Update to my previous post:
New version of the mod available for the 3000T Series - Tested on 3000XSeriesT.7.10.2017042905.ksx!
After a couple of PM's from Pinkus (thank you for the sparring!), I have modified the application to read the commands from a textfile for easy modification.
Futhermore the application will check for existing infiniivision.lnk and infiniiVisionLauncher.exe in the \Secure\Startup folder and delete if any, as to avoid a bootloop situation after a system update.
(I will advise to remove the mod prior to updating just to be safe, but anyway)
Also if no command.txt is found, a new will be created with a default option of "-l all".
Feedback is greatly appreciated!
As always - Use it at your own risk!REMOVED ATTACHMENT FOR REVISION OF README
