Author Topic: East Tester ET4410&ET4510 Desktop LCR Meter  (Read 42201 times)
Gertjan and 5 Guests are viewing this topic.
Offline Martin72Topic starter
  • Testfield Technician
Re: East Tester ET4410 Desktop LCR Meter
« Reply #100 on: November 11, 2023, 08:03:45 pm »
ET3501 100kHz $580
It looks really grown up, but Aliexpress shows me a price of over 1000€, plus the note that delivery to my country is not possible.
Offline MegaVolt
  • Country: by
« Reply #101 on: November 11, 2023, 08:58:37 pm »
ET3505    500 kHz
ET3501    100 kHz
« Reply #102 on: November 11, 2023, 09:30:39 pm »
Yes, that is known, there is also a 1Mhz model - And they all look the same, if you are referring to the picture showing a 3505. ;)
Offline NickNacl
« Reply #103 on: November 13, 2023, 04:09:21 pm »
There is a calibration routine in the settings, this is accessed by holding down the SET button I think when turning on. Any more info on this would be appreciated. Thats if anyone dare calibrate it, i daren't as I don't have the values required.
Offline w.v.s.
« Reply #104 on: November 13, 2023, 04:27:51 pm »
Thank you for the hint. I so far only tried the open+short calibration.
« Reply #105 on: November 13, 2023, 08:47:25 pm »
Thank you for the hint, NickNacl!
Indeed, when pressing the "Set" button while powering on, a secret menu appears...
...But not in english. ;)
To our chinese members: Could anyone of you translate this and post it here? Thanks !!
Edit: or confirm that the google translations is correct.
« Last Edit: November 13, 2023, 09:27:57 pm by Martin72 »
Offline w.v.s.
« Reply #106 on: November 13, 2023, 09:54:06 pm »
At least a Greek letter near Arabic numbers in a Chinese menu seems to challenge google translate  :-DD
Offline thm_w
  • Non-expert
« Reply #107 on: November 16, 2023, 12:03:59 am »
hm "project" field sounds suspicious?
ET3501 100kHz $580
The 3501 is $550 here: https://www.aliexpress.us/item/1005004523242097.html
But its a too bulky for me to consider 3.6kg, at least the 45xx is fairly compact can easily be picked up by hand.
Another seller sold me the 4510 for $190 but has not shipped, so I won't recommend them yet: https://www.aliexpress.us/item/1005001645307071.html Do not use this seller, they asked for more money and never shipped.
You can take another $20-30 off these prices using coupons.
« Last Edit: November 22, 2023, 09:23:56 pm by thm_w »
Offline NickNacl
« Reply #108 on: November 16, 2023, 09:27:43 pm »
i just used google translate. my tester went out of calibration so i tried to recal it but it is still way out.
I have not seen an english menu yet, neither is this cal routine documented. I was trying to find a reset key, but this popped up.
Offline Andrey_Ak
  • Country: kz
« Reply #109 on: December 20, 2023, 03:42:36 am »
Hello. I have a similar LCR meter, only RuoShui 4091C.
As I understand it, their hardware is almost the same as ET4410.
https://www.youtube.com/watch?v=y_8pZtPALrc#t=21m
When I was choosing which one to take, i liked RuoShui 4091C more, it is
somehow more solidly made.  It seemed to me to be of higher quality.
What software on the computer can be used with them by connecting via RS232?
Offline w.v.s.
« Reply #110 on: December 20, 2023, 10:15:40 am »
Hello,
congratulations! What VID and PID does it show when connected by USB?
You could probably use that software https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
If you are running linux, I have some work-in-progress software, which also has some library for talking to ET4XXX. If someone is interested, I can share some info and sources.
Offline pope
« Reply #111 on: December 20, 2023, 10:25:03 am »
Did you sort it out?
Offline w.v.s.
« Reply #112 on: December 20, 2023, 10:30:48 am »
That one seems to support the frequency, level and offset variation in small steps like the more expansive ET45XX, but at the lower price level of the ET44XX. Interesting!
