I took a few more pictures.
It doesn't look too bad.
Martin,
That's the kind of SMD Fixture that can cause issues!
It has no internal shield partition between the H and L sections. This will cause errors with small Cap measurements (high Z) as the internal fields change with plunger location on the moving end. This will be aggravated by the ET35 since its H and L sections are reversed which means the moving plunger end is the "hot" H end whereas the normal LCR Meter orientation has the moving plunger on the "cold" L side.
Also we found this type with the two end screws on the cover use a thinner aluminum case/cover and powder coat paint the entire case and cover without any masking. This may cause less than ideal shielding between the cover and case which makes contact thru just the 2 end screws.
The other (better) type SMD Fixture we have has 4 screws to hold the cover and uses threaded inserts in the cover.
The cover you have looks like it might be sturdy enough tho, might want to ream the holes in the cover to remove the paint coating and get good contact with the 2 screws to case.
The case looks as if it's only relying on the BNC washers to puncture the paint coating to tie to the cover, this may require removing the BNCs and cleaning away the paint coating around the BNC holes for better contact.
Also check the Plunger outer cases, these form a somewhat coaxial conductor with the plunger, you want these to be firmly connected to the cover which must make a good connection the case to get back to the BNCs.
Remember to check the brass threaded rods that make contact with the plungers, ours arrived loose and it took awhile before we discovered this "surprise"!!!
Anyway, looks like you might have some reworking ahead to get this SMD Fixture up to standards for precision LCR measurements with the ET35!!! After getting things in order our modified SMD fixture has good repeatability even up to 8MHz, so these can be "coached" with a little effort into a good fixture for precision measurements.
Keep us posted on your progress.
BTW are you sure you have a cold, or just "skipping work" to have time to play around with this stuff
Best,
