Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1568178 times)
inse and 20 Guests are viewing this topic.
Offline Estaxe
Understood, thank you!
Offline PioB
Does someone have the firmware 7.50 for the 3000T as downloaded from keysight that they could share with me by any chance? ( 3000XSeriesT.7.50.2021102830.ksx )
Thank you very much in advance.
Thank you very much Boppeldibop!
« Last Edit: January 06, 2025, 01:44:14 pm by PioB »
Offline BillCRM
  • Country: cn
More proper test of 500MHz mod using tektronix cg5011 calibrator:
Rise time at about 600-640ps which means about 550MHz bandwidth.
Still triggering at 1GHz time mark signal.
Amplitude and frequency measurements both accurate.
I'm very satisfied with this mod!
Offline PioB
So I went over the thread, went back, went back some more and I have the general recipe for modifying the firmware figured out:
1 unzip ksx file (7zip, izarc https://www.izarc.org/, it's a cab )
2 copy nk.bin.comp to other directory
3 bincompress /D nk.bin.comp nk.bin_tobepatched
4 patch nk.bin_tobepatched
5 bincompress /C nk.bin_tobepatched nk.bin.comp
6 md5sum nk.bin.comp
7 modify install.xml
45c45
<               <file checksum="originalChecksum">nk.bin.comp</file>
>               <file checksum="newChecksumFromStep6">nk.bin.comp</file>
78a79,95
>                       <action>continue</action>
>               </onFailure>
>       </installStep>
>       <installStep>
>               <command>\windows\cmd.exe /c ren \Secure\Startup\infiniivision.lnk infiniivision.lnk.original</command>
>               <onFailure>
>                       <filePath>\usb\errorLog.txt</filePath>
>                       <message>No factory lnk to move away.</message>
>               </onFailure>
>       </installStep>
>       <installStep>
>               <command>\windows\cmd.exe /c copy \usb\infiniivision.lnk \Secure\Startup\infiniivision.lnk</command>
>               <onFailure>
>                       <message>lnk copy from USB failed.</message>
>                       <!-- continue, without new valid link file -->
8 repack directory to cab file with https://www.izarc.org/
9 rename cab to ksx
10 copy to memory stick
11 add infiniivision.lnk to root of memory stick with
90#"\Program Files\infiniiVision\infiniivisionLauncher.exe" -l D3000BDLA -l SCPIPS -l WAVEGEN
update firmware
Boom!
Now I still have to work out how to find the exact locations for the patch (and how to get the checksum.
A long time ago I got the version 7.50 for the 3000T, patched and there the locations are
0x0DD19FB 99 69 -> FE 67
0x127929F 04 00 A0 E1 -> 00 00 A0 A3
0x12F4C9B B4 F1 93 E5 -> 01 00 A0 E3
I tried my hardest to find over what "area" the checksum is taken, why exactly _this_ address needs to change from 04 to 00, and why the third edit is there.
Unfortunately, I haven't come across the "understanding" yet, I tried importing the file into ghidra, but arm v8 little endian 32 seems not to be the expected architecture, ghidra complains a lot about there not being instructions... so even a hint on a correct set of paramenters would help. Binwalk gave me a long list of "file consists of html headers, pictures, program code" and if I let it split up the file (of the un- and the patched 7.50) , I found one file where the md5 differed and in there were the modifications, but I am not sucessful analyzing that file, either.
So some hint on how to understand step 4 would be appreciated, so I can pull it off on the newer firmware :)
Thank you very much everyone that put in the work! I
« Last Edit: January 07, 2025, 09:01:27 pm by PioB »
The following users thanked this post: dl250, BillCRM
Offline BillCRM
  • Country: cn
I think the final solution about hacking this might still be a licence generator, and I believe someone in China had already done this and made some money from it. So if there's a high level hacker could figure out how to generate the licencce and make a software, then there's no need to mod every firmware versions.