« Last Edit: December 20, 2023, 10:33:08 am by w.v.s. »
Offline pope
« Reply #113 on: December 20, 2023, 10:51:50 am »
Where did you find the 4091C cheaper than the ET4510? I got the ET4510 for a bit less than 300euro (exc. customs). Should be here next week.
Offline w.v.s.
« Reply #114 on: December 20, 2023, 11:47:42 am »
[/quote]
Sorry, that look was too quick. I duckducked for the 4091C and found a hit on aliexpress, but I did not see that it was a multi-variant offer and only looked at the price. But that was for the VC4090A.
The following users thanked this post: pope
Offline pope
« Reply #115 on: December 20, 2023, 11:51:35 am »
[/quote]
Yeh, that's. tricky one on aliexpress. Sometimes they show a pic of some expensive equipment for $20 and you end up buying some cable or something...
Offline Andrey_Ak
  • Country: kz
« Reply #116 on: December 23, 2023, 04:50:13 pm »
I bought a 4091C in June 2023 for $345 with shipping.
https://aliexpress.ru/item/1005006148682738.html
Official manufacturer's page with documentation:
https://www.victorruoshui.com/products/lcr-meters
« Last Edit: December 23, 2023, 05:50:07 pm by Andrey_Ak »
Offline Andrey_Ak
  • Country: kz
« Reply #117 on: December 23, 2023, 05:22:57 pm »
Only sometimes 4091C sell fake ones.
On them, the label is on top and not on the bottom and the power button is round and not square, here is an example of a fake:
The following users thanked this post: MegaVolt
Offline Andrey_Ak
  • Country: kz
« Reply #118 on: December 23, 2023, 05:29:16 pm »
Hello,
Hello!  What commands can I try in the TestController interface?
« Last Edit: December 23, 2023, 06:08:40 pm by Andrey_Ak »
« Reply #119 on: December 23, 2023, 05:32:45 pm »
You can try the scpi command list I´ve uploaded for the ET44xx series:
https://www.eevblog.com/forum/testgear/test-equipment-et4410/msg4086994/#msg4086994
Offline JohanH
« Reply #120 on: December 23, 2023, 07:12:59 pm »
This looks like the East Tester or Mustool (that I have). They have round power button. It's not necessarily a "fake". I guess they are just relabeling them and chassis look a little different.
Offline Andrey_Ak
  • Country: kz
« Reply #121 on: December 25, 2023, 04:28:26 am »
Hello!
I requested from the manufacturer a program for controlling the RuoShui 4091C LCR meter in English:
https://www.eevblog.com/forum/testgear/east-tester-et4410-desktop-lcr-meter/msg5231736/#msg5231736
Here is the link:   https://tis.kz/temp/LCR_setup_Eng.zip
« Last Edit: December 25, 2023, 04:52:59 am by Andrey_Ak »
The following users thanked this post: thm_w, Martin72
« Reply #122 on: December 25, 2023, 10:54:05 am »
It´s the same I´ve received from East Tester - But now in english.
And now I can understand the failure message.. ;)
Offline JohanH
« Reply #123 on: December 25, 2023, 10:58:33 am »
Can't get it to find the font in wine (tried to install it to multiple places). Ah, well, don't really need it though.
« Reply #124 on: December 25, 2023, 11:23:58 am »
I would like to choose a serial port first - but you can't do that.
The pop-up window next to the "Connect" button is empty.
Then I looked in the setup.ini, there is a line com id =1.
OK, my ET4410 is com5, so I changed the 1 to a 5, started, nothing.
Then the other way round, changed the comport in the device manager, from 5 to 1, then unpacked the program again, started - nothing.
Always the message that you have to select a port first, which you can't do.
Garbage.
Edit: It works now.
« Last Edit: December 25, 2023, 01:39:08 pm by Martin72 »
