Author Topic: East Tester ET4410&ET4510 Desktop LCR Meter  (Read 44368 times)
Online Martin72Topic starter
  • Testfield Technician
Re: East Tester ET4410 Desktop LCR Meter
« Reply #125 on: December 25, 2023, 11:36:24 am »
Finally, I tested whether it was due to my device - it's not, Testcontroller finds it without any problems.
(Kierkegaard)
Offline Andrey_Ak
  • Country: kz
« Reply #126 on: December 25, 2023, 12:28:41 pm »
It works for me:
« Reply #127 on: December 25, 2023, 01:04:42 pm »
Hm,
You also have a com port displayed, but the program can't find anything for me...
Which OS do you have? I am running Win10.
(Kierkegaard)
Offline Andrey_Ak
  • Country: kz
« Reply #128 on: December 25, 2023, 01:10:09 pm »
When starting the program, I can select any COM port.
Windows 7 x64  v.6.1.7601
« Reply #129 on: December 25, 2023, 01:43:15 pm »
Aha... :D
@All:
If I use the compatibility mode for win7, then it works!
The colors in the illustration are somewhat unfortunate, perhaps this can be changed.
But it works perfectly and the ET4410 is recognized and displayed without any problems.
(Kierkegaard)
Online JohanH
« Reply #130 on: December 25, 2023, 01:44:17 pm »
Got the program working in wine after "winetricks allfonts". Set a COM1 port in the registry.
Still can't access the device. I can select COM1 in the program.
I can't find any specs if it requires a specific port speed. Tried also swapping RX and TX on the cable but no go.
Offline w.v.s.
« Reply #131 on: December 25, 2023, 02:30:47 pm »
This is how my program looks like (at least mine shows more contast  :-DD ):
Left plot is time series for primary measured value, next to it a histogram of that value.
First line: Time, last measured primary value, average and standard deviation.
Second line: Selection of primary unit, measured secondary value, real part of impedance, imaginary part of impedance.
Third line: Selection of secondary unit, frequency.
Not the best C++ coding style. Currently running with 22.04.1-Ubuntu. Also talks with GPIB, LXI, and some USB devices.
Offline coromonadalix
« Reply #132 on: December 25, 2023, 03:24:44 pm »
but man    i hate all the black  thingy / fashion / trend,   way too hard to see,    use light gray  instead,  if your room get too dark or darker in a sense, you loose the contrast effect and almost see nothing ??
black is not for me  loll  even on instruments front panels ...
kudos
Offline Andrey_Ak
  • Country: kz
« Reply #133 on: December 25, 2023, 03:31:11 pm »
Aha... :D
@All:
Why does your interface look prettier than mine?
I have a question mark after the value "ROUT".
All the selection fields are curved, the colors are also different.
And I can't change the value of the "ROUT" value, there are 100 and 30 ohms, I can choose but they don't change on the device, it always shows 100 ohms.
« Reply #134 on: December 25, 2023, 04:13:18 pm »
No idea, I´ve changed nothing.
And me a "0" instead of  \$\Omega\$, makes ist not better.
Now you´ve mentioned, same here... :(
I have examined the exe file with Uni-Extract, the LCR programme itself is written in Delphi, perhaps something can be changed/corrected there.
(Kierkegaard)
Offline pope
« Reply #135 on: December 25, 2023, 06:22:41 pm »
This software looks pretty hopeless to me :)
Offline MathWizard
« Reply #136 on: December 25, 2023, 08:43:26 pm »
So as they are built right now, what's capping the max frequency at 100kHz ? Say you wanted to extend it to 1 or 10MHz, would much have to be added or changed ? Someone would have to hack the MCU or whatever's in itm to add the extra range.
I'm interested in trying that with my LCR meter, but I'm over my head with the MCU.
« Reply #137 on: December 25, 2023, 09:05:08 pm »
It won't work that easily.
I had drawn a part of my ET4410 as a circuit diagram and if I remember correctly, the circuit corresponds exactly to the one on the left side(lower corner) of this picture:
For frequencies above 100kHz it becomes much more complex, simply increasing the frequency is not enough, the whole circuit has to be adapted/replaced.
It's not worth it.
On the contrary, I started with the circuit diagram to find out how to optimize the existing circuit so that it works up to 100kHz, because I have my doubts that it does.
