Hi all,
thank you for all posts that have allowed me, three years ago, to restore my DSOX3034A.
Now I also have a DSOX2012A with corrupted NAND but i ran into a problem that i can't solve.
The DHCP works and change the address in the Oscilloscope.
I can see the address assigned with "IP Scanner" or in my router.
Although I assume that the firmware installed is 2.30 (Length=0x12F9870)
I have tried to load the nk.bin of 1.10, 2.10, 2.20, 2.30, 2.35, 2.42 without success.
The file celoader and nk.bin are in C:\DSOX\
Below I report the screen-shots of the RS232 traffic (Oscilloscope) |Oand the Win7 DOS window (PC).
I have read and reread the 116 pages of the blog but I cannot understand the problem.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Thanks for your help and sorry for my english !!!
U-Boot 2010.03 (Jan 26 2011 - 12:37:34)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: 128 MiB
In: serial
Out: serial
Err: serial
SerNum:serial number not programmed
Chip: BD Board Rev: 4
Net: smsc
Press space to stop autoboot: 0
## Booting kernel from Legacy Image at f8050000 ...
Image Name: PBOOT
Created: 2011-01-27 11:38:14 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 36703 Bytes = 35.8 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Jan 27 2011 02:
04:15
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXOOOOOOOOXOXXOOOOOOOOXOOXOXOOOÿOXXXOOOOOOOOOXOOOOXOXXOXXOXOOOXOXXXXXXOOX
XOOOOOOXOOXXOXXOOOXOXXOOXXOXOOOERROR: Checksum failure (expected=0x11DCE9E comp
uted=0x11DC098)
****** Checksum failure on record 42, ABORT!!! ******
Completed file(s):
- : Address=0x80361000 Length=0x12F9870 Name="" Target=RAM
Loading image 1 failed, trying next one
Loading image 2 from memory at 0xD1600000
BL_IMAGE_TYPE_UNKNOWN
Loading image 2 failed, trying next one
All images failed
Press r to reset
Now I leave and press space to stop autoboot P500 Boot Loader Configuration :
Mac address .......... (00:30:D3:20:8B:C5)
Ip address ........... (192.168.1.169)
Subnet Mask address .. (255.255.255.0)
DHCP ................. (Enabled)
Boot delay (seconds).. (0)
Load image 1 at startup
Image addresses. (0xdxxxxxxx for NAND, 0x8xxxxxxx for RAM)
1 (0xd0600000)
2 (0xd1600000)
l) Load flash resident image now
d) Download from ethernet now
u) Start u-boot by resetting
v) Verify Images
I press "D" option>Ready!
Downloading image from platform builder
Setting MAC address GMAC_MAC_ADDR_HI_LO[0] = 0x8000C58B, GMAC_MAC_ADDR_HI_LO[1]
= 0x20D33000
Auto Negotiation complete in 133943 iterations
Link up
AutoNegotiate Full Duplex
AutoNegotiate 100 Base T
Reading MAC address 0x30 0xD320 0x8BC5
= 0x20D33000
INFO: GMAC Ethernet controller initialized.
InitDHCP():: Calling ProcessDHCP()
ProcessDHCP()::DHCP_INIT
!CheckUDP: Not UDP (proto = 0x00000002)
Got Response from DHCP server, IP address: 192.168.1.207
ProcessDHCP()::DHCP IP Address Resolved as 192.168.1.207, netmask: 255.255.255.0
Lease time: -1 seconds
No ARP response in 2 seconds, assuming ownership of 192.168.1.207
+EbootSendBootmeAndWaitForTftp
Sent BOOTME to 255.255.255.255
!CheckUDP: Not UDP (proto = 0x00000001)
This is what it tells me from PC Command Prompt The "C:\DSOX" directory contain "celoader" and "nk.bin"
Microsoft Windows [Versione 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Tutti i diritti riservati.
C:\Users\Utente>cd \
C:\>cd dsox
C:\dsox>celoader nk.bin 192.168.1.207
syntax: celoader [binfile-name] [target-id]
CELOADER 1.3.0 - Waiting for BOOTME from nk.bin...
Packet from: 192.168.1.207
64 BYTES: EDBG-------0- ------SH600_-----------SH600_35781------A---------
Error: Received EBOOT from another target
** EXITING **
C:\dsox>