Offline wp_wp
  • Country: cn
V2.66
04 00 A0 E1—>00 00 A0 E3
F0 59 FF EB—>01 00 A0 E3
checksum:
0x25EF95EF->0x25EF943E
Turn on it,research it,change it.
                              ——wp_wp
Offline wp_wp
  • Country: cn
Actually,the 0x0DD19FB 99 69 -> FE 67 is 99 69 08 3F->FE 67 08 3F,this is the Record[172] checksum.
You should focus on the change of infiniivisioncore.dll.
These two changes actually are modifying the infiniivisioncore.dll.
                              ——wp_wp
Offline wp_wp
  • Country: cn
For 3000T V7.65 Firmware nk.bin
04 00 A0 E1->00 00 A0 E3
B4 F1 93 E5->01 00 A0 E3
0A 96 34 3F->6F 94 34 3F
                              ——wp_wp
Offline Bud
Not much useful info without addresses.
Offline PioB
I have something for 3000T, version 7.50, two diff files as proposed by Bud here: https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg5764693/#msg5764693
The version 7.50 is a bit older and used just as a test whether the md5sums of the individual files work out, and they seem to
$ md5sum nk.bin.comp 750_p/nk.bin.comp
3d064ba7f3f8352f44fbb0ba12d24bff *nk.bin.comp
3d064ba7f3f8352f44fbb0ba12d24bff *750_p/nk.bin.comp
$ md5sum install.xml 750_p/install.xml
93bda73729736e3416a65947d7075be2 *install.xml
93bda73729736e3416a65947d7075be2 *750_p/install.xml
Prerequisites: cygwin, bsdiff, bspatch
nk_bin_comp_3k_7_50diff.bz2 remove extention .7z
oszicab.ddf.txt remove extention.txt
install_patch.txt use as is
/cygdrive/c/Windows/System32/expand 3000T.7.50.2021102830.ksx -F:* .
patch install.xml install_patch.txt
bspatch nk.bin.comp  nk.bin.compnew nk_bin_comp_3k_7_50diff.bz2
rm nk.bin.comp
mv nk.bin.compnew nk.bin.comp
/cygdrive/c/Windows/System32/makecab /F oszicab.ddf
I made the patches with
diff 750/install.xml 750_p/install.xml > install_patch.txt
and
bsdiff 750/nk.bin.comp 750_p/nk.bin.comp nk_bin_comp_3k_7_50diff.bz2
cabs expanded with:
in 750/ I have the unmodified patches
in 750_p I have the patched version I got from a kind member back in '21
Hope that helps, size of total files is <8 kb
Unfortunately the above changes without addresses didn't work out:
V2.66
checksum:
40897 entries found: 04 00 A0 E1—>00 00 A0 E3
1 entry @ 0x00FED26B: F0 59 FF EB—>01 00 A0 E3
checksum:
"0 entries found": 0x25EF95EF->0x25EF943E
48705 entries found: 04 00 A0 E1->00 00 A0 E3
43 entries found: B4 F1 93 E5->01 00 A0 E3
0 entries found: 0A 96 34 3F->6F 94 34 3F
« Last Edit: January 13, 2025, 08:59:15 pm by PioB »
The following users thanked this post: Bud
Offline wp_wp
  • Country: cn
V2.66
checksum:
Actually
EF 95 EF 25->3E 94 EF 25
                              ——wp_wp
Offline wp_wp
  • Country: cn
When I investigate the 3000T,I find that there is no need to do the first change.
So the modification should be more easier.
« Last Edit: January 13, 2025, 02:57:32 pm by wp_wp »
                              ——wp_wp
Offline wp_wp
  • Country: cn
Actually,for V2.66,there is no need to post the addresses.
