As usual Ian is here to help. My opinion is that you should keep that in case something goes terribly wrong and one of the "lab rat" scopes we are trying to mod dies irreparably.
:TheSteve
As you are saying, going to 350/500 Mhz is indeed a very good upgrade. A tempting one at least. From my position I can tell you I'm not doing the mod necessarily for me, as I'm doing it for the community. I learned a lot from the community and there's a time to give something back.
If we find a way to determine the capacitor/inductors values and I manage to procure 4 Teledyne relays, I'm willing to try the mod to 1Ghz.
The easiest way would be someone with a 1Ghz scope do these measurements so we compile the BOM. Otherwise it would be a hit and miss operation for determining the right values.
As a side note for all interested parties.. Moving the K503 relay into the K501 position requires hot air desoldering.. I would add that to the BOM to swap it as
desoldering and resoldering might have unknown consequences as the part is rated at maximum 5s 250degrees reflow. These are specified as flux resistant but non-cleanable inside.
