Windows,
I simply selected Chinese (Simplified China) under "Language" as shown in the picture below.
Edit:
The base language remains German (or English, depending on what is set as the main language) and it will not be switched to Chinese.
As you can read below, apps check whether the language is installed and use it if it is available.
« Last Edit: June 14, 2024, 11:21:01 am by james38 »
« Reply #234 on: June 14, 2024, 02:56:43 pm »
Everything done, but the menu of the update programme and most of the messages remain unreadable.
The text file in the folder is also indecipherable.
And so I could beat myself up at the moment... :o
Earlier the LCR was alive again, something I did made the flashing take 347 seconds and the device started itself.
But it showed the old firmware and so I started again....
....And I have a dark screen again..... |O
If I can somehow fix it, I'll leave it like this, no matter how great the new firmware is.
(Kierkegaard)
Offline coromonadalix
« Reply #235 on: June 14, 2024, 04:37:01 pm »
Does not inspire confidence in this brand .....
« Reply #236 on: June 14, 2024, 05:24:48 pm »
It's almost not the brand's fault, except that perhaps the tools should be adapted for the rest of the market.
Good news, I've got it again....
You start the tool, click on the "???" area - and then switch on the device.
Then everything happens automatically.
But I don't have the new firmware version.
EDIT: Filename of the firmware is wrong
« Last Edit: June 15, 2024, 04:49:41 pm by Martin72 »
(Kierkegaard)
Offline w.v.s.
« Reply #237 on: June 14, 2024, 06:34:59 pm »
Glad to read, that it seems to be rather robust, at least.
Have a nice weekend, everyone!
The following users thanked this post: egonotto, coromonadalix, Martin72
« Reply #238 on: June 14, 2024, 07:25:30 pm »
I have extracted the exe. file of the tool (with Uni-extract), maybe someone can do something with it:
https://drive.google.com/drive/folders/1ZPBc9Df7ZjhOaKCm4Pl2RnXrERZjSoUn?usp=sharing
seems to be something in Delphi/Borland, but I'm not familiar with it.
(Kierkegaard)
Offline w.v.s.
« Reply #239 on: June 14, 2024, 11:06:55 pm »
Yes, I've also read Delphi several times in the firmware program. And these are the last strings, which I found:
754774:FileVersion
754800:1.10.1905.2
754830:InternalName
754866:LegalCopyright
754906:LegalTrademarks
754950:OriginalFilename
754994:ProductName
755030:ProductVersion
755060:1.0.0.0
755082:Comments
755110:LastCompiledTime
755144:2014-06-25 12:07:39
755190:VarFileInfo
755222:Translation
So we probably deal with a 10 year old program. But i did not identify unicode data in the interval, in which I would mainly expect for Chinese characters (4E00-9FFF), neither i did not find the string "Flash" so far.
« Last Edit: June 15, 2024, 08:25:23 am by w.v.s. »
Offline w.v.s.
« Reply #240 on: June 15, 2024, 12:47:46 pm »
This looks like a interesting range to look for strings:
Offline w.v.s.
« Reply #241 on: June 15, 2024, 12:49:52 pm »
And this decoding looked promising at a first glance, but the translator could not make much sense of it and it appears to contain plenty of Korean letters, too:
« Reply #242 on: June 15, 2024, 02:11:56 pm »
Translator here ??
ask terra operative ?  he's from japan and may know some .. or some people ?
« Last Edit: June 15, 2024, 02:14:15 pm by coromonadalix »
« Reply #243 on: June 15, 2024, 02:22:42 pm »
Translator here ??
Nah, Terra is an Aussie living in Japan.
Might have Japanese wife iirc
Some stuff seen @ HQ cannot be shared.
Offline w.v.s.
« Reply #244 on: June 15, 2024, 02:41:38 pm »
Japanese won't help much, here, i guess. The software should be Chinese language. The Japanese adopted the Kanji from China a long time ago and we had a Chinese guy in a Japanese class, who struggled barely less with the Japanese Kanji than the German students.
Offline KungFuJosh
  • TEAS is real.
« Reply #245 on: June 15, 2024, 03:41:46 pm »
The mixing of language probably means font issues, not combination of languages.
Yes, Japanese and Chinese do share a set of characters, but not all the meanings are the same. More complex words are supposedly more different, but I don't know more than a few Japanese words.
Offline w.v.s.
« Reply #246 on: June 15, 2024, 04:25:17 pm »
Not everything in that range are strings. So it can be absolute nonsense, that might contain something meaningful, if we are lucky. But i was happy to find some encoding setting, that at least looked partially Chinese to me.
« Reply #247 on: June 15, 2024, 04:47:56 pm »
Here you can see that everything is in Chinese, including the "strange characters" in the tool itself.
Somehow this does not work with Windows 10, with the complete language pack usage:
https://www.eevblog.com/forum/testgear/east-tester-et4410-desktop-lcr-meter/msg5524615/#msg5524615
Thanks to the post, however, I have also discovered that the new firmware is installed on my ET4410:
Quote from: james38
Contrary to the version in the file name, the correct version that is inside is: V6.00.2405.039
My version before flashing(Unit bought 07/2023):
V6.00.2136.018
So it worked after all. :-+
(Kierkegaard)
The following users thanked this post: james38, KungFuJosh
Offline james38
« Reply #248 on: June 16, 2024, 12:42:26 am »
Congratulations, Martin.
You should now get the correct values ​​in the list menu,
which was the bug fix.
It's good that you didn't give up, because we now know
that even if the flash process failed, you can repeat it by repeating the process.
The only thing is that the flash tool itself is very difficult to use.
« Reply #249 on: June 22, 2024, 03:28:59 pm »
The ET4510 has arrived today....
....But I wasn´t at home. :P
Then it's Monday and I have to bring some money with me (customs). ;)
(Kierkegaard)