« Last Edit: January 13, 2025, 03:08:52 pm by wp_wp »
                              ——wp_wp
Offline PioB
V2.66
checksum:
Actually
checksum:
1 entry @ 0x00D42137 0x25EF95EF->0x25EF943E
So is the 04 00 A0 E1 -> 00 00 A0 E3 @ 0x00FC3A9B? (cf comparison in attached png?)
So to understand better what I am looking for:
I were to understand the file structure of the nk.bin better, it would be evident? What architecture do I need to tell Ghidra to load the file with? arm v8 little endian 32 bit leads to "bad instructions, garbledmess"
If I search for "infiniivisioncore.dll" i find that string at 0x012A4126, which is after all the above addresses, so that doesn't seem to be the start of the file.
I admit, I am not yet that deep in my understanding of how the nk.bin is structured :-[
Offline msuthar
  • Country: in
For 2.66   ../dump/infiniivisioncore.dll   also asks for  ../dump/coredll.dll.
.text:40DB1000 ; Processor           : ARM
.text:40DB1000 ; ARM architecture: metaarm
.text:40DB1000 ; Target assembler: Generic assembler for ARM
.text:40DB1000 ; Byte sex            : Little endian
nk.bin uncompressed open in 10 editior
Options Patch
00FC3A9B 04 change it to 00
00FC3A9C 00 change it to 00
00FC3A9D A0 change it to A0
00FC3A9E E1 change it to E3
Nag Patch (corrected address)
00FED26B 05 change it to 01
00FED26C 59 change it to 00
00FED26D FF change it to A0
00FED26E EB change it to E3
Checksum Patch
in file data.txt
Original Un Patched:
Record [168] : Start = 0x81114000, Length = 0x005615C8, Chksum = 0x25EF95EF
Patched :
@Record [168] : Start = 0x81114000, Length = 0x005615C8, Chksum = 0x25EF943E
10 editor: for nk.bin
Select > Select Range > Select Start [D42137]  Size [5615C8]
Tools > CheckSum > Checksum-UByte(8bit)
 Chksum = 0x25EF943E   is shown in reverse order in nk.bin is there before at start of data block Record[168]
locations in nk.bin
00D42137 EF change it to 3E
00D42138 95 change it to 94
00D42139 EF change it to EF
00D4213A 25 change it to 25
73
« Last Edit: January 15, 2025, 03:18:19 pm by msuthar »
The following users thanked this post: analogRF, Sigi_cz
Offline PioB
Hi MSuthar, thank you! I tried implementing all the info I had so far, but if I went with the info given above: The nag patch is at 0x00FED26B , you have written "0x00EFD26B" ?
And are my cab options
;*** MAKECAB Directive file
.Set Cabinet=on
.Set Compress=on
.Set CabinetName1=2k_266_patched.ksx
.Set MaxDiskSize=CDROM
correct?
I tried to work through this yesterday and got a message saying that the update went wrong and the scope was booting of the standard firmware.
Little by little...
Thank you very much!
« Last Edit: January 15, 2025, 07:10:30 am by PioB »
Offline hk4sva@gmail.com
  • Country: co
    • https://www.qrz.com/db/HK4SVA
Hello and thank you very much for the help.
Could someone confirm where I downloaded the nk.bin files for the MSO-X 3014A because the following LINK seems to be out of service?
Download firmware v2.35 from here:
https://cal.equipment/doc/HP_Agilent_Keysight/DSOX/
Thanks
Offline PioB
There's a link on
https://salvagedcircuitry.com/2000a-nand-recovery.html with a bunch of firmwares:
https://salvagedcircuitry.com/docs/2000a-nand-recovery/2000a-3000a-firmware.zip
This website was tremendously helpful in getting started down the dsox rabbit hole 👍
Offline PioB
Standing on the shoulders of giants.
Here's the diffs to patch the recipe.xml and the nk.bin.comp for the 2000 series.
