So - I've been a little busy, but as promised - the permanent mod for the 3000T series. - Tested on 3000XSeriesT.7.10.2017042905.ksx
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
After some testing, I found out that the registry edits to the regdb wasn't needed and all the mod takes is a exe, that call the infiniivisionlauncher.exe with our commandlines.
As I am no programmer, I found a source code in the CE sdk to do the job, compiled a exe and deleted the lnk in the startup folder, placing the exe here and copying the full infiniivisionlauncher.exe to the secure folder, as all exe's in the startup folder will be launched and as a result creating the "bootloop" problem.
I have created a zipfile with the needed exe's, a readme file and a script to do the job of copying.
The script will also copy a backup of cal-data to the usb stick, as I had a incident during all this testing, where the scope reported it gone, sp just to be safe.
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
Use it at your own risk! - But I have done quite some testing using the script, after reflashing firmware and no problems.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
EDIT:
New version of the mod available for the 3000T Series - Tested on 3000XSeriesT.7.10.2017042905.ksx!
After a couple of PM's from Pinkus, I have modified the application to read the commands from a textfile for easy modification.
Futhermore the application will check for existing infiniivision.lnk and infiniiVisionLauncher.exe in the \Secure\Startup folder and delete if any, as to avoid a bootloop situation after a system update.
(I will advise to remove the mod prior to updating just to be safe, but anyway)
Also if no command.txt is found, a new will be created with a default option of "-l all".
As always - Use it at your own risk!REMOVED ATTACHMENT FOR REVISION OF README