Edit: Pic taken from the Impedance Measurement Handbook (Agilent):
https://wiki.epfl.ch/carplat/documents/rcl_agilent.pdf
« Last Edit: December 25, 2023, 09:21:30 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: thm_w, MathWizard, w.v.s.
Offline w.v.s.
« Reply #138 on: January 04, 2024, 10:42:22 pm »
Did a small face lift on my ET4410. Might appear boring, but I did not like the look of that orange  ;D
Proper red would also be acceptable but was not on stock.
Offline thm_w
  • Non-expert
« Reply #139 on: January 04, 2024, 11:32:48 pm »
Received the ET4410
Internals are basically the same as the ones Martin posted other than the micro. Instead of STM32F103 we have a more powerful N32G455. Though the meter is probably running the same code for the most part. The UI front panel uses N32G457.
Parts seen:
- N32G455 144MHz 32-bit 5MSPS ADC, 1MSPS DAC
- SGM3003 analog switch
- MS8052M high speed 5V 250MHz op-amp
The factory CAL routine mentioned above (hold SET when powering on) requires: 1.4k, 4.64k, 15k, 47.5k, 174, 25.5, 6.81, 2.05, and "standard impedance" whatever that is.
To disassemble:
- Remove two large philips head screws at the back of the case
- Remove the tilting bale by rotating it, then pop out
- Sheet metal case will slide off
edit: jlink can connect to the N32G455RE, but of course the flash is locked so no easy way to read it out.
« Last Edit: January 05, 2024, 12:06:38 am by thm_w »
The following users thanked this post: james38
Offline w.v.s.
« Reply #140 on: January 04, 2024, 11:38:33 pm »
Received the ET4410
If your device is still open: Did you look if there is any activity on the through-holes for the front-usb, where no connector is mounted?
« Last Edit: January 04, 2024, 11:40:52 pm by w.v.s. »
Offline thm_w
  • Non-expert
« Reply #141 on: January 05, 2024, 12:24:06 am »
There is an unpopulated connector JP2 + U10 at the top, presumably goes to the GPIB connector on the back. JP3 is SWD port. Then JP5 which is right above the USB hole, has 5V, Gnd, then two other pins that presumably go to the 32G457 OTG port. But there is no activity or voltage on the two middle pins, so I don't think any connection is implemented in the software its running.
Offline thm_w
  • Non-expert
« Reply #142 on: January 05, 2024, 12:42:42 am »
For whatever reason HPOT output has some distortion on it whereas HCUR signal does not. I guess when they are connected its normal so it doesn't matter?
Output is:
- 2V at 10kHz and 1.8V at 100kHz with no load.
- 0.67V and 0.57V with 50R load.
« Last Edit: January 05, 2024, 12:52:49 am by thm_w »
Offline w.v.s.
« Reply #143 on: January 05, 2024, 09:56:21 am »
Thank you for checking this!
Offline mawyatt
« Reply #144 on: January 05, 2024, 03:04:05 pm »
Output is:
HPOT and LPOT are LCR Meter Signal High Z Sensing Inputs, HCUR is the Drive Signal Output Source and LCUR is the Drive Signal Sink, usually at virtual ground as forced by a Transimpedance amplifier.
Best,
~Wyatt Labs by Mike~
Offline james38
« Reply #145 on: May 30, 2024, 06:12:02 am »
i have found an interesting Blog where some tells about an Issue in the Scan-List with the ET4410
and that he got an FW Upgrade.
It is in chinese so you must translate it via Google.
https://blog.zeruns.tech/archives/774.html
The Url for the Upgrade is pan baidu but there ist also
an alternate URL on the page  where you can download it without pan baidu.
https://www.123pan.com/s/2Y9Djv-ZCcvH.html
I have not tested it but maybe its interesting for someone.
« Last Edit: May 30, 2024, 09:34:51 pm by james38 »
The following users thanked this post: thm_w, Martin72, w.v.s.
Offline w.v.s.