/cygdrive/c/Windows/System32/expand 2000XSeries.02.66.20240123001.ksx -F:* .
patch recipe.xml 2k_266_recipe_patch.txt
mv nk_bin_comp_2k_266diff.bz2.7z  nk_bin_comp_2k_266diff.bz2
bspatch nk.bin.comp  nk.bin.compnew nk_bin_comp_2k_266diff.bz2
rm nk.bin.comp
make a cab file with Cabpack 1.4, chose MSZIP. *
(Files to add, the same as were there in the first place:
recipe.xml
FPGA2000A.bin
FPGA3000A.bin
updateBootLoaders2.exe
cleanupFileSystem.exe
xloader_image.bin
u-boot_image.bin
pboot_rel.bin
p500_ddrdriver.bin
envVars.txt
auxInstallStep.exe
LGPL.COPYRIGHT.TXT
nk.bin.comp
infiniiVisionSetup.cab
move .cab to .ksx
Add the .ksx and any of the infiniivision.lnk files to the root of the memory stick
eg
88#infiniivisionLauncher.exe -l MSO -l BW20 -l DIS -l PLUS -l SCPIPS -l VID -l CABLE --perf
enjoy
Thank you very much to everyone that helped me in understanding the mechanics (addresses and contents) of the patch.
The inner workings, I need to work my way through them as well, the _understanding_ of the file is still elusive. I hope at some point it'll fall into place. I'll probably be back with more questions on my way up the mountain, a sincere thank you very much! :)
*https://www.softpedia.com/get/File-managers/CabPack.shtml
« Last Edit: January 15, 2025, 08:45:30 pm by PioB »
The following users thanked this post: tru3533, analogRF, Sigi_cz, onesystem
Offline FrancescoChino
    • https://www.eevblog.com/
Have anyone the compiled driver of the Spear600  for Windows 10?
Thank you
Have you the spear600 driver compiled for Windoes 10?
Tahnk you
Francesco
Offline onesystem
As per this amazing post, I am trying to use spearload to revive DSOX2024A.
Made some progress while waiting for a LAN adapter, which ended up making getting one redundant. ::) ....
$ spearload -t spear600 p500_ddrdriver.bin u-boot_image.bin
spearload: opening device...
spearload: sending DDR driver p500_ddrdriver.bin...
spearload: sending firmware u-boot_image.bin...
But in my case, when I run the spearload program, I get the following error:
C:\spearload>spearload -t spear600 p500_ddrdriver.bin u-boot_image.bin
spearload: read_file: p500_ddrdriver.bin: could not read: Invalid argument
spearload: could not read DDR driver file
So my question is: is there anyone here who would be so nice to share their working copy of spearload.exe program, for a Windows machine?
My oscilloscope is experiencing a corrupted file which causes it to reboot constantly, all the way after booting into running screen (see image).
I am sure there is more to handle after I load the u-boot, but it is not accessible - I only get into p-boot if I hold space bar on power-on.
Offline ShQ
  • nonplussed
That's a known bug with that version of spearload :palm: you can grab the updated one here and that should work properly! I've updated that original post now too to point to it, since you are not the first to run into this.
The following users thanked this post: onesystem
Offline onesystem
Thanks! I tried the pre-made .exe version and it was giving usblib error, so I built one from source on my pc, usblb error stopped, but this one is coming up:
spearload: st_find: could not find suitable USB device for VID = 0483, PID = 7261
spearload: device not found, is it powered on and in recovery?
I checked my computer settings and it does list the usb device with VID = 0483, PID = 7261. Is there something else I need to do? - I tried every USB port, and made sure nothing else is plugged in.
Offline onesystem
Ok. So with help of ShQ I was able to get the spearloader.exe to work, but I am unable to get into u-boot prompt no matter how much I keep that space bar pressed.
