My Agilent DSO-X 3034A arrived earlier in the month and it took until today to get a DSOXLAN module for it. The scope is running v2.36 firmware as has been the case for recent folks. It's been a pleasure to use so far, and I'm looking forward to unlock a little extra potential.
For the purpose of exploring v2.36, here is some details (for the complete file listing, see attached FileList.txt):
Directory of \Secure\infiniiVision
01/01/86 12:04a <DIR> web
01/01/86 12:04a <DIR> fpga
10/10/07 06:45p 46624 System.Drawing.dll
10/10/07 06:45p 214552 mscorlib.dll
05/05/13 09:21a 82432 Agilent.Cdf.Api.Licensing.dll
05/05/13 09:21a 160256 Agilent.Cdf.Api.Lxi.dll
05/05/13 09:21a 85504 Agilent.Cdf.Api.Security.dll
05/05/13 09:21a 28160 Agilent.Cdf.Api.SystemManagement.dll
05/05/13 09:21a 163840 Agilent.Cdf.Api.dll
05/05/13 09:21a 9216 Agilent.Cdf.Core.Lxi.Web.ComServer.Interop.dll
08/24/12 03:16p 238080 OpenNETCF.dll
05/16/13 08:43p 13312 WebPageData.dll
08/24/12 03:16p 398336 SetupConverter.exe
01/01/86 12:04a 1152032 splashImage.bin
08/24/12 03:17p 251392 dnssd_CE.dll
08/24/12 03:17p 355840 libcups2.dll
08/24/12 03:17p 83968 libcups2backend.dll
09/13/13 11:10a 215040 vncServer.exe
08/24/12 03:20p 21504 websockify.exe
09/13/13 11:17a 17312416 infiniiVisionCore.dll
09/13/13 11:10a 12104 infiniiVisionLauncher.exe
09/13/13 11:10a 180736 infiniiVisionWebCom.dllThe infiniiVisionCore.dll is the same size (in bytes) as the previous v2.35 release, however the
two files are different.
The bytes previously mentioned to patch at location 0x277e50 are not there. My best guess (just by comparing, and noting the same sequence of bytes) is that they are now at 0x277e30.
I patched the bytes at 0x277e30, and setup the USB boot key as per the instructions here. I tried 3 different USB keys: SanDisk Cruzer 2GB, Kingston DataTraveler 4GB, Transcend 32GB. All were USB 2.0 drives, and formatted FAT32.
None of these drives worked. During boot, groups of LEDs on front of the scope would flash in sequence and after a short while the scope would restart and try again. Removing the USB drive, the scope would boot as normal.
I am not sure if I patched the infiniiVisionCore.dll correctly as it is different to v2.35. I have uploaded the .dll here. I hope a more knowledgeable person could look at it and provide some comments. If more files are needed, just let me know. @
plesa @
abyrvalg hoping you guys might be able to take a look.
Reading back through the thread, people have had success with:
"a podunk 4G USB stick I got from Digikey"
SanDisk Extreme USB 3.0 16GB
Kingston 4GB microSD with adaptor
DaneElec 2GB SD with cheapo USB card reader
Integral 8GB
Hoping I will not have to downgrade --- I will keep trying with other USB drives...
Sparky
