I hurried again and loaded the .bin file uploaded by tv84. First I deleted the flash and loaded only one file starting from 0 to 8 sectors (one size 0x10000). After a successful flash when I turn on the oscliscope sometimes it boots successfully and sometimes not. I tracked across the UART where the boot fits
One example of a boot. Interrupts on kernel loading ...
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: fsmc-ecc1 128 MiB
In: serial
Out: serial
Err: serial
SerNum:serial number not programmed
Chip: BD Board Rev: 4
Net: smsc
Press space to stop autoboot: 0
## Booting kernel from Legacy Image at f8050000 ...
Image Name: PBOOT
Created: 2015-05-07 8:18:27 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 37749 Bytes = 36.9 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
An example of another boot. unsuccessful loading of all images .....
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
In: serial
Out: serial
Err: serial
Net: smsc
Image Name: PBOOT
Starting kernel ...
Debug serial initialized ........OK
RTC: 2021-3-7 23:26:40.8 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built May 7 2015 01:38:03
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
RTC: 2021-3-7 23:26:40.11 UTC
Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOERROR: Checksum failure (expected=0x31D2860 computed=0x31BA795)
****** Checksum failure on record 7, ABORT!!! ******
Completed file(s):
[0]: Address=0x80361000 Length=0x1ACB780 Name="" Target=RAM
Loading image 1 failed, trying next one
Loading image 2 from memory at 0xD1600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOERROR: Checksum failure (expected=0x31D2860 computed=0x31BBD0F)
Completed file(s):
Loading image 2 failed, trying next one
All images failed
Press r to reset
An example of a successful (at least I think it is) boot. All channels appear and everything looks good.
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
In: serial
Out: serial
Err: serial
Net: smsc
Image Name: PBOOT
Starting kernel ...
RTC: 2017-5-19 23:17:58.87 UTC
System ready!
RTC: 2017-5-19 23:17:58.91 UTC
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXXOOOOOOOOOXOOOOXOXXOXOXXOXOXOXOXXXXOOXXXOOOOOOXXOXXOXXXXXXOOOXXXOXXOOOXXXOOOXOOXOOXXOOXOXOOOOXOXOOOOOXOOOXOOOXXXOXOXXXXXXOXXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOX
OOOXOOXOOOOXXXOOOOXOOXXOOXOOOOOOOOOXOXOOOXOOOOOOXOXOOOOXOXOOOOOOOXOXOXOOXOXOOOXOOOXOOXOXXOXOOOXOXXXXXOXOXXOXXXXOXOXXOOOXXOXXXXXXXOXXXXXXXOXXXXOXOXXOXOOOXXXXOXXXXXOOOXXOXX
OOXXOXXXOOXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXXXOXOOOXOXOOXOOXXXXXXXXXXXXXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1ACB780, LaunchAddr = 0x80362000
Completed file(s):
Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
RTC: 2017-5-19 23:18:2.34 UTC
Launching windows CE image by jumping at address 0x 362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 8 2013 at 17:05:33
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Mar 7 2021)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000 size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200 (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
-EDeviceLoadEeprom 00:03:D3:04:10:00
Phy found addr 31 (ticks=3044)
WaitForLink Start (ticks=3045)
No Link (ticks=4048)
<--EDeviceInitialize
GMAC DMA status register = 0x0
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
Running infiniiVisionInstallHelper
Failed to start/configure network.
Device load time:
NANDFLASH: 0 ms
SNANDFLASH: 0 ms
SHIM DLL, LoadRealDll [PalIO.dll] for [AgilentPalIO.dll]
SHIM [AgilentPalIO.dll] Get Process Addresses
Our command line is
Performing Startup
SHIM DLL, LoadRealDll [PalSStorage.dll] for [AgilentPalSStorage.dll]
SHIM [AgilentPalSStorage.dll] Get Process Addresses
creating \Agilent Flash\selftest\
creating \Agilent Flash\wfmMem\
creating \Agilent Flash\LxiMdns\Released build, Mar 7 2021, 23:23:02
Initializing FPGA...
FPGA Type: Wyoming
Ver: 2.011 Released
Build Time: Tue May 27 16:03:14 2014
Build Machine: TS2404M
No option module detected
Keyboard firmware version 32... ok
Keyboard Info: Board id 1, Board rev 3
Startup sequence is complete.
SHIM DLL, LoadRealDll [PalSysManagement.dll] for [AgilentPalSysManagement.dll]
SHIM [AgilentPalSysManagement.dll] Get Process Addresses
SHIM DLL, LoadRealDll [PalCaps.dll] for [AgilentPalCaps.dll]
SHIM [AgilentPalCaps.dll] Get Process Addresses
System has been running 23.916475 seconds
Start Up Sequence 13.584780
Memory Load 55%
System Physical Memory 39.672 / 73.277 MB
Process Virtual Memory 49.500 / 1024.000 MB
-----> InfiniiVision is running <-----
failed open \Secure\InfiniiVision\LudicrousSpeed.usb
no workaround for USB phy
What to do next? Now the oscilloscope sometimes boots from the first attempt and sometimes from the 20th ...
Before deleting the flash via UART I was able to load version 3000XSeries.02.35.2013061800. Later, I upgraded to 3000XSeries.02.65.20210307001 via USB according to the procedure on Keysight
