Greetings from Brazil!
I got my own DSO-X2002A =) and with lots of licences and 200MHz upgrade!
![Kiss :-*](https://www.eevblog.com/forum/Smileys/default/kiss.gif)
Firstly, I came to thank who made this possible. I have no enough words to say THANKS to all who helped to hack the planet...eh, the scope
I'd like to add some words to the "Power-super-scope for dummies" instructions. I had lots of questions and the procedure is really simple.
So, to make it easy for dummies like me:
1 - Download Phillyflier's patched firmware from post #2167 on page 87. Seems the link is dead but you can find it here in the forum
2 - Download Luminax's license patch from post #1529 on page 62
3 - IN THE LUMINAX'S PATCH, Extract license patch. You'll have 3 files. One for install the patch, one for uninstall the patch, and the infinitiivision.lnk file which is the licence itself. Since the file is a LNK file, it will be extracted in windows as a extensionless file and you will not edit it easily. Open cmd window (if using MS Windows), navigate to WHERE YOU EXTRACTED the license patch folder and rename infiniivision.lnk to .txt
4 - Edit infiniivision.txt and replace EVERYTHING in the file with Odessa's modification from post#2197 on page 88 which is written below
80#infiniivisionLauncher.exe -l DIS -l MSO --perf -l BW20 -l SCPIPS -l CABLE -l VID5 - Save and rename file back to .lnk
6 - Copy firmware file (rename from .ksx to .cab if current scope fireware is older than v2.41) to FAT16 OR FAT32 ROOT DIRECTORY formatted USB drive
7 - IN THE SAME ROOT DIRECTORY Copy licence files (2x .cab files and .lnk file) to same USB drive
Now go to your scope, turn on and plug in USB drive to front USB port
Press [Utility] > File Explorer, select the firmware file (3000XSeries.02.50.2019022736_patched.cab); then, press Load File, wait for scope to load and reboot.
Check firmware has updated to v2.5, if successful continue
Press [Utility] > File Explorer, select v241_link_install.cab file; then, press Load File, wait for scope to load and reboot.
Check licenses have all been added and if so...
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
Hope that helps to make the procedure less confusing =)
