Author Topic: DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?  (Read 1171156 times)
Offline Mr. Scram
  • Display aficionado
Is there a way of backing up the current firmware? I can't seem to find any older firmware versions being available, which makes me nervous. As a side note, is it possible to change the logos out in the newer firmware? I can see the splash screen being an easy fix, but the right corner logo isn't as obvious.
Offline Safar
  • Country: ru
I've skimmed through the thread and have learned a lot. Can anyone please confirm the following?
*Any oscilloscope still on Agilent firmware should be upgraded to modern firmware to prevent NAND issues and possibly add extra features
*To enable features as described in this thread on recent firmware you need a DSOXLAN module or equivalent alternative. Enabling without a LAN module is no longer possible
*When enabled there is a feature which allows downgrading of the oscilloscope back to stock for the purposes of warranty or selling it.
Is this current and correct for a 2000X series?
1. New firmwares core flash twice in different memory regions
2. PhillyFlyers maked CAB file with all corrections in DLL (look in ~April), so you can just flash it like factory FW. For install different start options also exist special CAB that copy your LNK file to Secure directory. So you need only usb flash device.
3. Just use factory FW
The following users thanked this post: Mr. Scram
Offline Mr. Scram
Does anyone happen to have original Agilent era firmware or a good source for older firmware versions?
Online MarkL
Which version do you want?  I have all the X3000A versions going back to 1.10.  As far as I know they are identical to the downloads for the X2000A.
Offline whatguy
Today I applied the steps
and was able to update my scope
The .ink file includes
160#\....exe -l ALL - TOM -l DIS -l MSO -l MEMUP -l SCPIPS -l CABLE -l SGMC -l FLEXC -l BW20 -l ADVMATH -l EMBD -l EDK -l VID --perf
I have a 200MHz DSOx3024A
I was wondering could I increase the frequency?
I get an warning at boot;
"System concerns detected:
OS version is not correct. Please reload system firmware."
Other than those two issues the scope seems to have unlocked a bunch of features.
Can I get rid of the nag screen at startup and does this DSOX3024A support higher Frequency?
Offline Safar
  • Country: ru
...and does this DSOX3024A support higher Frequency?
Unfortunately not.
Next step 350/500MHz have another motherboard (actually the same, but with different input circuit elements)
You can shift by program mod only in 1 step from 100 to 200 (for DSOX301xx) and from 350 to 500MHz (for DSOX303xx)
Offline jashugan
Hello,
I'm owning a new DSOX3014T, I have a new LAN card, I have FW 7.20.2017102614, but I'm not able to enter into telnet...
For password, I used this website to generate the password: https://repl.it/repls/FrostyUnsungAcrobat
I filled the following fields:
MODEL  = "DSOX3014T"
SERIAL = my serial, MYxxxxxxxx
MAC    = my xx-xx-xx-xx-xx-xx
then run the script and get the password.
In telnet, I put "infiniivision" as user name.
For password I tried both the skywalker1977+password generated and password generated only, but it failed...
Just to be sure I'm not missing something, if my serial was MY12345678 and my MAC was 00-11-22-33-44-55, what should be the password to write into the telnet?
Thank you
« Last Edit: July 26, 2019, 09:11:51 am by jashugan »
Offline rattnallen
Try to enter the password directly after boot, there seems to be an timeout.
The password should be the password generated only, no skywalker1977 in front.
Offline The_PCB_Guy
  • PCB Enthusiast
If I remember correctly the password attempt always fails the first time. You may have to try twice before it'll let you in using Telnet.
The_PCB_Guy
Offline jashugan
Both of you were right: there is a time and password appears to fail first time. Now I have successfully cracked my DSOX3014T. Thanks!!!
Offline The_PCB_Guy
  • PCB Enthusiast
Glad to hear it!
The_PCB_Guy
Offline analogRF
Is it possible to enable the FRA (frequency response analysis) function on 3000A series?
According to the datasheet it seems that it doesn't exist but I am hoping it could still be possible
Offline lukier
    • Homepage
I would like to know the answer to that question as well. 1000X series have it, despite having less capable HW inside, so it doesn't sound like HW limitation (which was the case with 2000A MSO + decoding for example).
Offline mlloyd1
Keysight told me the answer is no.
I enabled everything on an MSO-X3024A that I have access to and FRA does not show up.
Really disappointing considering the nice function generator app that works just fine.
mlloyd1
The following users thanked this post: analogRF
Offline 2N3055
  • Country: hr
It is like this:
2000 and 3000A are same codebase, with model differences.
3000T and 4000A are same codebase, with model differences.
Sorry!
Offline Mr. Scram
mlloyd1
Agreed, it seems disappointing lower models get better features based on effectively the same hardware. It appears Keysight has trouble differentiating the very similar model ranges. Obviously there's always the option of adding it in a future firmware upgrade like they've done with various features or upgrades in the past.
Offline Altemir
  • Country: ru
Hi All!
Are model DSOX3034T will be hackable?
Offline Alanme
  • i am not perfect but i know that
Hello guys, i am in a big disaster  :palm: :palm: :palm::
I have update my DSOX 2024 to 2.5 firmware patched, with usb stick, but no licences was activated.
I have try to modifiy my infiniivision.ink and brick my scope in a continual restart. :scared: :scared: :scared:
I haved brick my scope before with a 2.35, and with the help of the community, i haved recovered my scope.
After several attemps the scope have reboot.
I have try the franckbusses serial port, but nothing appear in the terminal.
I have try with tera term, putty, and tty emulator: no way.
I have scope the RX and TX with my very old scope, when the dsox boot, i have a trame.
When i send a command, i have a trame : the serial connection work.
Why i haven' the boot sequence appearing in the terminal ?
Someone have one solution for enable licences please?
I haved all enabled, in the 2.35 firmware, and i can,t downgrade to.
I am in a very difficult situation, and a help will be very apreciate, please.
thank you by advance
« Last Edit: July 29, 2019, 01:10:02 pm by Alanme »
Offline Alanme
Offline Alanme
my(old) mother board
Online PA0PBZ
Exactly how did you connect the scope serial port to the PC?
The following users thanked this post: Alanme
Offline Alanme
my serial connection
Offline Alanme
my professionnal connector :-// :-//
Offline Alanme
my old max 232
Offline Alanme
my screen