« Reply #146 on: May 30, 2024, 08:59:39 am »
I've tried to decode the hex-file, assuming that the :10 lines contain 16 bytes of data each and
have a 211392 bytes binary file now. It may not be correct, yet. But it does not seem to be encrypted, because I see familiar strings:
ET4510"X
,A/x
PARAMETER)
MODEi
STAT))
P<LIS
list
LEVEL
VOLTAGz)
OURC
VERSIONx
REMOTP
LOCA
FAI'
9(?b
IMMEDI,
BEEPER)
TNSYSTECy
 4(x
COMVALU
AUTO
RANGu1)
EQUI
IMPEDANC
DEVi
FUNCTION
I was also glad to the "ET4510" string in the ET4410 firmware. I am guessing, that the target location for that data might be 0x8004000. The :02 seems to give the coarse location of a block and the characters 4 to 7 of the :10 the fine address within that block.
In the meantime, I've learned that this is a intel format for hex-files and well documented. So not much need for guessing here.
« Last Edit: June 02, 2024, 01:26:55 pm by w.v.s. »
Offline w.v.s.
« Reply #147 on: May 30, 2024, 09:03:16 am »
SYSTEM
 4401
4402
4410
4501
4502
4510
these are used for some switch/case:
           ;-- switch:
│           0x08015584      dfe800f0       tbb [0x0801558c]            ; switch table (6 cases) at 0x8015588
            0x08015588      .char 3
            0x08015589      .char 8
            0x0801558a      .char 13
            0x0801558b      .char 18
            0x0801558c      .char 23
            0x0801558d      .char 28
│           ;-- case 0:                                                ; from 0x08015584
│           ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│           0x0801558e      19a1           adr r1, 0x64                ; "4401"
│        ; 0x80155f4
│           0x08015590      01a8           add r0, var_4h
│           0x08015592      eff73ef8       bl fcn.08004612
│       ┌─< 0x08015596      18e0           b 0x80155ca
│       │   ;-- case 1:                                                ; from 0x08015584
│       │   ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│       │   0x08015598      18a1           adr r1, 0x60                ; "4402"
│       │                                                              ; 0x80155fc
│       │   0x0801559a      01a8           add r0, var_4h
│       │   0x0801559c      eff739f8       bl fcn.08004612
│      ┌──< 0x080155a0      13e0           b 0x80155ca
│      ││   ;-- case 2:                                                ; from 0x08015584
│      ││   ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│      ││   0x080155a2      18a1           adr r1, 0x60                ; "4410"
│      ││                                                              ; 0x8015604
│      ││   0x080155a4      01a8           add r0, var_4h
│      ││   0x080155a6      eff734f8       bl fcn.08004612
│     ┌───< 0x080155aa      0ee0           b 0x80155ca
│     │││   ;-- case 3:                                                ; from 0x08015584
│     │││   ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│     │││   0x080155ac      17a1           adr r1, 0x5c                ; "4501"
│     │││                                                              ; 0x801560c
│     │││   0x080155ae      01a8           add r0, var_4h
│     │││   0x080155b0      eff72ff8       bl fcn.08004612
│    ┌────< 0x080155b4      09e0           b 0x80155ca
│    ││││   ;-- case 4:                                                ; from 0x08015584
│    ││││   ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│    ││││   0x080155b6      17a1           adr r1, 0x5c                ; "4502"
│    ││││                                                              ; 0x8015614
│    ││││   0x080155b8      01a8           add r0, var_4h
│    ││││   0x080155ba      eff72af8       bl fcn.08004612
│   ┌─────< 0x080155be      04e0           b 0x80155ca
│   │││││   ;-- case 5:                                                ; from 0x08015584
│   │││││   ; CODE XREF from fcn.0801556c @ 0x8015584(x)
│   │││││   0x080155c0      16a1           adr r1, 0x58                ; "4510"
│   │││││                                                              ; 0x801561c
│   │││││   0x080155c2      01a8           add r0, var_4h
│   │││││   0x080155c4      eff725f8       bl fcn.08004612
│   │││││   0x080155c8      00bf           nop
« Last Edit: May 30, 2024, 01:05:12 pm by w.v.s. »
Offline w.v.s.
« Reply #148 on: May 30, 2024, 09:04:25 am »
ELEC
 V6.00.2405.039
 %s,%s,%s,%s,%s
)FhF
)FhF
Offline w.v.s.
« Reply #149 on: May 30, 2024, 09:08:10 am »
0Hz
10Hz
30Hz
100Hz
120Hz
200Hz
400Hz
800Hz
1kHz
2kHz
4kHz
8kHz
10kHz
15kHz
20kHz
30kHz
40kHz
50kHz
80kHz
100kHz
