Hi folks,
I've been meaning to offer up a quick comparison of carry cases from Rigol and Agilent/Keysight for comparable form factor DSO/MSO instruments. This is not an in-depth review --- just pictures and comments comparing two cases. I hope it is of use to those looking to purchase a carry case for their equipment.
I discuss the following carry cases:
Rigol BAG-G1 Instrument Carry Case (for DSA800 series, DG4000 series, DS/MSO2000(A) series) Website USD $147 (previously retailed for $120)
and
Agilent/Keysight N6457A Soft carrying case and front panel cover Website USD $153 (includes
front panel cover which retails for USD $52)
I have attached photos of each carry case illustrating the pockets/pouches, carry straps, handles, etc.
In terms of materials (fabric, zips, rubber feet) and construction (mostly stitching) I would rate each case to individually be of high quality, but that is not to say I deem them equally durable -- the Rigol case is superior in this regard; see following comments.
Rigol BAG-G1- Construction using rigid panels allows the bag to maintain its shape even when empty (not important itself, but illustrates the construction and rigidity which would help protect contents).
- All panels (side walls and top and bottom) are covered with "heavy duty" type woven nylon; I'm unsure what material is used for the inner part of the panel. The outer nylon looks and feels very durable, as though it would resist any tearing if it were snagged or caught on something sharp.
- Front and back panels have padding and feels dense enough (~ 5mm thick when compressed) that it would provide protection from impacts.
- Inner surface of panels is covered with finely woven nylon; softer feel than in Agilent/Keysight case.
- Three zippered external pouches: one on each side and one front facing. Front pouch has 2 internal pockets. Side pouches are small -- adequate for USB flash drives, small tools, adapters, USB cable, etc. Front pouch easily big enough for power cord.
- There is no zipper securing contents of the main compartment. Rather two clips release the curved lid which extends completely over the sides and front (covering upper part of front zip pouch). Despite that there is no zip the lid is snug fitting and all-encompassing of the main compartment -- I do not believe any reasonable sized items (e.g. pouch for your probes) would fall out in normal use/transport. Even a flash drive probably wouldn't fall out...but I'd put it in a zipped pocket to be safe.
- Lid has zippered mesh pouch on the inside -- spacious as it utilizes the full width of the case.
- Removable/adjustable divider (velcro attached) in the main compartment allow you to customize the space for a snug fit to your instrument. The divider is padded.
- Two flaps and a strap with buckle cover the main compartment to secure the instrument. Your equipment would not fall out even if the bag were open and upside down.
- Additional space in main compartment is sufficient to store your own pouches with probes.
- Carry handle with comfortable rubber grip.
- Shoulder strap is same width as Agilent/Keysight, but finer woven material. Additionally the shoulder strap is larger and more comfortable. Shoulder strap is not removable, but is adjustable in length. All metal fittings; no plastic.
- No removable zippered pouch is provided for probes.
- No name tag area.
- 5 rubber feet on bottom.
Agilent/Keysight N6457A- Soft padded construction; outer nylon has a durable woven pattern; inner nylon has finer weave, but not as fine as Rigol. This bag will not maintain its shape when empty.
- Padding is soft and compressible (< 2mm thick when compressed); would offer minimal protection against impacts thus understandable that case comes with a protective cover.
- Carry handles, and removable shoulder strap. Clips and swivels for shoulder strap are (reinforced?) plastic; do not appear very rugged. Shoulder strap pad is not as comfortable as Rigols (it is not as wide or long).
- Single front zippered pouch across full width of bag. No side pockets.
- No inner dividers or inside pockets.
- Removable storage pouch for accessories; decent size with inner divider. Can hold 4 probes and MSO kit.
- Space for name tag on the back of case.
- Main zipper opens across both side and top allowing unrestricted access to contents.
- 4 rubber feet on bottom.
SummaryOverall I find the Rigol case a superior product in terms of materials (more durable nylon fabric, metal clasps), construction (rigid panels, dense padding), and features (more zippered pouches, inner divider). I prefer the handle on top of the Rigol case than the extra pair of carry straps on the Agilent/Keysight product --- the straps tend to get in the way of opening the bag, or its not obvious at a glance which strap to grab when picking up the case to sling over your shoulder. The non-cluttered straps is important for the Rigol case because the shoulder strap is not removable. The Agilent/Keysight product tends to feel more like a "padded bag" than a "case" --- the "main compartment" (if you can call it that) is just a big void, whereas the Rigol case has a clear structure to it.
I'll be happy to answer any questions.
Cheers,
Sparky
Edit: Added additional picture.