Really, what I am trying to handle - is the error at the end of this log:
U-Boot 2010.03 (May 18 2017 - 11:28:22)Agilent P500
CPU:   SPEAr600
DRAM:  128 MiB
Flash: 512 KiB
NAND:  internal ecc 128 MiB
Debug serial initialized ........OK
RTC: 2022-2-8   1:40:39.69 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Oct 29 2015 01:
39:04
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
RTC: 2022-2-8   1:40:39.73 UTC
 Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXXOOOOOOOOOXOOOOXOXXOXOXXOXOXOXOXXXXOOXXX
OOOOOOXXOXXOXXXXXXOOOXXXOXXOOOXXXOOOXOOXOOXXOOXOXOOOOXOXOOOOOXOOOXOOXOXOXOXXXXXO
XXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOXOOOXOOX
OOOOXXXOOOOXOOXOOXOOOOOOOOOXOXOOOXOOOOOOXOXOOOOOXXOOOOOOOXOXOXXOOXOXOOOXOOOXOOXO
XXXOXOOOXOXXXXOXOXXOXXXXXOXOXXOOOXXXOXXXXXXOXXXXXXOXXXXOXOXOXOOOXXXXOXXXXXOOOXXO
XXOOXXOX
XXOOXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOXXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXXXOXOOOXOXOOXOOXXXXXXXXXXXXOXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1ACA724, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000  Length=0x1ACA724  Name="" Target=RAM
 Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
RTC: 2022-2-8   1:40:43.19 UTC
Launching windows CE image by jumping at address 0x  362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar  8 2013 at 17:05:33
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Feb 27 2019)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000  size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
 OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200  (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
-EDeviceLoadEeprom 00:30:D3:21:F2:AD
Phy found addr 31 (ticks=3387)
WaitForLink Start (ticks=3389)
No Link (ticks=4391)
<--EDeviceInitialize
GMAC DMA status register = 0x0
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
Running infiniiVisionInstallHelper
Failed to start/configure network.
Device load time:
   NANDFLASH: 0 ms
   SNANDFLASH: 0 ms
SHIM DLL, LoadRealDll [PalIO.dll] for [AgilentPalIO.dll]
SHIM [AgilentPalIO.dll] Get Process Addresses
Our command line is
Performing Startup
SHIM DLL, LoadRealDll [PalSStorage.dll] for [AgilentPalSStorage.dll]
SHIM [AgilentPalSStorage.dll] Get Process Addresses
Released build, Feb 27 2019, 20:34:05
Initializing FPGA...
FPGA Type: Idaho
Ver: 2.027 Released
Build Time: Tue Oct 13 16:48:05 2015
Build Machine: TS2404M
No option module detected
Keyboard firmware version 32... ok
Keyboard Info: Board id 7, Board rev 2
Startup sequence is complete.
Saved configuration invalid
SHIM DLL, LoadRealDll [PalSysManagement.dll] for [AgilentPalSysManagement.dll]
SHIM [AgilentPalSysManagement.dll] Get Process Addresses
SHIM DLL, LoadRealDll [PalCaps.dll] for [AgilentPalCaps.dll]
SHIM [AgilentPalCaps.dll] Get Process Addresses
System has been running 24.192625 seconds
Start Up Sequence 13.443283
Memory Load 55%
   System Physical Memory 39.816 / 73.277 MB
   Process Virtual Memory 46.125 / 1024.000 MB
-----> InfiniiVision is running <-----
failed open \Secure\InfiniiVision\LudicrousSpeed.usb
no workaround for USB phy
Exception 'Data Abort' (4): Thread-Id=04b000a6(pth=841ab178), Proc-Id=04ae00a6(pprc=841ab628) 'websockify.exe', VM-active=04ae00a6(pprc=841ab628) 'websockify.exe'
PC=40255064(ws2.dll+0x00005064) RA=00013410(websockify.exe+0x00003410) SP=0002fb7c, BVA=0003fffc
Originally I was thinking to reload firmware using TTL, but since I cannot get into u-boot prompt - can I replace that websockify.exe file directy? Not even sure if that's a problem here.
